Epson 2040 - what paint should i use for screen - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 3 Old 08-09-16, 09:20 PM Thread Starter
New Member
Wall - Dark Gray
Ceiling - Black
Screen size - 140" (16:9), projector apprx 13ft from screen (ceiling mount)
No ambient light interference (basement). First row 14 ft. Second 19ft
Thanks in advance.
raj100 is offline
post #2 of 3 Old 08-19-16, 04:02 AM
Re: Epson 2040 - what paint should i use for screen
A flat, neutral white will normally be best in that situation, unless you personally prefer an overall darker image.
For white, I've been enjoying a painted and framed section of wall which used ColorPlace (brand) interior, flat, Light-Base. The gallon was around $10 at Walmart. I asked the person at the hardware desk to add 4ounces of white pigment from the tint-machine into the gallon can (also called 4Y of KX-tint), which helps make the Light-Base as bright and neutral-white as it can be.
This paint has a very flat finish (opposite of a glossy finish) which allows it to show an extremely crisp and clean image despite neither my paintjob nor my wall being perfect. It also managed to cover the previous near-black surface with only two coats (rolled on)..so that was nice.
If you decide afterward that you'd prefer a darker image that this white provides with the projector in Eco-lamp, the same paint is available in a light neutral grey such as "SnowField" or "OONN 72/000" which can simply be rolled on over the previous white surface.
Simple
, build in a day, takedown in an hour.
Ftoast is offline
post #3 of 3 Old 08-19-16, 01:57 PM Thread Starter
New Member
Thank you, appreciate your suggestion. Will try it.
raj100 is offline
2040 , epson , paint , screen
