Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Service | Support > DIY Repair and Maintenance
  Discuss replace projector lamp with led lamp how to DIY in the Service | Support forum; replace projector lamp with led lamp how to DIY Has anyone ever tried to or heard of a how to replace a projector lamp with a led lamp?...
Views: 1145 - Replies: 4
Old 11-06-09, 01:35 PM   #1
New Member
Alias: esoterikest
Loc: Queens, NY
User: #44397
Since: Nov 2009
  esoterikest is offline
Old 11-06-09, 02:10 PM   #2
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
Re: replace projector lamp with led lamp how to DIY
There are lots of potential issues with this, not the least of which is the difference in color spectrum between the two types of light sources.
...the soulshine, it's better than sunshine. It's better than moonshine. It's sure better than rain.
Old 11-07-09, 03:11 AM   #3
Alias: Krankshaft
User: #19570
Since: Apr 2008
  Krankshaft is offline
Issue 1: Bypassing the ballast UHP lamp power supply for the projector since the mainboard on most projectors won't even power up if the microcontroller doesn't detect a sustained arc (and light) from the UHP lamp.
Issue 2: Schematics aren't provided for most (computer projectors which I guess is what you're talking about) which would require some reverse engineering to achieve Issue 1 (time consuming).
Issue 3: High lumen output LEDs would be extremely expensive. Also high output LEDs need cooling for the dies just like UHPs do. If you've ever owned a high powered LED flashlight you'd see the heat the dies generate at only a few watts.
Issue 4: Hotspots you would probably have to use an array of LEDs to achieve enough light and without a proper reflector and lenses to bring the separate light sources into convergence with each other you would have sunspots all over the projected image brighter at the center and dimmer on the outside edges of the individual LEDs.
Issue 5: Light output temperature the projectors DLP color wheel or the diachronic color filters in an LCD projector are designed for the color temperature of a UHP lamp. A different temperature from the LEDs would cause colors to be off not to mention the temperature discrepancy of the separate LEDs in the array.
There are many other issues but these are the main hurdles I can think of off the top of my head. Suffice it to say this isn't a weekend project.
Optical trains are designed around the characteristics of the light source which is what makes this such a challenge.
I know UHP lamps are expensive but they are difficult to manufacture and most of them are still handmade by glass blowers and skilled craftsman so that adds into the cost. Not to mention the precision alignment equipment needed to position the arc tubes in the reflector properly.
Old 11-10-09, 03:44 PM   #4
Alias: Mike
Loc: Sacramento, CA
User: #20692
Since: May 2008
  tiggers97 is offline
I wish it were true. But I think LED's, as nice as they are, are still far away from being economical options for home theaters for the masses.
Old 11-13-09, 06:19 AM   #5
Alias: andy summers
Andysu's Avatar
Loc: United Kingdom
User: #20513
Since: May 2008
  Andysu is offline
It would be nice for it to work and cut/reduce wattage and extended life of the light/bulb as replacing a bulb for most video projectors isn’t cheap. That’s why I use my widescreen Panasonic CRT mostly for regular viewing and the LCD video projector for new film DVD/Bluray usage.
So I shouldn’t be replacing my bulb till around late 2010 since I only brought early this year second-hand with new bulb that the owner installed before selling it.
I have seen an LED video projector at Maplin Electronics for £120.00 pounds not sure if the specification is high enough for average fair robust quality?
70mm was regarded as the Rolls Royce of picture and sound in its day.
« Home Theater Shack > Service | Support > DIY Repair and Maintenance »
lamp, projector, replace
Bookmark and Share
Dish Network
