Creative Sound SolutionsDiscuss Modelling an SDX15.... in the DIY Speakers | DIY Subwoofers forum; Modelling an SDX15.... Got some 20" sonotube and 6" PVC for the port and I plan on getting an SDX15 coupled with a ... |
Views: 503 - Replies: 22
| Modelling an SDX15.... Got some 20" sonotube and 6" PVC for the port and I plan on getting an SDX15 coupled with a BASH500. Want to dig as low as possible and this is 100% home theater (Blu-ray). Was thinking around 400L, but there is NO WAF, so can go as big as I want..... Ideas? | ||||
| | #2 | ||||
| Re: Modelling an SDX15.... 400 liters would be as big as you'd want to go. You won't gain much in a bigger size. The Bash 500 would need the Hi-Pass filter set to 13.9 hz as shown in the boost table documentation. Maximum air speed is 29 m/s with a 6 inch port 19.5 inches long. You should flare the ends with MDF "doughnut" rings. ![]() We're all in this together! Members DIY Subwoofer Database Enclosure Volume Calculators Driver Wiring Diagrams | ||||
| | #5 | ||||
| Re: Modelling an SDX15.... If low end output is what you're after for HT then 400 liters tuned to 15 hz works well. How big is the room? We're all in this together! Members DIY Subwoofer Database Enclosure Volume Calculators Driver Wiring Diagrams | ||||
| | #6 | |||||
| Re: Modelling an SDX15.... Quote:
| | #7 | ||||
| Re: Modelling an SDX15.... 400 liters to 15 hz give you the most SPL at 20 hz and under. Is the room sealed off from other areas? We're all in this together! Members DIY Subwoofer Database Enclosure Volume Calculators Driver Wiring Diagrams | ||||
| | #8 | ||||
| Re: Modelling an SDX15.... Yep, one door on the right side, but it is closed during movies. | ||||
| | #9 | ||||
| Re: Modelling an SDX15.... You'll do just fine with this setup. We're all in this together! Members DIY Subwoofer Database Enclosure Volume Calculators Driver Wiring Diagrams | ||||
