Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Service and Support > DIY Repair and Maintenance
Free HK Service Manuals
Discuss Free HK Service Manuals in the Service and Support forum; Free HK Service Manuals It seems that Harman Kardon has their service manuals (not just owner's manuals) on the internet, although they don't post ...
Views: 3063 - Replies: 4
Old 10-20-06, 01:04 PM   #1
Alias: Aaron
JorgenMan's Avatar
Loc: Albuquerque, NM
User: #2040
Since: Aug 2006
  JorgenMan is offline
Lightbulb HK Service Manuals available for download
It seems that Harman Kardon has their service manuals (not just owner's manuals) on the internet, although they don't post links to them. Here's how I found mine (an AVR40):
Go to the HK website, http://www.harmankardon.com/, and go to the support page, where you find the link to the owner's manual. For example, mine is:
http:// manuals.harman.com/HK/Owner%27s%20Manual/AVR40%20om.pdf
Note that I've put a space at the beginning of the URL so the forum software won't turn it into a link. To find the service manual, replace the "Owner%27s" (Owner's) with "Service", and change the end of the filename from "om" to "sm". Talk about a lucky guess!
To continue the example, my service manual is found at:
http:// manuals.harman.com/hk/Service%20Manual/AVR40%20sm.pdf
The two differences are the subdirectory ("Service%20Manual" instead of "Owner%27s%20Manual"), and the end of the filename ("sm" instead of "om"). Of course, I can't guarantee that all HK products will be there, but I did test out the HK3380, a current HK receiver, and voila - there it was! Thanks to this trick, I was able to figure out what the problem was with my receiver, and didn't have to spend hours tracing signal paths.
Old 04-24-08, 04:13 PM   #2
Alias: Ben
Loc: Pinawa. Manitoba
User: #739
  Bent is offline
Re: Free HK Service Manuals
I have a AVR 525 reciever, I am able to locate a owners manula, but not a service manual for mine this way.
Mine has some display lights that don't eliably stay lit - I'd like to fix them.
Old 08-18-08, 11:00 AM   #3
mamisano
Inactive
Alias:
User: #
Posts: n/a
Lightbulb Re: Free HK Service Manuals
Bent wrote: View Post
Bent, I have the same receiver and I am experiencing problems as well.
Try this link, it worked for me: http:// manuals.harman.com/HK/Service%20Manual/AVR525%20sm.pdf
(remove the space before manuals)
Old 08-22-08, 12:22 AM   #4
Alias: Ben
User: #739
  Bent is offline
thanks a million - it worked.
Old 10-24-09, 01:00 PM   #5
New Member
Alias: marco
User: #43793
Since: Oct 2009
  marco1104 is offline
Hello, I'm looking for service manual AVR 255, this isn't work for this model, please help me.
« Home Theater Shack > Service and Support > DIY Repair and Maintenance »
