Black Widow Ultra™ Development - Page 7 - Home Theater Forum and Systems - HomeTheaterShack.com
 1Likes
post #61 of 237 Old 12-09-13, 04:41 AM
Re: Black Widow Ultra™ Development
hi guys.
im new in this forum but i have followed BW topics long time ago.
i have a mitsubishi HC3800 (1300 lumens) projecting a 105" image from 3,50m, according to projector calculator this give me a image brightness of 18fl with a screen gain of 1.0, but i use it in low lamp mode.
after doing lot of research i start my plans to do a BW screen with new AA formula and a white mate paint. im from Portugal so i dont have easy acess to those paint you recommend as base and AA i bought from ebay.uk and postage is a bit expensive.
after i sand the wall, prime it and apply 2 coats of 4:1 white mate base/AA i get a beautifull uniform light grey screen, no roller mark, no hotspots, no nothing just a very smooth light grey paint.
after i power on my projector the image was amazing, white was very white and the image just pop up, with beautifull colours. compared with a white wall is a great improvement. my only tiny disappoint was the black color, i was expect have more improvement on black level compared with a white wall , the improvements are very visisble but i was expect a bit more like i see on some topic of BW using old formula.
my question is, if i instead using a white base use a grey base the black levels will be improved? as far i could check,using the new AA formula with a white base we get a much more light grey compared with the old BW formula right? what grey paint should i use to get a screen with about same colour of old BW paint?
i dont know if i can go with a much dark screen. with my projector specs/mount options can i use a grey base paint instead white?
im really very impressed with my BW screen, just try to see if i can get some more improvements
thanks you guys for all that work and research and sorry for my bad english
stryker is offline
post #62 of 237 Old 12-09-13, 08:48 AM Thread Starter
mechman's Avatar
Steve Mechelke -mech
stryker wrote: View Post
Yiannis may be able to help you better than either myself or harpmaker here. What paint brands do you have available? To get a BW Ultra™ similar to the original BW™, you would want the base paint tinted to Glidden Veil.
Yes.
Your English is fine!
mechman is offline
post #63 of 237 Old 12-09-13, 09:18 AM
mechman wrote: View Post
thanks for the quick reply
i can get any paint brand available from ebay.uk so i think i can get any brand that sell in UK.
in my country i can get paint brands that maybe you never heard, like Procolor, Cin, Robbialac, Marilina, Barbot right?
stryker is offline
post #64 of 237 Old 12-09-13, 12:55 PM
grinthock wrote: View Post
I apologize in advanced if this has been covered. Here in Canada I have access to AAA-F (new) no problem, but i'm trying to figure out the base paint.
We have Dulux location everywhere as well as some Lowe's and of course Home Depot locations.
The plan is to prime with Kilz 2, and then do a BW made with 00NN 53/000 "Veil" at a 4:1 Ratio
My question is around paint "BASE" is you look on the Dulux web site specifically for Canada, there are various options (again i'm not stuck with Dulux is Lowes if a better option)
http://www.dulux.ca/en/our-products/...terior-paints/ Diamond? LifeMaster? Glidden Ultra? I have read some people had different experience with Diamond specifically because of the way the TiO2 is in that product.
They list various base paints, and they all come in various sheens and types. What i'm looking for is what is the best recommended base and sheen type for a proper BW mix...
I did notice some people still using the "Valspar Ultra White Flat" base, but I noticed Eggshell mentioned? Many discussions of Snow and Veil and various grey versions - but just want to ensure again that the base is right.
After looking into all this (but i'm still looking for clarification only because others may also) I was able to pick up 2 x 16oz containers of AAA-F LOT 69 at my local Currys Art Supply here in Canada -- which means VUPE in 427-2 Bermuda Beige is what I need! --- that I know I can get.
grinthock is offline
post #65 of 237 Old 12-09-13, 01:58 PM Thread Starter
mechman's Avatar
I have very little experience with Dulux. I would stick to sheens that are less than Eggshell. Flat, Matte or Flat Enamels should work fine.
mechman is offline
post #66 of 237 Old 12-10-13, 04:24 AM
after you recommend glidden vail colour i did a quick search on this forum about it and exist lot and lot of people very very pleased with screens painted with that colour.
hope Yiannis pass here soon and recommend a place in UK that ship glidden veil to Portugal ( i hope such place exist) where i can buy it
stryker is offline
post #67 of 237 Old 12-10-13, 07:56 AM
HTS Moderator
Hi stryker!!
Is Benjamin Moore or Caparol being imported in Portugal? I 've never heard of these paints you mentioned but i 'll try to see if by any chance are connected to Vitex or Vivechrom (Greece's local paint brands). Usually local paints use franchising but the formula of the paint remains the same of some well known brand.
Yiannis1970 is offline
post #68 of 237 Old 12-10-13, 09:42 AM
Yiannis1970 wrote: View Post
Hi stryker!!
never saw those brands selling in Portugal , we dont have many brands here
i think i only need 1L of paint, so i dont mind pay some few extra € and buy from ebay.uk or any place that ship to Portugal.
unfortunately i search those brands on ebay.uk but didnt get much luck. get auto air fine-aluminium was already hard, only found one shop on ebay.uk that sell to here.
thanks
edit: i forget to say that Procolor brand have a machine that can mix colours and make specific code colours but i suppose the result vary from each machine
stryker is offline
post #69 of 237 Old 12-10-13, 02:10 PM
HTS Moderator
Can you ask them if they use NCS or RAL system?
post #70 of 237 Old 12-10-13, 02:38 PM
on Procolor page say this translated to english : "It is one of the innovative tools developed by procolor allowing the professional painter locate in seconds deseadolas color charts color 55/05, Renova, ACC Color Map, Ral and NCS II."
stryker is offline
black , development , ultra™ , widow
