Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Projector Screens | DIY Screens > DIY Screen Developers Forum
household paint and mediums
Discuss household paint and mediums in the Projector Screens | DIY Screens forum; household paint and mediums Hmmm... I wonder what refracts?!?!?! Sorry! Back on topic now! mech...
Elite Screens
Views: 883 - Replies: 29
Old 12-31-08, 01:17 AM   #26
Alias: mech
mechman's Avatar
Loc: Empire Township, MN
User: #6446
  mechman is online now
Re: household paint and mediums
mech
Old 01-01-09, 02:36 PM   #27
Shack Moderator
Alias: custy
custard's Avatar
Loc: walsall, uk
User: #22494
Since: Jun 2008
  custard is offline
projector in the ceiling position!
a common setup for most home theaters
background:
projector just below ceiling
throw distance 14 feet?
no zoom appllied on lens of hd65
sitting position very slightly (1 foot) in front of projector
5:5:1 panel on left (n8.17), matt grey on right (n8.34)
camera set to black and white
room lighting only. matte grey is lighter as expected
100% white field with camera by projector - ie the ceiling position
100% white field camera at horizontal midline of panels
100% white field sitting/viewing position on axis
100% white field sitting in the worst seat of my setup (about 20 degrees from the middle of the two panels)
100% white field sitting position at about 30 degrees
100% white field sitting position at about 40 degrees
100% white field sitting positon about 45 degrees
100% white field at about 60 degrees. i had to move quite close to the panels as the side wall would not allow me to go further away.
100% white field at about 60 degrees from LHS
i only estimated the angles after the photos were taken so dont take them as exact.
i used a square piece of paper and folded it diagonally to give me 45 degress and again to give me 22.5 degrees. the paper was placed at the intersection of the two panels.
Old 01-01-09, 03:33 PM   #28
Shack Moderator
Alias: custy
custard's Avatar
Loc: walsall, uk
User: #22494
Since: Jun 2008
  custard is offline
Harpmaker wrote:
custard wrote:
Harpmaker wrote:
wbassett wrote:
custard wrote:
wbassett wrote:
One question I have is it the medium that's causing the gain or is the medium making the mix more translucent and the aluminum causing the gain... or more than likely a combination of the two?
exactly!
i am in the process of making two white panels. one with medium and one without. hopefully that will enlighten us.
if the medium is not producing gain, then the panels should have similar angular reflective properties.
If we can get the mix more translucent not only will it be a bit lighter it will also allow more of the aluminum to do it's thing and make for a brighter image with darker shades of gray.
I haven't done any testing with it yet, but I got a bottle of Golden Fluid Titanium White and Fluid Matte Medium today; I can now compare testing with those to what Custy is doing.
Background:
i thought that the medium was causing paint to lighten. this was down to me seeing a lighter reading of my 5:5:1 panel when comparing to the equivalent panel without the medium.
i have doubts now wether this is the case.
especially now that i dont see the same effect with the white paint panels. the opposite effect is being seen but on a very small scale.
i havn't spectroed the white panels yet as the they have only been drying for 12hrs.
if you guys remember from the the previous posts - my sample reading for the 5:1 without the medium was reading lighter than when it was painted on a panel.
if we were to use the sample reading and then compare this to the panel with medium added (5:5:1) then you could say it was darkening the mix slightly
we could also hypthesize that below a certain Luminance value the medium causes lightening and above that value it causes darkening.
the white panel readings later today should help us reach a conclusion.
ok sorry about the babbling on!
methodology:
two panels primed with 3 layers of white paint.
1st panel painted with matt 2 coats of diluted (20%) white paint.
2nd panel painted with 3 coats of diluted (15-20%)medium:matt white 50:50
projector by ceiling, camera set to black and white
medium:matt white 50:50 on the left, matt white on the right.
room lighting - the medium panel looks slightly darker.
100% white field, camera by projector.
100% white field, camera at middle of panels
100% white field, camera in seating position
20 degrees off axis, seating position
30 degrees
40-45 degrees
60 degrees RHS
60 degrees LHS
conclusion:
the medium is adding a slight amount of angular reflectivity but not to the level that is being seen when aluminium is added.
note that the medium panel does not beat the straight white matte panel in the angular reflective position.
when aluminium was added we see it beats its counterpart in the angular reflective position.
also the aluminium panel was qiute a bit darker than than its counterpart as opposed to what we have with the white panels.
the only other factor to eliminate is wether something else in the lumitec is improving performance.
i will try and locate a suitable base in a standard matte finish.
if the lumitec is providing the performance boost then you guys should have no difficulty matching a base up in lumitec colors. here in the uk i dont think i can do that.
I concur Custy, well done.
Old 01-02-09, 02:28 AM   #29
Shack Moderator
Alias: custy
custard's Avatar
Loc: walsall, uk
User: #22494
Since: Jun 2008
  custard is offline
the spectral readings after about 21 hours drying...
it seems that the matte medium is darkening the mix by a tad only. i wouldnt have thought it was anything to worry about.
the matte medium should cause the most change in hue with a light color and i dont see a big change.
i'll take another reading of them panels in a week and a month for changes.
Old 01-08-09, 03:24 PM   #30
Shack Moderator
Alias: custy
custard's Avatar
Loc: walsall, uk
User: #22494
Since: Jun 2008
  custard is offline
it seems the golden fluid matte medium is not changing too much after a weeks curing.
« Home Theater Shack > Home Theater | Audio and Video > Projector Screens | DIY Screens > DIY Screen Developers Forum »
household, mediums, paint
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
