Whitch is better fo streaming audio - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices
Discuss Whitch is better fo streaming audio in the HD World | Computers | Games | Media forum; Whitch is better fo streaming audio Is it better to use my 360 or pc for .wav and .mp3 files streamed to my receiver?...
Old 11-01-07, 07:34 AM   #1 (Link)
Alias: jwhite
Loc: Houston,Texas
User: #6296
jwhite8086 is offline
Old 11-01-07, 08:07 AM   #2 (Link)
Alias: bob
Loc: Houston, TX
bob1029's Avatar
User: #7011
bob1029 is offline
Re: Whitch is better fo streaming audio
Depending on the quality of the mp3/wav stream, I would probably go with a pc, since you can get a soundcard with a higher quality dac. Also, you have more flexibility in which programs you use for streaming. With a pc you have the ability to use software such as Winamp, which has a great selection of high-quality internet radio stations.
Old 11-01-07, 04:01 PM   #3 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
I dont know what the 360 has for decoding but I can tell you that not all decoders are created equal and the quality from one mp3 player to the next is noticeable. I still have an old Nomad Jukebox that I upgraded the hard drive in to a 40gig and it sounds far better then my friends Ipod even though he uses a higher bitrate than I do, Im still using 60%vbr for all my mp3 files. (we have even compared the same track both at 160vbr)
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2,
2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Nintendo Wii
Old 11-01-07, 04:19 PM   #4 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
Josuah is offline
Doesn't matter if you can send a digital bitstream instead of analog. Which you should be able to. I wouldn't send an analog signal from either your XBOX 360 or PC if at all possible to avoid it.
Old 11-02-07, 11:52 AM   #5 (Link)
Alias: jwhite
Loc: Houston,Texas
User: #6296
Thats some good information, I haven Asus M2n32-sli deluxe with onboard sound max I can output spdif or fiber optic to my yamaha HTR 5760. Would the DAC in my receiver, media player, or sound card determin the sound quality ?
Old 11-02-07, 08:59 PM   #6 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
Josuah is offline
Since you're sending a digital signal out of your computer/XBOX, the only DACs being used would be in your receiver (digital to analog converter).
« Home Theater Shack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices »
Similar Threads
Welcome Fi Audio!!! Sonnie Forum Announcements | News 0 09-12-07 03:27 PM
JL Audio lcaillo Manufacturer and Vendor Reference Information 0 05-14-07 07:20 PM
Outlaw Audio lcaillo Manufacturer and Vendor Reference Information 0 05-08-07 06:49 AM
PS Audio lcaillo Manufacturer and Vendor Reference Information 0 05-06-07 06:21 PM
Mach 5 Audio
