Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Service and Support > DIY Repair and Maintenance
Bad convergence chips: Is it possible resistors aren't affected?
Discuss Bad convergence chips: Is it possible resistors aren't affected? in the Service and Support forum; Bad convergence chips: Is it possible resistors aren't affected? Is it possible NOT to have burnt/open resistors when a STK goes bad? The BV channel stopped working on my ...
Views: 850 - Replies: 2
Old 10-19-08, 11:55 PM   #1
Alias: DaveG
Loc: Parma OH
User: #27273
Since: Oct 2008
  Dave610 is offline
Is it possible NOT to have burnt/open resistors when a STK goes bad? The BV channel stopped working on my set, resulting in severe vertical pincushion of the blue.
I'm about to order the recommended STK394-160's for my 8 yr old Pioneer PRO610HD, and decided to check all the output resistors on the conv. amp, by desoldering one end of each. All checked out okay, some maybe .1 or .2 ohm out of tolerance (the meter I used doesn't have a zero-adjust option, so I had to subtract .3 ohm from actual reading.) No problems with soldered connections, apparently this board was repaired at one time (service company swapped boards under warranty for non-related issue), key solder points look great. All components on conv. amp and digital conv. boards look brand-new, nothing obviously wrong. BTW, can't seem to find any pico fuses on this set so far.
Thank you for your response.
Old 10-20-08, 02:05 AM   #2
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
Re: Bad convergence chips: Is it possible resistors aren't affected?
Yes, it is quite possible to have a bad IC and all of the resistors undamaged. In fact, on the Pioneer sets this is not unusual. IIRC, the convergence supply fuses may be glass fuses on that set. Just be sure to check the resistors with the ICs removed and the yokes disconnected.
Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for.
Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information.
Old 10-20-08, 12:46 PM   #3
Alias: DaveG
Loc: Parma OH
User: #27273
Since: Oct 2008
  Dave610 is offline
Thanks lcaillo, I can now go ahead and order the Hitachi kit X480293 (X480295 appears to be out of stock at Tritronics). Thank you so much for sharing your knowledge, especially the convergence thread. Can't tell you how much I appreciate the info, our local service company would probably charge about $800 to swap boards - they want $130 just to turn on the set and look at the screen!
« Home Theater Shack > Service and Support > DIY Repair and Maintenance »
affected?, aren't, chips:, convergence, resistors
