DIY ScreensDiscuss Black Widow Beta Testers Needed in the Screens forum; Black Widow Beta Testers Needed My first post on HTS ;-), so hi everyone A little background about my self, I'm total newbie with PJ ... |
Views: 4580 - Replies: 101
| | #21 | ||||
| Re: Black Widow Beta Testers Needed My first post on HTS ;-), so hi everyone ![]() A little background about my self, I'm total newbie with PJ and DIY screens. I recently bought my first PJ - a refurbished HD65 for my basement (work in progress). Currently I'm using it temporarily in my living room area on my off white wall. I've got a free sample from Tiddler (super nice guys) to try his CIL based - AAAF BW clone and I found a little too dark when testing it on a piece of card board, however I love the blacks it offers. Tiddler suggested to try to add more white paint to the mixture, which I was going to do it. Then I came across C&S mixture by Harpmaker and as I was going to try it, he mentioned to me about your new mix almost ready for a 'world premier' ... From my understanding the performance would be somewhere between old BW and C&S? I hope the mixture will be rollable... So if you guys still need a testers and I would be able to use Behr paint (i.e. 1850) for the new BW Lite mixture, please shoot me a PM with what I need. Also I do not own a gun setup, so I will have to roll it. I live in Canada so do not forget I'm a little bit limited to the paints I get ![]() More info about my setup: Basement (mainly for kids to play, it won't be dedicated HT room) PJ placement: ceiling mount point Distance to throw: around 13' Screen size: 110" picture Screen type: primed drywall Borders: planning to use flat black paint Walls around: light colors (light green, orange or blue) Ceiling: white Window: one window on the side with blinds time: mostly evenings, so the daylight wouldn't be a problem Sources: SD DVD (using up converting DVD), HDTV (1080I) for some hockey games (lots of white ice surface) - sports, 720P/1080P mkvs movies if I bring my PC down... Future: Still undecided if I should get PS3 or built HTPC. TIA Last edited by clark17; 03-28-09 at 10:12 AM.. Reason: setup | ||||
| | #22 | ||||
| Re: Black Widow Beta Testers Needed Clark17, You have a Sherwin Williams and a Michaels nearby? What about Lowes? Are they not up in the Great White North yet? | ||||
| | #23 | |||||
| Re: Black Widow Beta Testers Needed Quote:
I've already picked up some paint at Michaels to try S&C #2 and a good Harpmaker did mention 'upcoming' BW lite mixture.... So here am I ![]() | |||||
| | #24 | ||||
| Re: Black Widow Beta Testers Needed | ||||
| | #26 | ||||
| Re: Black Widow Beta Testers Needed I guess you are right.... ![]() Anyways I should be able to sent/receive PMs now... TIA ![]() | ||||
| | #27 | ||||
| Re: Black Widow Beta Testers Needed Anyone else want to try out our latest N8 offering? Close up of the reflective particles: ![]() Next to my Black Widow Screen: ![]() | ||||
| | #29 | ||||
| | #30 | ||||
| Re: Black Widow Beta Testers Needed I'd be interested as I'm just getting ready to fab a screen for my 6500. I've been looking for a mix that is not as dark as some of the grays I have seen but still helps blacks a little. I have a sprayer also. I was planning on using the thrifty white from HD as a base. | ||||
