Problem playing wavs on SB Live! 24 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices.
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices
Discuss Problem playing wavs on SB Live! 24 in the HD World | Computers | Games | Media forum; Problem playing wavs on SB Live! 24 I bought the SB Live! 24 specifically to use with REW as my laptop did not have a line in. ...
Old 01-22-07, 05:31 PM   #1 (Link)
Alias: thm
Loc: Canada
User: #3354
Since: Oct 2006
  thm655321 is offline
I bought the SB Live! 24 specifically to use with REW as my laptop did not have a line in. I am currently trying to connect it to my stereo system to play wavs. However, I have a problem playing lossless wav files from my laptop over the Soundblaster Live! in that the sound gets choppy periodically. I do not think it is a CPU utilization issue, the hard disk is okay, I have all the latest drivers, USB 2.0 and nothing else is connected to the USB ports. If anyone has any ideas I would really appreciate it. Thanks.
THM
Old 01-22-07, 07:09 PM   #2 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: Problem playing wavs on SB Live! 24
Hi THM,
Since your question doesn’t directly relate to REW or the BFD, I’m moving your thread to our Computers Forum. You should be able to get some informed advice here.
Old 01-23-07, 07:32 PM   #3 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
  JohnM is online now
Worth making sure the card is set for 48k/16 bit in the device control app to minimise the USB load and checking the settings for background apps like anti-virus and anti-spyware apps in case they are doing background scans.
Old 01-28-07, 12:56 AM   #4 (Link)
Alias: thm
Loc: Canada
User: #3354
Since: Oct 2006
Thanks for your help John.
After much diagnosing it turns out it is the pcmcia wireless network card (which is one of the newer draft n cards). If I turn that off and use the older wireless card built in to the laptop the issue resolves itself. Must be a latency/cpu usage issue.
Thanks again for your help.
THM
Old 01-28-07, 05:16 PM   #5 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
  JohnM is online now
Interesting, I have the old Belkin pre-N card in my desktop PC and have the same problem, I disable the card to make measurements. Doesn't affect all USB devices though, I have a USB amp that I use for music and that doesn't have any problems.
« Home Theater Shack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices »
Similar Threads
SoundBlaster Live Problem Ciscokid REW Forum 7 01-07-07 03:53 PM
Embarrassing Video of Me Playing Wii Boxing geekwithfamily Home Theater, Audio and Video News 2 12-14-06 07:13 PM
VIOLENT FEMMES: LIVE AND OTHERWISE Fincave Music and DVD Concerts 0 09-01-06 06:17 AM
Anyone live near Springfield, MO? gacole2000 REW Forum 3 07-04-06 07:32 PM
Been playing with REW Thomas Funke REW Forum 8 05-03-06 03:37 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227
