The Right VGA Cable? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices
Discuss The Right VGA Cable? in the HD World | Computers | Games | Media forum; The Right VGA Cable? I've been told that when hooking up my PC to the tv through VGA, I will need a thicker gauge ...
Old 03-01-08, 09:40 PM   #1 (Link)
Alias: Ryan
Loc: San Bernardino, CA
User: #17392
Since: Feb 2008
powder21 is offline
I've been told that when hooking up my PC to the tv through VGA, I will need a thicker gauge cable than what is normally used. Is this true? If so, is the Belkin High Integrity Monitor Replacement cable going to do the trick (Like the one on Staples website) Or do I need to get something else? If so what?
Also, my new TV will be "HD-Ready". Will this be ok for watching HighRes (720p) DVD and TV rips off my puter?
Appreciate any help anyone can give. Thanks.
-Ryan
Old 03-02-08, 07:12 AM   #2 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is offline
Re: The Right VGA Cable?
Longer runs of VGA cable require a higher quality cable. How far from your PC to the TV?
We're all in this together!
Old 03-02-08, 09:25 AM   #3 (Link)
Shack Moderator
Alias: Mark
Loc: Northern Utah
nova's Avatar
User: #278
nova is online now
Well, it depends. As Mike mentioned, if it is a ways away you may need a better cable. In general you will be fine with a 6' cable. A better question is "Does your TV have a VGA input?" Most do not, they will usually have component, DVI, or HDMI. More than likely you will need a DVI or HDMI cable.
What is your new TV (Brand, Model)? Does your video card have and HDMI or DVI output?
Mark
Old 03-02-08, 11:03 PM   #4 (Link)
Bronze Supporter
Alias: jack
Loc: Chicago Suburbs, IL USA
basementjack's Avatar
User: #2649
Since: Sep 2006
basementjack is offline
one tip - if you are using a VGA cable, it's best to use a single cable , vs 2 connected together.
Try places like monoprice.com for affordable, thick VGA cables.
- Jack
Old 03-03-08, 12:38 AM   #5 (Link)
Alias: Ryan
User: #17392
Since: Feb 2008
powder21 is offline
Actually, the new TV will have a VGA input...if it didn't, my puter has a DVI output as well. Thanks for the tip about connecting more than one cable. I was planning on getting a 6 foot and connecting to a 10 foot extension. Maybe not wise. My tv will only be about 7 feet away, but the way I plan to run it...I'll probably need about 14-15 feet. I wanted to get the Belkin from Staples, because I have a gift card. Oh well...if it's not wise to connect two, then I will have to go somewhere else.
Oh...btw. Can anybody tell me what exactly these "higher quality / better" cables are called or what gauge they are or simply anything that will help me track down the right one. I work at Staples and the "High Integrity" is much thicker than the regular ones. (Links would be helpful here )
-Ryan
Old 03-03-08, 12:53 AM   #6 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is offline
Here's a thread discussing VGA cable length. Post #9 has links showing what you should look for.
http://www.hometheatershack.com/foru...le-length.html
Old 03-03-08, 06:21 PM   #7 (Link)
Alias: Ryan
User: #17392
Since: Feb 2008
powder21 is offline
Cool, thanks for the link...I'll be sure to read up and post back when I've found what I need. Thanks again.
Old 03-04-08, 07:11 AM   #8 (Link)
Bronze Supporter
Alias: jack
User: #2649
Since: Sep 2006
The thing to look for in a VGA cable is that it is constructed of 3 coax cables internally - and not just a bunch of straight wires. This is typically what makes the cables thicker, though wire guage can come in to play also.
I bought several VGA cables some years ago from www.pimfg.com Including a 50 foot VGA cable for use doing a presentation. I was very impressed - there was no ghosting, drifting, etc. it looked like the projector was connected to the laptop with a 6 foot cable.
Search the site for IBM-VGA-15-MM - its a 15 foot male to male cable made with coax for the RGB signal.
Cost is $8.33
- Jack
Old 03-04-08, 10:02 PM   #9 (Link)
Alias: Ryan
User: #17392
Since: Feb 2008
powder21 is offline
Awesome...thanks again.
« Home Theater Shack > HD World | Computers | Games | Media > Computers | Games | HTPC | Digital Devices »
Similar Threads
DIY Cable and Cable Tools Sonnie Remotes | Cables | Accessories 5 09-23-08 04:45 PM
VGA cable length toecheese Computers | Games | HTPC | Digital Devices 20 02-09-08 01:08 AM
how long can VGA cable be run? drf Home Theater Projectors 16 11-03-07 02:37 AM
Has anybody bought cables from Signal cable or Colbolt cable??? Jay C Huskers Remotes | Cables | Accessories 0 02-04-07 11:28 AM
Good Sub Cable w/Cheap Y-Cable... Lose Quality? baniels Remotes | Cables | Accessories 4 12-07-06 10:22 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
