| Computers | Games | HTPC | Digital Devices Soundblaster Live 24-bit External and MS Vista OSDiscuss Soundblaster Live 24-bit External and MS Vista OS in the HD World | Computers | Games | Media forum; Soundblaster Live 24-bit External and MS Vista OS I am trying to use my 24-Bit SB Live system with a new Vista Home Premium laptop. The problem is ... |
| | #1 (Link) | |||
| Soundblaster Live 24-bit External and MS Vista OS I am trying to use my 24-Bit SB Live system with a new Vista Home Premium laptop. The problem is not in hooking it up and it works fine, BUT I can not find out where or how to turn on the "Enable Monitoring" feature on the Line-In/Mic-in Advanced volume setting. It is simply not there any more, and I can not see it in the registry or the Sounds Control Panel anywhere. Please help me if you know....thanks | |||
| | #3 (Link) | |||
| Re: Soundblaster Live 24-bit External and MS Vista OS Not many Vista users here yet. Certainly in XP you simply use the Creative device application and select monitoring. I guess you're saying it isn't so easy in Vista. Are they new drivers and application programs from Creative for Vista? Some companies aren't quite up to speed on Vista yet. brucek | |||
| | #4 (Link) | ||||
| Re: Soundblaster Live 24-bit External and MS Vista OS Quote:
Evidently Creative Labs has forgotten to add the ability to turn on the "Enable Monitoring" for Line-In/Mic in Vista so far, or else I just can't find it, and I've looked everywhere I can think of! Thanks | ||||
| | #5 (Link) | |||
| Re: Soundblaster Live 24-bit External and MS Vista OS Bruce, that would be a great suggestion, but that particular setting is only availble after installing the SB software or a similar software. Doesn't come as a default with any OS that I kow of....thanks though | |||
| | #6 (Link) | |||
| Re: Soundblaster Live 24-bit External and MS Vista OS Then does Vista allow you access to the Windows mixer like XP? You would simply go to the Playback Mixer (not Record Mixer) and un-mute (or enable) Line-in and I would think that you should be able to monitor the output.... That's basically the end result of the application having Monitor enabled... brucek | |||
| | #7 (Link) | ||||
I tried to find out where to set it in the registry, and then thought it may be stored in an INI file somewhere, but no luck in either pursuit. Brian | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Soundblaster Live! 24-bit USB External Setup | bobgenie | REW Forum | 92 | 07-17-08 06:01 AM |
| Anyone get REW/soundblaster to work with Vista? | cruzmisl | REW Forum | 7 | 08-29-07 04:26 PM |
| A couple of basic questions for the Soundblaster live! 24 bit external | abergdc | REW Forum | 4 | 03-12-07 12:18 PM |
| SoundBlaster Live Problem | Ciscokid | REW Forum | 7 | 01-07-07 02:53 PM |
| Will 32-bit Windows Vista play HD DVD and Blu-ray? Maybe | HDBeat | Home Theater, Audio and Video News | 0 | 08-25-06 01:22 AM |
