Computer backup software? - Page 2 - Home Theater Forum and Systems -
post #11 of 22 Old 07-21-07, 12:34 PM
Jusbegood's Avatar
Re: Computer backup software?
F.Y.I........There's an end of the week sale for Acronis True Image 9.0 for $9.95 at don't know why this is so, because Acronis usually doesn't allow 3rd party vendors to sell their software. If you do spring for the software, and use it, I'd appreciate your opinion/s. Before you make a decision, you can check out the Acronis forums @ to do a little lurking in order to broaden your knowledge.
Jusbegood is offline
post #12 of 22 Old 07-21-07, 11:53 PM
wbassett's Avatar
I haven't tried it or anything, but there was some backup software that came on the My Book external drive I bought. I also know that the next model up My Book has a one button backup feature, just push the button and it backs everything up to the external drive.
Other than that, I'm also a big Ghost fan.
wbassett is offline
post #13 of 22 Old 07-22-07, 12:02 AM Thread Starter
HTS Hillbilly
HTS Administrator
I'm a redneck!
I downloaded True Image tonight (15 day trial version) and tried it out. It was pretty painless and took about 30 minutes to do a full image backup of my C drive, which is about 36GB.
One thing I liked about it, unlike my AVG... I don't notice it doing its thing in the background. At least that is a good thing. Unlike my desktop that I only restart a couple of times a week, I shut down my laptop every time I finish up with it or am going to be away from it for more than an hour or two. Timing the AVG and backup software to run can sometimes be tricky... it ends up not always getting that opportunity to run and wants to run when I start up. I notice AVG running in the background... it slows things down considerably, despite setting it to slow. This was one thing I was concerned about because my intentions are to do at least a couple of backups per week.
Cedar Creek Cinema
PremierHomeAudio: Denon, Marantz, Onkyo, Yamaha, Sony, Pioneer, Def Tech and more. Shoot me a PM!
Sonnie is offline
post #14 of 22 Old 07-22-07, 08:27 AM
mechman's Avatar
Steve Mechelke -mech
Maybe I'm silly, but I've always used the Windows backup program for both the laptop and the desktop. I've got an external for the laptop. The desktop is backed up to a second internal - no mirrored raid or anything like that. Occasionally (once per month) I'll burn a DVD-RW of my important stuff.
All I ever back up is my documents and that's generally under a gig.
I have used Ghost in the past and thought it was good. I guess I never had bad enough trouble where I could justify backing up everything or "ghosting" if you will.
'Knock on wood'
I've reformatted and reloaded Windows numerous times for numerous people. It can be tedious for some. But I view it as a beer drinking event!
mechman is offline
post #15 of 22 Old 07-22-07, 09:42 AM
I use sync-back to backup files from 3 different hard drives onto one large badckup drive. It has an auto backup schedule, and is free.
It does save the files as multiple files, and not as a single image, if that makes a difference.
eugovector is offline
post #16 of 22 Old 07-22-07, 09:55 AM
Send a message via AIM to bobgpsr
For those who want to get by with a minimum setup, you do get a functional backup software app when you buy a Seagate external hard drive. I've been using it for almost a year.
bobgpsr is offline
post #17 of 22 Old 07-23-07, 06:40 PM
bob1029's Avatar
Send a message via AIM to bob1029 Send a message via MSN to bob1029
Personally, I would use Robocopy, a program that is part of the free windows server 2003 resource kit. I use it at work all the time to back up entire hard drives for several reasons:
1. It backs up EVERYTHING.
2. If you run it again with the same parameters, it will only copy the changed/additional files.
3. Its free.
4. The files are copied 1:1, so you can access them immediately from any computer (no need to worry about disk image reading software).
The idea is, you have a source drive (c) and you want to do a 1:1 copy to a destination folder on a usb drive (d:\my backup). You simply run the command:
Robocopy.exe c:\ "d:\my backup" /e /R:1
This will copy the entire c drive to the my backup folder, the e switch specifies every file and subfolder, and the R:1 specifies to retry once if the file is unreadable.
Also, if you wanted to run an auto-backup, all you would have to do is put the first robocopy command into a batch file, and create a task that calls it (via task scheduler in control panel) to run every interval you specify.
If, after backing up an entire windows xp system drive, you wanted to restore it from the usb drive, all you would have to do is run:
Robocopy.exe "D:\my backup" c:\ /e /R:1
Then, boot from the windows xp installation cd, go to the recovery console and run:
The only downside i can think of is that you would need a second computer or bootable environment to perform the copy back to the system drive.
bob1029 is offline
post #18 of 22 Old 08-16-07, 08:24 PM
mechman's Avatar
Here's a couple more free options:
GoodSync - it's a data synchronization tool. I use it with a 2GB thumbdrive to back up "My Documents" folder - works great! A lot easier to use than my old drag and drop.
Mozy - Online storage - 2GB or less is free. Unlimited storage for $4.95 a month. You do need a high speed connection.
mechman is offline
post #19 of 22 Old 08-28-07, 07:17 PM
Posts: n/a
I've used backup software for many years. I started with "ghost" which worked very well but I've always found it clunky and too geeky for most people. So I searched for a better/easier utility and found Acronis True Image. This is so simple to use and other can easily follow the process to backup. Even better I enable "auto" backups and let the software do the work.
Ghost still is an excellent product but is more for the admin's! This can really be seen when you have to recover you're system drive and boot to their dos based utility which is a different animal altogether. True Image, on the other hand looks and acts the same whether in windows or off the boot disk, thanks to "linux".
I've tried backup drives and found them good but not all are created equal. Make sure you do your homework first. Some have software that must be installed before you can use them and make sure that your motherboard supports USB booting or getting back your boot drive may be a hassle!
If data backup is all you want then MS's own backup utility will work but is "lame" otherwise. However the new Vista backup is much improved but I haven't played with it that much!
All the suggestion above are workable, you just have to decide your requirements and budget. Just make sure you do "backup" your most important info and get it off your pc! DVD-R, CD-R, web or an external/extra hard drive are easy and inexpensive ways to ensure recovery and protection.
post #20 of 22 Old 08-28-07, 07:24 PM
Posts: n/a
The segate backup software is a "lite" version of Acronis True Image 10 and can be downlaoded for free off their website!
backup , computer , software
