Hearing a noise from PC - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 12 Old 02-05-11, 04:28 PM Thread Starter
ghost rider
Yesterday I became aware of a low frequency noise. It was very subtle and hardly noticeable. This is in my equipment room. I canít say I ever noticed it before. The strange thing is it was completely in auditable when I am sitting at the computer when I stand up I could plainly hear it. Itís kind of like a ground loop but has a lower frequency.
It took me while to isolate it. Thought it might be the furnace running or the refrigerator in the kitchen. I turned on and off the PC. That through me off because it didnít come on when I first turned on the PC and would keep running after I turned off the computer. I put my ear to the PC and cycled it on and back off perhaps 5 seconds after it on the HD would spin up[ and after I shut it down it would keep spinning for at least 5 second. I figure it ran till all the power had drained from the power supply.
At first I thought it was interesting how the sound was in auditable at 40 inches from floor but plain at 60 inches. Then I started thinking this may be the first sign that a drive is going bad. So I posted a thread to get some thoughts.
ghost rider is offline
post #2 of 12 Old 02-05-11, 04:44 PM
Moderator Emeritus
Re: Hearing a noise from PC
Sounds like this can mean the drive is beginning to have problems, or it could simply be a sound that has always been there and you just never noticed it before. Once you do notice something like this there is no way you can pretend not to hear it. It's like noticing a scratch on a TV or monitor; after you see it your eye will always be drawn to it.
Hard drives are mechanical devices and as such it's only a matter of time before they fail, never a matter of IF they will fail. ALWAYS have important data backed up to at least one other source, and preferably more than one. If you don't you WILL eventually lose that data. I think we have pretty much all "been there, done that".
Harpmaker is offline
post #3 of 12 Old 02-08-11, 04:26 PM
Also check all the fans in the unit, when the ball bearings burn out they produce a similar sound.
But the hard drive would be the first place I would look.
ISF Certified, HAA Trained, THX Installer I, Crestron Level II programmer, URC and RTI trained.
And various others but too much to list.
nholmes1 is offline
post #4 of 12 Old 02-08-11, 09:25 PM
Zeitgeist's Avatar
I'd disconnect the hard drive, see what happens.
Honestly.... I've never heard a low frequency noise from a hard drive. Normally when the bearings start to fail, it's a nasty high pitch whine. Although, I've heard some odd vibrations from the hard drive causing the case to resonate... But the drive itself was quiet.
I'd be more inclined to suspect a fan. Especially a mainboard or CPU fan - since they tend to be smaller and more likely to clog and act up.
Zeitgeist is offline
post #5 of 12 Old 02-09-11, 10:14 AM Thread Starter
ghost rider
In reply to the last 2 responses, I originally thought it must be a fan but what was weird and made it interesting is how I could hear the fans turn on and off instantly as turn it on and off. The noise was delayed 5 to 10 seconds both turning it on and off.
When I put my ear up to the case I hear the drive spin up seconds after I power it on and continues after I turn it off 5 to 10 seconds.
I plan to open it up and isolate the exact sound and if itís a drive I will made sure its backed up.
post #6 of 12 Old 02-09-11, 01:41 PM
HTS Senior Moderator
nova's Avatar
I agree with the others. Typically a HD does not emit low frequency noises, fans with bearing issues do.
Your 5-10 sec delay also makes me suspect that a fan is the culprit. When you start your PC the CPU is room temp, most computers control CPU fans by temperature so the CPU fan will not usually ramp up to full speed until told to do so. Depending on your computer and how its set-up most fans (CPU, GPU, North Bridge, case, PSU) are temperature controlled by the BIOS or some other program (Q-fan, Core Center, Easy Tune,Speed Fan etc.), thermistor, linear voltage regulation, pulse-width modulation and on and on and on.
nova is offline
post #7 of 12 Old 02-14-11, 10:05 AM
Did you check for any critters in the computer??
Haha, Just kidding of course.
iconrl is offline
post #8 of 12 Old 02-14-11, 11:06 AM Thread Starter
ghost rider
LOL I should check.
I'm not to worried mostly I thought it was very wierd how the frequency just hangs there in a specific part of the room. Besides worst case I have to reprocvess about 16 BD movies.
post #9 of 12 Old 03-04-11, 02:10 PM
peterselby7's Avatar
could be dust on a fan... I've had that send cooling fans off balance and cause vibrations.
peterselby7 is offline
post #10 of 12 Old 03-06-11, 10:35 AM
BoredSysAdmin's Avatar
Like what other said - clean the dust of the fans first, possibly you need to replace them is cleaning doesn't solve the issue. You can stop each fan individually to troubleshoot which one is noisy.
BoredSysAdmin is offline
hearing , noise
