Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Service | Support > DIY Repair and Maintenance
  Discuss Connecting Dual Torroidals in the Service | Support forum; Connecting Dual Torroidals Not sure if this is the right place to post this but I figure people with their noses in this ...
Views: 382 - Replies: 5
Old 02-04-09, 12:32 AM   #1
Alias: Brian
Loc: Auckland, New Zealand
User: #15579
Since: Jan 2008
  Pancakes is offline
Not sure if this is the right place to post this but I figure people with their noses in this forum will know the answer to my question.
I'm building a power amp and am stumped with the Torroidals. There are 4 outputs (split centre tap), that mush is easy. Both the inputs are orange and I want the ripple to be in phase on both L and R channels.
I'll be splitting the mains AC after the first fuse > L and R Torroidals > 2 x 35A 400V bridge rectifiers/channel (One will supply +V rail the other -V rail, the unused connections will be joined then run to ground.
I'm picturing that if I connect one of the cores up different to the other that it will reverse the 0V and +V secondaries too? I have access to an oscilloscope to check the output phasing (is it even phasing?).
Thanks in advance! Brian.
Old 02-04-09, 02:21 AM   #2
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
Re: Connecting Dual Torroidals
Not sure what you mean exactly by "connect one of the cores up different to the other " but you may find some help here:
http://www.electro-dan.co.uk/electronics/wiringtrans.html
...the soulshine, it's better than sunshine. It's better than moonshine. It's sure better than rain.
Old 02-04-09, 04:53 AM   #3
Alias: Brian
User: #15579
Since: Jan 2008
  Pancakes is offline
So each of my transformers is like the 230V single primaries/series secondaries illustration on the site you linked to (the bottom left of the four. The question is that I have two of those and am worried that if I hook one of them up as shown but the other with the primaries reversed (mine are both orange on each core so no live and neutral markings to indicate the start and finish of each primary winding). Does that mean that the +V and 0V of the secondary pairs (in the illustration red/yellow and blue/grey) will be reversed also or will it not matter after the rectifiers anyway?
Old 02-04-09, 11:42 AM   #4
lcaillo's Avatar
User: #328
  lcaillo is offline
Changing the polarity of the primary does not affect the d.c. output of your rectifier circuit. The orientation and relationship of the rectifiers and filters determine the polarity of the d.c. output.
Old 02-04-09, 11:43 PM   #5
Alias: Brian
User: #15579
Since: Jan 2008
  Pancakes is offline
Yeah that finally came to me as I was going to sleep. Now I get it I can't beleive I got stuck on that! I guess doing stuff with 12vDC forever and no AC has bunged me up. How embarressing to have asked that and thanks for the polite reply!
Old 02-05-09, 06:09 AM   #6
lcaillo's Avatar
User: #328
  lcaillo is offline
You should not be embarrassed at all to ask. We all get a bit mixed up on basics every now and then. The discussion may help someone else understand how transformers and rectifiers work.
« Home Theater Shack > Service | Support > DIY Repair and Maintenance »
connecting, dual, torroidals
Bookmark and Share
Dish Network
