DIY ScreensDiscuss Black Widow PFG - the Discussion - Black Widow in the Screens forum; Black Widow PFG - the Discussion - Black Widow jegyed wrote: Wish I read this before I got to impatient and purchased a 5 gallon bucket of BlackJack at ... |
Views: 35282 - Replies: 710
| | #111 | |||||
| Re: Black Widow PFG Quote:
mech | |||||
| | #112 | |||||
| re: Black Widow PFG - the Discussion - Black Widow Quote:
| | #114 | |||||
![]() mech | |||||
| | #115 | ||||
| re: Black Widow PFG - the Discussion - Black Widow I say take it back to Lowes and get your money back, unless you were planning on using the other 632 ounces for something else , in which case keep it for that.I'm not really sure what you got. What does it say on the side as far as the product #? What I was using was just a general purpose water based aluminum paint. Mine is High Reflectance All Purpose Aluminum Paint #5168 Contains
How much did it cost? Here it's $55 for a five gallon bucket. "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | ||||
| | #116 | ||||
| re: Black Widow PFG - the Discussion - Black Widow The product is "BlackJack Aluminum Roof Coating #71" " The Best and Brightest etc..." I double checked and it is water based. The price at Lowes is $37.50, but the department manager told me that sales were slow so they were going to discontinue it at this store. He gave it to me for $17.00 to get rid of it, so taking it back is not much of an option for me. | ||||
| | #117 | ||||
| re: Black Widow PFG - the Discussion - Black Widow $17 wasn't that bad then. I do believe that has fibers in it too, maybe not though, I couldn't find #71 on their website either. Usually roof coatings do have other things in it in addition to just the binder, water, and aluminum. You might be able to find something that works with it, but honestly we would have no idea what to use as a base since we have no data on it. If it's anything like the other aluminums, you'll want to use a warm white, but I can't promise how it will turn out. Look at it this way, you have more than enough to play with until you find the right combination ![]() "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | ||||
| | #118 | |||||
| | #119 | ||||
| re: Black Widow PFG - the Discussion - Black Widow On another note, what is the difference between using aluminum flakes and the silver mica flakes that I have been using? I easily attained a neutral, or really close to neutral, paint mix with them. | ||||
| | #120 | |||||
Haven't seen teh topcoat yet though. I am a bit wary of it. But I also trust you. ![]() Personally I like your mix! And I even recommended it elsewhere to the lower lumen crowd. I think that CGiv and the Black Widow compliment each other nicely here! I think of CGiv as kind of a SILVER killer. Maybe we should move this conversation to the CGiv thread though! ![]() And I really really really will get around to testing gain. But first I gotta figure out how exactly. With my spectro that is. But Sunday is the Super Bowl and we have guests coming and I also have a 92" Elite Silver Frame screen sitting in a box in my office that I have to review. And then hopefully box it back up and give it away to a member. mech | |||||
