| | 01-31-10, 03:13 PM
#1 | | New Member Bob | | Since: Jan 2010 |
| | | | Recommendation for oscilloscope requirements I’m about to start the replacement of the convergence ICs on an older Panasonic RP-HDTV. As part of the repair, I was looking to acquire an oscilloscope for this and other electronic troubleshooting project. I have the service manual for the RPTV that shows various waveforms at other test points on the boards.
I have searched for a couple of hours, but have been unable to find multiple sources about what would be the general bandwidth reqts for a suitable oscilloscope to verify the convergence IC repair and general TV troubleshooting? The only thing I have found is:
>>>> Basic requirements are: dual trace, 10-20 MHz minimum vertical bandwidth, delayed sweep desirable but not essential. A good set of proper 10X/1X probes. Higher vertical bandwidth is desirable but most consumer electronics work can be done with a 10 MHz scope. A storage scope or digital scope might be desirable for certain tasks but is by no means essential for basic troubleshooting.
Is there a general formula that should be used for this situation? E.g. the HDTV rates at maximum are 1920x1080 pixels/frame, 60 frames/sec, ????/pixel => yyy Mhz in a oscilloscope to adequately troubleshoot.
Bob | | | Advertisement | | | | | 01-31-10, 08:17 PM
#2 | | Shack Administrator Electronics Tech | | Since: May 2006 Gainesville, FL, USA My Photos |
| | | | Re: Recommendation for oscilloscope requirements For convergence and deflection circuits you can get by with virtually any scope, as the rates are in the kHz. For signal related work I would want 60mHz or better for analog, and a higher bandwidth storage scope for serious digital work, though I doubt that you will be doing much of either.
"I attribute the little I know to my not having been ashamed to ask for information, and to my rule of conversing with all descriptions of men on those topics that form their own peculiar professions and pursuits." John Locke Leonard Caillouet MS, CET, MST, ISF
ISCET, NESDA, ISF Forum Library Member
Need electronics repair? NESDA is the organization for the most professional servicers in the USA and has a great place to start looking for a shop in your area: http://www.tvrepairpros.com/ | | | 02-04-10, 09:00 AM
#3 | | Shack Moderator Greg | | Since: Nov 2007 NY My Photos |
| | | | Re: Recommendation for oscilloscope requirements Len, do you have, or know anyone who has, experience with the USB scope devices, such as the DSO-2090? -Greg
Don't worry... nothing new here, I've already made that mistake. Trust me. | | | 02-04-10, 06:42 PM
#4 | | Shack Administrator Electronics Tech | | Since: May 2006 Gainesville, FL, USA My Photos |
| | | | Re: Recommendation for oscilloscope requirements They have very limited bandwidth and I would be careful about ground loops and voltage limitations, as well as the low resolution. I have one but its use is limited.
Need electronics repair? NESDA is the organization for the most professional servicers in the USA and has a great place to start looking for a shop in your area: http://www.tvrepairpros.com/ | | | 02-04-10, 07:55 PM
#5 | | Shack Moderator Greg | | Since: Nov 2007 NY My Photos |
| | | | Re: Recommendation for oscilloscope requirements I've seen other models with 100MHz BW and (I think) 2G sampling... I think they were still under $400.... any better options for a cheapskate? -Greg
Don't worry... nothing new here, I've already made that mistake. Trust me. | | | 02-04-10, 10:06 PM
#6 | | Shack Administrator Electronics Tech | | Since: May 2006 Gainesville, FL, USA My Photos |
| | | | Re: Recommendation for oscilloscope requirements I have not seen that kind of bandwidth that cheap.
Need electronics repair? NESDA is the organization for the most professional servicers in the USA and has a great place to start looking for a shop in your area: http://www.tvrepairpros.com/ | | | 02-05-10, 10:13 AM
#7 | | Shack Moderator Greg | | Since: Nov 2007 NY My Photos |
| | | | Re: Recommendation for oscilloscope requirements Well... I was wrong about the # of samples, but unless I'm missing something, the BW stands... this is what I've found for less than $400... granted, to get that price you have to buy on ebay form a source in China...
DSO2090, 40MHz, 100MS/s "realtime", 32K samples/ch
DSO2150, 60MHz, 150MS/s "realtime", 32K samples/ch
DSO2250, 100MHz, 250MS/s "realtime", 512K samples/ch
DSO5200A 200MHz 250MS/s "realtime" 1M samples/ch -Greg
Don't worry... nothing new here, I've already made that mistake. Trust me. | | | | |
