IR repeater compatibility with Xbox 360 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices
Discuss IR repeater compatibility with Xbox 360 in the HD World | Computers | Games | Media forum; IR repeater compatibility with Xbox 360 I finally broke down and purchased an IR repeater system to control my components, which are not in my theater ...
Old 12-05-07, 11:31 PM   #1 (Link)
Alias: jack
Loc: Chicago Suburbs, IL USA
basementjack's Avatar
User: #2649
Since: Sep 2006
basementjack is offline
I finally broke down and purchased an IR repeater system to control my components, which are not in my theater room.
Everything works except the 360 (using the IR media remote, the RF controllers work fine)
I've tried everything, including a high powered "blast emitter" from parts express.
Does anyone have any experience with IR repeaters and a 360?
Heres what I've got:
from a1components.com:
IR target - fits in a keystone jack, has a red led that lights up when hit by IR $11
IR repeater block with Power Supply $27
IR emitters - 2 off one plug $7
total of about $50.
- Jack
Old 12-08-07, 11:57 AM   #2 (Link)
Shack Moderator
Alias: Mark
Loc: Northern Utah
nova's Avatar
User: #278
nova is offline
Re: IR repeater compatibility with Xbox 360
Sorry, I have no experience with either, but are you using Media Center? If so I do believe that remote uses rolling codes or some such nonsense. You can try and disable Debounce and see it that takes care of the problem.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\idIr\Remotes\745a17a0-74d3-11d0-b6fe-00a0c90f57da] or
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\HidIr\Remotes\745a17a0-74d3-11d0-b6fe-00a0c90f57da]
depending on which version of MCE.
Should see DWORD key called "EnableDebounce". Pobably set to 1. Set it to 0 to disable Debounce.
Then reboot,... worth a shot anyway. If you're not using MCE,..????
I'd only suggest doing this if you are comfortable messing around in Windows registry, I'd also recommend you back-up your current registry before attempting this. But then, you're a computer guy anyway,... right?
Mark
Old 02-02-08, 09:38 AM   #3 (Link)
Alias: George
Loc: Nova Scotia
User: #15981
Since: Jan 2008
Rambo4 is offline
I have an IR repeater working on my Xbox 360. I can control any video or music that I need without the need to buy another remote. Mind you I have it working with a Control4 system. I downloaded the drivers for the 360, and it worked right away. The C4 system was the price of a decent universal remote, and I feel was well worth it.
Regardless, IR repeaters will work with a 360. Just a matter of finding the magic code for your repeater.
« Home Theater Shack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices »
Similar Threads
New Model PS3 and Xbox 360 wbassett Computers | Games | HTPC | Digital Devices 18 10-19-07 07:19 AM
Xbox 360 as a DVD player Instal Computers | Games | HTPC | Digital Devices 2 09-21-07 11:02 AM
XBox 360 Steve Williamson Computers | Games | HTPC | Digital Devices 21 06-05-07 05:47 PM
Xbox 360 for my Bday FlashJim Computers | Games | HTPC | Digital Devices 5 04-17-07 10:32 PM
HD-DVD for the Xbox 360 confirmed Roger Home Theater, Audio and Video News 0 05-09-06 07:16 PM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
