| DIY Screen Developers Forum Mirror ExperimentsDiscuss Mirror Experiments in the Projector Screens | DIY Screens forum; Mirror Experiments Ericglo wrote:
I would give some pics, but I don't think I have enough posts. I joined this forum just ... |
Views: 1687 - Replies: 59
| | #51 | |||||
| Re: Mirror Experiments Quote:
![]() You can pad some posts here in order to post pictures. | |||||
| | #52 | ||||
| Re: Mirror Experiments Can we get mylar film at Michaels? When I search for it on the internet I get links which could be described as 'less than legal'. I don't want a big sheet. Just something small that I can adhere to the surface of something to spray. | ||||
| | #53 | |||||
http://www.mirrorsheeting.com/ It seems to be associated with hydroponics. | |||||
| | #54 | ||||
| Re: Mirror Experiments I'm just wondering if I can get it locally. I'll check around tomorrow or Thursday. I would think I could get smaller pieces at Michaels. I'm not sure if the samples would do or not. I'll check Michaels first and then we'll go from there. | ||||
| | #55 | |||||
You might try a Mylar balloon, should work if it doesn't have printing on one side. | |||||
| | #57 | ||||
| Re: Mirror Experiments I'm gonna check around some today to see what I can find. Otherwise I'm gonna take dougri up on his kind offer to send me some that he has sitting around. Richum - For what I'm intending to do a balloon wouldn't work. I want to adhere the mylar to half of one of my 2X4 hardboard panels. Then spray the whole thing at once to see what effect the mylar really has. Prof. - Now I just need to find a hydroponic store! There are a couple that come up in Minnesota. But none are close by. I've got a couple of fairly large greenhouses close by though so I'm gonna check there too. | ||||
| | #58 | ||||
| Re: Mirror Experiments You can probably get it from an online Hydroponic store..but you will have to specify that they roll it up and put it in a cylinder to post it.. Prof.. Home Theatre...the never ending story! | ||||
| | #59 | ||||
| Re: Mirror Experiments I ended up driving the 20 miles to get a 4'X25'X1mil roll of it. I think that should be enough. Has anyone adhered this stuff to anything? I'd like to cover half of each of my panels in mylar. | ||||
| | #60 | ||||
| Re: Mirror Experiments You might want to try reflective aluminum. MIRO-4 is 97% reflective, and it cuts out the depth issues. It's super thin, lightweight, and if you happen to have a fluorescent lighting manufacturer in your area you could probably get a sample to try for free with a little sweet-talking. They generally sell their scraps to aluminum recyclers and get a very small percentage of what they payed, so giving someone a small piece could be plausible. I managed a 1 year contract at a small national manufacturer that built a second plant here in gainesville and might be able to get my hands on some 2x4 sheets. They are generally cut to 4x8 out of the mill too. I know it's pretty expensive, but it's an option, and couldn't be worse than paying 100 dollars for a mirror. Obviously I have no idea how neutral the return would be, but it's something to consider. | ||||
| Bookmarks |
| Tags |
| experiments, mirror |
| Thread Tools | |
