Internet speed problems - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
 8Likes
post #11 of 37 Old 10-17-16, 04:07 PM
Andre's Avatar
Andre
Re: Internet speed problems
I bought one of these to test if I had any bottlenecks.
https://www.amazon.com/Tonor-RJ45-Ne...s=cat+5+tester
ellisr63 likes this.
Andre is offline
post #12 of 37 Old 10-17-16, 06:38 PM
fschris
i am a CCNP so i will throw out a couple things:
1. Have you tested a PC or laptop connected right to the cable modem for your desired speeds that you are looking for ?
2. that is all the cable company will care about.
Now, your network is a hodpodge of devices and those switches are not that great. You could have a STP issue, vlan issue, default gateway issues etc... even the crappiest cat 5 in your house from 1985 could probably do 100mb so i doubt you have a major wiring issue. But you never know...
Also don't forget if you test your internet speeds on dslreports (etc) you will never get those speeds in real life internet browsing. Netflix will give you about 5Mb downloads and ultra HD is around 25. I mean even trying to upload pictures to the cloud will be limited.
I highly suggest using Ubiquiti networks gear and use a Ubiquiti WAP. All the netgear stuff is kind of junk. Its kind of like amplifies sayiung they can handle 5000 watts.
https://help.netflix.com/en/node/306
fschris is offline
post #13 of 37 Old 10-17-16, 09:23 PM Thread Starter
ellisr63's Avatar
Ron
fschris wrote: View Post
Thanks for the info. Yes, I have tested it at the modem...when the Tech was here he did that, and got my speed up (wired and wifi, but soon after he left it dropped down. In addition now my Modem gets a latency error if I try to hook up the modem directly to the laptop. I have tried several cables, and the only way to have internet working now is with the modem plugged into the Netgear router. My Provider guarantees at least 200Mbps from the modem, and I tested it from their site with the Tech on the phone, and it varied from .3Mps to 239Mps (this was done with multiple tests from my HT with a Cisco switch).
I am not going to be buying new network switches or routers as it worked fine before we upped it to 250Mps from 100Mps.
Ron
My Home Theater
ellisr63 is offline
post #14 of 37 Old 10-18-16, 05:55 PM
fschris
have you ever transferred files around your network faster than 100m? i have issues doing this since my PCs and servers cant really do it. I would just not get too excited about having 250Mb download since the fastest you can download netflix is about 25 MB
fschris is offline
post #15 of 37 Old 10-18-16, 08:16 PM Thread Starter
ellisr63's Avatar
Ron
I have had speeds of up to almost 300Mbps across my LAN in the past.
Ron
My Home Theater
ellisr63 is offline
post #16 of 37 Old 10-19-16, 03:36 PM Thread Starter
ellisr63's Avatar
Ron
We had 2 Techs show up today to fix the problem. They found that the coax barrels were bad, and replaced them. Then they tested with their laptop to our modem, and got 250+Mbps. When they tested it with my wife's laptop the speed dropped down to less than 50Mbps. They tried testing bypassing the wires to the router, and disconnecting all 3 switches...signal came back to 250+ Mbps. Then they plugged in the switches again (testing after each one is up), and the speed was still 250+. I then asked them to run the test again just to make sure, and it dropped down again. They said that it is either my wife's laptop, our switch that is next to the router or that the wires need to be replaced in the wall. I will return the switch, and see if that solves the problem...if not then I guess it will be time to run new cat 6 to the switches to replace the current cat5 wires.
Ron
My Home Theater
ellisr63 is offline
post #17 of 37 Old 10-20-16, 11:56 AM Thread Starter
ellisr63's Avatar
Ron
My friend is going to come over this weekend and see if we have a noise interference problem...since the Tech was able to get full speed from their laptop, but not from my wife's laptop a couple of feet away. Are there settings on a Win8 or Win10 laptop that could cause problems? I have noticed that her laptop doesn't even see our 5Ghz wifi, but does see the lower one. The laptop is only about 2 years old.
Ron
My Home Theater
ellisr63 is offline
post #18 of 37 Old 10-20-16, 02:46 PM
fschris
Is the laptop 802.11a or 802.11g ?
http://www.radio-electronics.com/inf...s-tutorial.php
fschris is offline
post #19 of 37 Old 10-20-16, 05:00 PM
HTS Moderator
Reviewer
theJman's Avatar
Jim
ellisr63 wrote: View Post
A setting should either work or not work; intermittent issues suggest something else to me. Variations - especially wide ones like this - are often associated to a mismatch of some type. Continuing on with my driver/firmware theme... is your wife's laptop in need of an update perhaps?
-Jim
theJman is offline
post #20 of 37 Old 10-20-16, 08:19 PM Thread Starter
ellisr63's Avatar
Ron
theJman wrote: View Post
I will have to check and see if she has all the latest updates.
Ron
My Home Theater
ellisr63 is offline
internet , problems , speed
