Hello all, I am trying to do backlighting for my DIY screen. 161" diagonal I believe. I have a smart outlet that allows to turn on and off power from my phone. I have been looking at LED strips on Amazon but they all have remote with on/off button. I am wanting to setup backlight with turn on and off when power is supplied to lighting. Color hue changing preferred. I would settle for solid color blue though.
Are you planning to have this light on when watching movies? if so you dont want any other color than 6k otherwise your going to cause issues with the image quality and it will be a distraction not a help.
Are you planning to have this light on when watching movies? if so you don't want any other color than 6k otherwise your going to cause issues with the image quality and it will be a distraction not a help.
Can you explain further why I want 6K color(don't know what that is) over what mostly others are using for theirs? And note I;m trying to stay under $80 for backlighting.
You could buy extensions which I believe are about 3' each and about 30.00 each. I believe I have 5 extensions to surround my 92" screen. You would also need a Phillips Hue hub or starter kit with one. So it does get pretty pricey. I currently have about 20 of the lights, strips and bulbs and am very happy with them, but for the price, they had better last.
6K is a white light leaning towards a very slight blue color. If you use red or green or whatever other color and you have that on while watching movies it will cause eye strain and your brain will compensate for the color and then the actual image on the screen wont look as it should (whites will not look white etc)
Interesting. I will look into this. I have heard that any lighting behind would reduce eye strain. Which was mostly what I was going for, but thought color changing would be cool with it. But since thats not the case, I may abandon it.
Amazon has single color strips pretty cheap that wouldn't require a remote. I also saw some 6k and higher through amazon but at a higher price. Another affordable option would be led Christmas lights. I don't believe these options would be dimmable.
I install these SUPERNIGHT kits -( identical to the $300 kit Screen Innovations sells with thier screens) - it has solid red blue green and many colors in between... and is dimmable .. I have the solid blue on while Im watching my movies and its really nice... $49.00
Having it triggered by AC seems a bit over the top ... I use my URC remote to control mine on/off and all colors...If you want to have it triggered with 12v you can still get the XANTECH AC1 from Amazon as well...
The imaging science principles pertaining to human perceptual factors are seldom explained and frequently misunderstood, in both consumer video and less so in professional video. Surrounding a video display with the wrong viewing environment conditions will induce viewing fatigue for many people and/or distort the viewer's perception of the image. Here is an article that explains many of these principles: http://cinemaquestinc.com/ive.htm .
Best regards and beautiful pictures,
Alan Brown, President
CinemaQuest, Inc.
SMPTE, THX, ISF, Lion AV Consultants
"Advancing the art and science of electronic imaging"
I use the SUPERNIGHT 5050 series from Amazon ... Easily controlled with URC TOTAL CONTROL / iphone app... the good news is that TOTAL CONTROL will also operate your entire system...
I did a backlight on my screen too (not DIY though). I love it for showing off, but I never keep it on during a movie. Not sure what it is, but the backlighting looks good on my TV, but not great on my projector screen.
Related Threads
742.3K posts
170.9K members
Since 2006
