| Computers | Games | HTPC | Digital Devices Why HDMI ?Discuss Why HDMI ? in the HD World | Computers | Games | Media forum; Why HDMI ? From VGA to DVI, I can't see much of a difference.... Is there any real difference between DVI and HDMI ... |
| | #1 (Link) | |||
| Why HDMI ? From VGA to DVI, I can't see much of a difference.... Is there any real difference between DVI and HDMI to the eye? thx Samsung 24" LCD Widescreen 245BW X-Fi Elite Pro Soundcard B&W 685 AA hAvoc 18" with 2 PR1816 in 7.3cu.ft@18.5hz Crown XTi1000 Crown XTi2000 the big summer upgrade(new big sized bookshelves with new sub setup)**Soon to be a new MTM DIY project** | |||
| | #2 (Link) | |||
| Re: Why HDMI ? DVI=HDMI They are interchangeable. Many products claim HDMI but really have a DVI with an adapter. Correct me if I'm wrong, of course. Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3 | |||
| | #3 (Link) | |||
| Re: Why HDMI ? Well, maybe. In fact, it is also possible that VGA=DVI. DVI connections can contain analog or digital. The digital signals are the same as HDMI video, while the analog are generally the same as VGA or whatever flavor of VGA you have on the system. DVI-I contains both signals, and if your system uses the analog, you would not see a difference between DVI and VGA because they are the same signal. Same with DVI digital and HDMI. "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | |||
| | #4 (Link) | |||
| Re: Why HDMI ? Really the only difference between HDMI and DVI-D (other than the connector) is that HDMI sends a handshake signal with it and also sends digital audio. This makes it easy to make or get an adapter from DVI to HDMI Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| | #6 (Link) | |||
| Re: Why HDMI ? so its basically the same thing as dvi in terms of video quality.. the difference is that it also transfers audio signal? Samsung 24" LCD Widescreen 245BW X-Fi Elite Pro Soundcard B&W 685 AA hAvoc 18" with 2 PR1816 in 7.3cu.ft@18.5hz Crown XTi1000 Crown XTi2000 the big summer upgrade(new big sized bookshelves with new sub setup)**Soon to be a new MTM DIY project** | |||
| | #7 (Link) | |||
| Re: Why HDMI ? Yes. I have a HDMI signal coming out of my receiver and going to my Projector that only has DVI so I just got an adapter cable. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| | #9 (Link) | |||
| Re: Why HDMI ? To the eye, as others already said, not much. Correct if I am wrong, but as far as I know, if you want to play a Blue Ray disk in your PC you need a card with an HDMI interface which supports HDCP and an appropriate display also. Of course HDMI also caries audio as well.. | |||
| | #10 (Link) | ||||
| Re: Why HDMI ? Quote:
dvi can play blu-ray and support HDCP, idk if my 245bw is appropriate for blu-ray but i played a 1080p movie under .mkv extension and the colours and quality was top notch. Samsung 24" LCD Widescreen 245BW X-Fi Elite Pro Soundcard B&W 685 AA hAvoc 18" with 2 PR1816 in 7.3cu.ft@18.5hz Crown XTi1000 Crown XTi2000 the big summer upgrade(new big sized bookshelves with new sub setup)**Soon to be a new MTM DIY project** | ||||
| | #11 (Link) | |||
| Re: Why HDMI ? Are you sure? As far as I know the main reason for "inventing" HDMI from the movie industry was HDCP. .mkv is not a BR disk. As far as I know, HDCP is removed in .mkv BR rips. | |||
| | #12 (Link) | |||
| Re: Why HDMI ? Yep for sure DVI can (optionally) do HDCP. HDCP is not required in a DVI connection but is required for HDMI as you say. However DVI can also have HDCP and do the handshake for copy protected video (thereby making a Blu-ray player happy). Not all displays with the digital version of DVI have HDCP, but some (more and more these days) do. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| HDMI Switcher? | basementjack | Remotes | Cables | Accessories | 3 | 02-09-08 06:54 PM |
| HDMI to 2 displays | legacy | Home Theater Components | 0 | 08-23-07 01:53 PM |
| HDMI Twins: Is BetterCables Selling an $89 HDMI Switcher for $350? | geekwithfamily | Home Theater, Audio and Video News | 2 | 02-27-07 11:11 AM |
| New Here- HDMI ?'s | tango | Home Theater Components | 8 | 02-08-07 06:19 PM |
| All PS3's will have HDMI 1.3 | bobgpsr | High Definition | HD-DVD | Blu-ray | 2 | 09-25-06 11:41 AM |
