Upgrading laptop hard drive - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices
Discuss Upgrading laptop hard drive in the HD World | Computers | Games | Media forum; Upgrading laptop hard drive I’d like to upgrade the hard drive in my Compaq Evo 600 laptop from a 30 gig to an 80. ...
Old 01-12-08, 11:39 AM   #1 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
I’d like to upgrade the hard drive in my Compaq Evo 600 laptop from a 30 gig to an 80. I’ve found some on eBay, but something I’m seeing in the specs has me nervous. They mention its RPM capacity, but notes that it has power specifications similar to a slower drive.
Power specifications – is that something I need to be concerned about – i.e., that the power supply might not be able to support some hard drives?
I can’t find any info in the manual on the stock 30 gig hard drive I’m using, except that “Any 9.5 mm hard drive can be used in the hard drive bay.”
Here are the features for a 7500 RPM drive. Below it are the features for a 5400 RPM drive. I assume the 7500 PRM unit is better, but being an audio guy, I have no idea what any of this stuff means. Hopefully some of you can decipher some of it for me.
  • Enhanced Adaptive Battery Life Extender 3.0 for maximized battery life
  • Low Power: Spins at 7500 RPM for fast performance but has power specifications similar to slower 5400 RPM drives
  • Fluid Dynamic Bearing Spindle Motor for lower acoustics and increased non-operating shock tolerance
  • Ultra Quiet : Advanced noise reduction using a Voice Coil Motor (VCM) Damper
  • S.M.A.R.T. compliant detection system that gives advanced warning of possible drive inconsistencies
  • Stiffness-reinforced base casting construction offers enhanced stability and greater vibration/shock resistance
  • Antiferromagnetically-coupled (AFC) "pixie dust" media
  • Specular Layer giant magnetoresistive (GMR) heads
  • Ramp Head Load/Unload technology
  • Partial Response Maximum Likelihood (PRML) read channel
  • Adaptive Formatting
  • Low Power: Spins at 5400 RPM for fast performance but has power specifications similar to slower 4200 RPM drives
  • Stiffness-reinforced base casting construction offers enhanced stability and greater vibration/shock resistance Antiferromagnetically-coupled (AFC) "pixie dust" media
Old 01-12-08, 06:23 PM   #2 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is online now
Re: Upgradiing laptop hard drive
Hi Wayne,
The power specification is normally intended toward those that want to maximize battery life -- the less power used, the longer the batter will last. If you're like me and leave your laptop plugged in pretty much 24/7, you won't care about power specs. If you fly a lot and want to watch DVDs on the plane, you will be more senstitive to power requirements.
The higher spin rate of the drive, the faster you will be able to read the data from the media (all else being equal). If you are performance sensitive (opening large files, can't wait for XP to boot, etc.) you'll want as high a spin speed as you can find/afford. For many people, it won't make that much difference. I primarily use my laptops for web browsing and remote desktoping, so performance isn't critical for me. If you are opening large files and/or file swapping a lot, performance might be more important for you.
As far as the power spec relating to the concept that your laptop won't be able to apply enough power to it to allow it to work properly, I don't think you should worry about it. All the power stuff that I've dealt with is always related to power savings for battery life. Your laptop should have no problem powering a 7200 (or 7500) or 5400 RPM drive.
The only thing I would worry about in this case is heat. It's one of those weird things that could cause problems that would be intermittent and nebulous to describe. The 7200 RPM drive will almost surely generate more heat (it's spinning faster) and that could cause trouble in your system if it's on the edge of being too warm already. Now, I've replaced two 5400 drives with 7200 RPM drives (two different Toshiba Satellite laptops) and haven't had any troubles with heat.
FWIW, I would very much suspect that your original drive is a 5400 RPM drive.
All the other features don't make a lot of difference to most end users. For the past eight years, I've worked for either of the two major hard drive companies, and I find that many of the features and performance enhancements are for our customers rather than the end users. Sure, there are gamers, high end users and companies that really need everything that can be offered, but for the average user, the highest performing drives aren't really necessary.
If I guess right, you'll be just fine with a relatively current, 5400 RPM drive. It will be adequate and reasonably priced.
Anyway, that's my tak e on the subject.
-- Otto
Old 01-13-08, 05:55 AM   #3 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Thanks for the great info, Otto! There’s only $10-12 difference between the two, so I’ll probably get the fast one.
Old 01-13-08, 09:06 PM   #4 (Link)
Alias: jack
Loc: Chicago Suburbs, IL USA
basementjack's Avatar
User: #2649
Since: Sep 2006
basementjack is offline
Wayne - there are 2 interfaces for Laptop drives - P-ATA and S-ATA
Sata drives have shown up in newer laptops - if you search tiger.com or newegg.com you'll see laptop drives of both varieties.
Be sure to pick up the one you have now.
A new laptop drive is one of the best ways to speed up your laptop!
It might even be worth looking for laptop drive reviews on the internet - storagereview.com might be one place to check - tomshardware.com might be another.
aside from the internal drive, you could also add an external.
There are small USB powered external drives (they are usually 2.5" laptop drives in an enclosure)
there are also larger external drives that require the use of the included power adapter.
one relatively new category of external drive is one with an e-sata interface.
Sata is the most common interface on new PC's, and Esata basically lets you connect a hard drive to your PC, with no loss in drive speed (USB is slower than most hard drives, hence the need for something like e-sata)
I have seen Laptop PCcards with E-sata ports (PCCards used to be known as PCMCIA cards way back when)
- Jack
- Jack
Old 01-15-08, 08:11 PM   #5 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Re: Upgrading laptop hard drive
Thanks, Jack. I don’t know how old this laptop is, I figure at least 3-4 years. So I doubt it’s a Sata?
The eBay vendor doesn’t specify which kind it is, but I assume that since it’s model-specific for mine, it’s the right kind?
Old 01-15-08, 08:34 PM   #6 (Link)
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
Otto is online now
Hi Wayne, guys,
Yeah, it's probably not SATA at that age. You can certainly tell if you open it up, and that shouldn't be hard -- they're usually just behind a panel on the bottom in some way or another. If the eBay vendor doesn't specify, I'd ask him just to be sure.
-- Otto
Old 03-29-08, 03:08 PM   #7 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
An update, I got the 80-gig high speed hard and it's installed and up and running great. Thanks everyone for the guidance.
« Home Theater Shack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices »
Similar Threads
Upgrading Bob_99 Home Audio Speakers 16 10-26-07 02:44 PM
Looking for a good outboard hard drive Wayne A. Pflughaupt Computers | Games | HTPC | Digital Devices 11 07-07-07 04:26 AM
external hard drive for movies scott Computers | Games | HTPC | Digital Devices 13 01-17-07 08:42 AM
DVD Recorder with Hard Drive Bob_99 Home Theater Components 2 12-18-06 03:02 PM
Hard Drive Encryption at Your Fingertip Roger Home Theater, Audio and Video News 0 09-08-06 08:24 PM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
