Audio General, Inc.: Great deals on projectors, screens and electronics. Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Power Sound Audio designs, develops, and assembles high quality loudspeakers and subwoofers for home theater environments. Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! OPPO Digital - Universal Network 3D Blu-ray Players - Buy Direct from the Manufacturer KEN KREISEL Sound & Design Genelec: Active Speakers and Speaker Systems Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices RAM Electronics: Audio, Video, Home Theater and Computer Cables. GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Check out the Woot product for today! Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! DIY Parts and Accessories as well as custom built cables. Fast worldwide shipping. Madisound Marantz Value Electronics: A trusted retailer and custom installer that specializes in whole-house audio, home theater, Plasma, LCD, LED, HDTVs, Blu-ray and more. Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! SVSound GR Research - Offering audiophile quality loudspeakerkits, high quality crossover components, drivers and accessories. Also providing a wide range of design services from complete commercial product line design to assistance with individual custom products and upgrades.
Home Rules Register Gallery Glossary FAQ
Room EQ Wizard
Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Service | Support > DIY Repair and Maintenance
Donations Reviews Vendors
Views: 729 - Replies: 9
Old 01-15-12, 03:15 PM   #1
Since: Jan 2012
  MiFor3 is offline
I started this thread.
Unhappy Mitsubishi WS-65711 - No Sound
Just replaced convergence chip in this rear projection TV and the picture is now great! Only problem is I have lost sound. Checked all connections and all is well. Tried two different AV sources and both Directv and DVD player provide an excellent picture but no sound. Both use separate connections so problem must be in TV not the source. Had excellent sound before I replaced convergence chip, now nothing! Any ideas on this?
Thanks,
Bill
Old 01-16-12, 10:01 AM   #2
HTS Administrator
lcaillo's Avatar
Tech Guru
Gainesville, FL, USA
My Photo Gallery
  lcaillo is offline
Re: Mitsubishi WS-65711 - No Sound
You likely pulled the connector to the speakers. Four pin connector near the front of the board IIRC.
"I attribute the little I know to my not having been ashamed to ask for information, and to my rule of conversing with all descriptions of men on those topics that form their own peculiar professions and pursuits." John Locke
Leonard Caillouet MS, CET, MST, ISF
Need electronics repair? NESDA is the organization for the most professional servicers in the USA and has a great place to start looking for a shop in your area: http://www.tvrepairpros.com/
Old 01-16-12, 05:17 PM   #3
Since: Jan 2012
  MiFor3 is offline
Thanks Icaillo,
That's exactly what the problem was. After I installed the repaired board I could not see that connector on the board and the wires with the 4 pin plug had dropped out of site so I completely missed it. Once it was reconnected all was fine with the sound and the picture was also looking good with the new chip. I surfed for a few minutes to thoroughly check things out and then I powered down the TV to reinstall the back panel.
But now I have a new problem, the TV will not power up. Right after installing the back panel and pushing the TV back in place it will not come on. Whenever I turn the power on, either from the remote or the front panel, the green light comes and I can hear the "click" and within 2 or 3 seconds it shuts off, by itself, with a "click". It does not stay on long enough to produce either picture or sound. I ran the front panel diagnostics and it returns error code "12" which is "Normal Operation, No Error Detected", per the Service Manual. I have performed a System Reset using the button on the front panel of the TV and have unplugged and replugged the TV, all with no resolution to this problem.
Any ideas?
Thanks, Bill
Old 01-16-12, 07:55 PM   #4
HTS Administrator
lcaillo's Avatar
Tech Guru
My Photo Gallery
  lcaillo is offline
Check your front panel control switches. Unplug the control panel and try using the remote.
Old 01-17-12, 06:33 PM   #5
Since: Jan 2012
  MiFor3 is offline
Well Leonard that did not work as the TV green light still came on for about 3 seconds and shut back off by itself just using the remote with the control panel unplugged. Any other ideas?
Bill
Old 01-18-12, 07:39 PM   #6
HTS Administrator
lcaillo's Avatar
Tech Guru
My Photo Gallery
  lcaillo is offline
It shuts off but you get a 1-2 code? Are you sure it is not a 2-1 code?
Old 01-19-12, 07:09 PM   #7
Since: Jan 2012
  MiFor3 is offline
Leonard, yes it was code 12, however, in my continued efforts to resolve this I checked the four green Pico fuses by unsoldering one side of each fuse and checking for continuity and they were all ok. After soldering the Pico fuses back in place I now get Error Code - 22 (Short Protect). Any other ideas?
Bill
Old 01-19-12, 08:03 PM   #8
HTS Administrator
lcaillo's Avatar
Tech Guru
My Photo Gallery
  lcaillo is offline
2-2 is a low voltage supply short protect. Check all of the low voltage supplies. By far the most common problem is the convergence circuit.
Old 01-19-12, 08:19 PM   #9
Since: Jan 2012
  MiFor3 is offline
Leonard,
Can you give me some detail as to where to check for the low voltage supply. Transformer? Also if the TV keeps shutting off will I be able to check this in the off mode?
Bill
Old 01-20-12, 05:02 PM   #10
HTS Administrator
lcaillo's Avatar
Tech Guru
My Photo Gallery
  lcaillo is offline
All of the low voltage supplies are marked on the circuit board at test points. The service manual may map out where they are, or you can refer to the schematic and find the filter caps for each supply and check there.
 Reply     Post New Thread     Back to Top of Page
« Home Theater Shack > Service | Support > DIY Repair and Maintenance »
mitsubishi, sound, ws
Bookmark and Share
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright ©2006 - 2013, Home Theater Shack, LLC.
OUR SPONSORS
Accessories4less
Audio General Inc
Chase Home Theater
Discount-Merchant
Emotiva
Epik Subwoofers
Exteris Audio
Genelec
GIK Acoustics
GR Research
HTD: Home Theater Direct
KEN KREISEL
Madisound
Marantz
MiniDSP
OPPO Digital
Power Sound Audio
RAM Electronics
Stereo Integrity
SVSound
Take Five Audio
The Audio Insider
Value Electronics
Visual Apex
The Sub Zone
OUR AFFILIATES
Abe's of Maine
Boston Acoustics A Series Speakers
Cables.com
Denon - Buy Direct. Free Shipping.
Electronics Express
Fluance
GamersGate
Harman
J&R.com
Shop for Harmony Remotes at Logitech
Shop MCM Electronics for Your Home Theater Needs
Musician's Friend Stupid Deal of the Day
Once You Know, You Newegg
Overstock.com
Parts Express: Your #1 Speaker Building Resource
Roku + Netflix = Instant Movies on your TV
Solid Signal Antenna Superstore
Sonos Wireless Music Player
SquareTrade Warranties
Vann's
vudu.com
Woot!
Zzounds
Abt Electronics
Best Buy
Butterfly Photo
Circuit City
DIRECTV
emusic.com
GameFly
HDtracks High Resolution Music Downloads
HP Computers
Klipsch
MarvelStore.com
Monoprice.com! Best quality products at the lowest price, Always!
Instantly watch from thousands of TV episodes & movies streaming from Netflix. Try Netflix for FREE!
OneCall
Buy Televisions at Panasonic.com
Paul's TV
SMS Audio
503327_Get Free Shipping At Sonic Electronix!
Sony
Super Media Store!
Velodyne
Official Shop of Warner Bros
World Wide Stereo
Epic 80 Home Theater Speakers
Search Engine Friendly URLs by vBSEO
