| Computers | Games | HTPC | Digital Devices BR/HD DVD Combo driveDiscuss BR/HD DVD Combo drive in the HD World | Computers | Games | Media forum; BR/HD DVD Combo drive It is finally out: http://www.newegg.com/Product/Produc...82E16827136133
It's a DVD drive for PCs that does Bluray and HD DVD. $299. It has ... |
| | #1 (Link) | |||
| BR/HD DVD Combo drive It is finally out: http://www.newegg.com/Product/Produc...82E16827136133 It's a DVD drive for PCs that does Bluray and HD DVD. $299. It has been in and out of stock all day. It comes with PowerDVD to be able to play back either title type, so if you've already got an HTPC and are sitting on the fence on the BR/HD war- this is an easy escape. Couple of caveats: if you projector is digital only and doesn't have HDCP, it won't display. If you don't have digital inputs, no problem (explain that one), as the software will output via VGA or component. Ideally, you would have an HDCP 'chain' and be done with it, but HDCP cards are still not mainstream yet. For me, my PJ is analog, and this may be what is needed to get my HTPC revived. | |||
| | #2 (Link) | |||
| Re: BR/HD DVD Combo drive The LG drive does look pretty sweet. I wonder how long it will be before production will keep up with demand. If they fall under $200 around x-mas time I might go crazy and pull the trigger. With or without a high-def TV ![]() | |||
| | #3 (Link) | |||
| Re: BR/HD DVD Combo drive Looks great. I'm actually starting the prep work for my new PC and This drive would be great for it. And at $299, that's an amazing price. Now to just put the money together... =-) ------------------ Mark Santora Editor Los Angeles, CA | |||
| | #4 (Link) | |||
| Re: BR/HD DVD Combo drive Yep, we're finally getting there. $300 is still a pretty bitter pill to swallow for a single optical drive, but I remember thinking the same thing about DVD-Burners and people still bought them. Unfortunately, I don't think this price is going to drop as fast as the stand alone units. I don't see the demand being there. For me, this drive would have to hit $100, the price I paid for my A2, before it went in the HTPC. One more thought, another thing that would speed the sale of these, and the MPAA doesn't want to hear it, somebody cracking the copy protection for good on both formats, and coming up with a piece of software, like DVDShrink, that would save a high quality compressed copy to their movie server. Something like a 10GB H.264 file. Then you see the sale of these things pick up. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #6 (Link) | |||
| Re: BR/HD DVD Combo drive I breezed through the topic titles, but must have missed it. Can you give me a link to the thread, or drop the name of the software? Thanks, Marshall Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #7 (Link) | ||||
| Re: BR/HD DVD Combo drive Quote:
I may be way off though, and if so I apologize for my ignorance. | ||||
| | #8 (Link) | |||
| Re: BR/HD DVD Combo drive It will still be better than DVD quality, in higher rez for sure, and should even have less compression artifacts as h.264 is a very efficient codec, and you should be able to keep the Dolby Digital Plus or Dolby TrueHD soundtrack. You could of course keep the HD movie in full 20GB glory, but for those of us with movie jukeboxes, being able to store twice as many movies would be worth the slight quality hit. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #11 (Link) | ||||
Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | ||||
| | #12 (Link) | |||
| Re: BR/HD DVD Combo drive anyone have any info if you can use the dolbyHD from a computer or only you get regular dolby5.1??compare to a stand alone HD/BR player Last edited by uxmal; 11-10-07 at 08:28 PM. | |||
| | #13 (Link) | ||||
Sending the decoded audio out via lossless 5.1 channel linear PCM on HDMI is very tricky and very limited at this moment. Just a few have done it using just certain PC motherboards and a special HDMI add on PCI card. It could be that the Toshiba X205 Notebook PC does it right for 5.1 LPCM audio with its HDMI output. Notebook PC's are easier to secure the audio (for the satisfaction of the content providers and the AACS). | ||||
| | #15 (Link) | |||
| Re: BR/HD DVD Combo drive The very very best most expensive DACs are really only accurate to 20 bits or so. If the source track was properly dithered, then 16 bits is normally as good as any normal good quality home sound system can use. Requires a very very quiet room and a lot of max SPL capability to take advantage of 20 bits. 24bit depth is great for editing/processing. | |||
| | #16 (Link) | |||
| Re: BR/HD DVD Combo drive I purchased the LG combo drive just before the holidays for my HTPC. It plays HD-DVDs and Blu-Ray movies wonderfully with Cyberlink Ultra. However, getting TrueHd via analog connections didn't work for me. Thru analog Cyberlink gave me an error message that one item wasn't HDCP compliant, but thru Toslink it played fine. My soundcard (HT Omega Claro) does support 24-bit 192khz, but if Cyberlink won't allow analog playback then it's good for nothing. ![]() | |||
| | #17 (Link) | |||
| Dont worry Auzentech is coming with hdmi for the Auzentech X-Fi Prelude is great here is the press realase http://www.auzentech.com/site/company/press.php ![]() | |||
| | #18 (Link) | |||
| Re: BR/HD DVD Combo drive Thanks, uxmal for the heads up. This seems like a good work around for getting HD audio from a HTPC, but hdmi 1.3? How can it say that it's hdmi 1.3 compatible if it can't do video. Shouldn't graphics cards be 1.3 and do audio in the future? Just wondering... ![]() | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| DVD/VHS Combo player | Bob_99 | Home Theater Components | 6 | 11-09-07 06:55 AM |
| LG BH100 Blu-ray Disc/HD-DVD Combo Player - Product Review | Sonnie | High Definition | HD-DVD | Blu-ray | 5 | 03-28-07 03:39 PM |
| DVD Recorder with Hard Drive | Bob_99 | Home Theater Components | 2 | 12-18-06 03:02 PM |
| IFA 2006: Pioneer NOT planning HD DVD / Blu-ray hybrid drive | HDBeat | Home Theater, Audio and Video News | 0 | 09-04-06 12:50 PM |
| Receiver/DVD combo? | Brian Bunge | Home Theater Components | 6 | 05-27-06 06:56 PM |
