Just having fun with my new found skill: picture insertion and url linking. I have started a build thread now that I'm almost finished ( who's got time while there's work to do?). It is
http://www.hometheatershack.com/foru...d-journal.html and includes a plan of the room and location of the planned Trio12 horn loaded subwoofer. Mark advised earlier that loaded horns like corners, in fact use corners to their advantage. That's handy since a cabinet like that really only fits in corners in most theaters. I would naturally want to face the horn opening towards the seats as if coming from the front. Does that make sense, or should I think about facing it sideways? Remember that my sealed 10" subs will move to the front eventually and face the seats as well. I want to avoid creating a suck out problem, and I already have some wierd nulls and peaks because of the room dimensions( I think). When I first set up the equipment in the room I had the 2 10" subs on the side wall mid points facing towards each other, and there was basically no bass in the room ( and lots on the other side of the basement 30 feet away!)
Thanks for your interest and comments...
Quick side question...how do I make my url link into a word like " here " or " there"?
