Hi
I have a Thorhauge tube preamp.
And want to fit a Goldpoint attenuator V24C Custom.
The Thorhauge have a 100ohm (0.1K) potmetre with stepmotor.
I want to take away the motor and fil the Goldpoint.
If I divide 100ohm with 23 I get 4.3ohm. Not easy to find resistors 100 95.7 91.4 87.1 ..........
So can I use the value from 100ohm to 1ohm in normal value and get a 18 step atteuator?
Some ide of good resistors to use?
Best regards
Frank
Best regards
Frank
