Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Home Theater | Audio | Video > Projection Screens > Screens > DIY Screens
DIY Screens
  Discuss Black Widow PFG - the Discussion - Black Widow in the Screens forum; Black Widow PFG - the Discussion - Black Widow benven wrote: It would be interesting to make up some PFG with the Auto Air Aluminum (AAA ) product. I ...
Views: 35366 - Replies: 710
Old 01-22-08, 03:12 PM   #61
Shack Moderator
Alias: Bill
wbassett's Avatar
Loc: Upper State NY
User: #6427
  wbassett is online now
Re: Black Widow PFG
benven wrote: View Post
It would be interesting to make up some PFG with the Auto Air Aluminum (AAA) product. I still have some left over. Although, I would have to use the Behr 4850 white paint as the base. This paint is awesome guys. I think it would be as good if not better than the other white paints you have tried. The good thing about using the AAA is it does help with spraying as it was designed to be sprayed. Just a thought, Or is that 2 thoughts?
Ben like mech said we're actively looking at this right now, and thanks for passing it along!
I called the company and this is basically the same as what I originally was using but mine ended up discontinued... which was aluminum, a binding material, and water. That's it.
I called Createx today and they said yup, that's all that's in the Auto-Air Aluminum.
Like you said, this is designed to be sprayed so a couple things right off the bat:
  • No need to strain it prior to being used.
  • Definitely sprayable
  • Will probably be able to be sprayed with a Preval Sprayer too for those that want to go that route
  • For those that want to roll, it will act as a natural thinner to latex paint and help it go down very smooth.
I do want to say before anyone runs out and buys this, we need to test it and find a base white that is more in like with our specs. We only did basic testing with the original because why waste time on something that was discontinued? We could have worked a base out but why? (In hind sight, if we had then this would be a simple substitute is all... but as they say hindsight is 20/20 right?)
So right now we know HE558 works, and we'll get an easier method out shortly but it will be the same method and performance, it won't be a total redesign or complicated method.
Old 01-22-08, 03:31 PM   #62
Shack Moderator
Alias: mech
mechman's Avatar
Loc: Empire Township, MN
User: #6446
  mechman is offline
Re: Black Widow PFG
wbassett wrote: View Post
And I'd like to add that the original aluminum paint pushed blue (I hate saying that but for lack of better terminology) with what we've mixed it with. That includes some of the blue deficient whites we've tried. So this may take us, and my pocketbook , a while to figure out!
mech
Gain Readings
Spectro Readings - not up to date but will be soon
Old 01-22-08, 03:47 PM   #63
Alias: Brian
Loc: Tewksbury, MA
User: #15852
Since: Jan 2008
  bidzer is offline
Re: Black Widow PFG
I was just @ Lowes to see what they had and all I saw was this in a gallon:
http://www.lowes.com/lowes/lkn?action=productDetail&productId=114462-29-5180-A-30&lpage=none
Old 01-22-08, 03:53 PM   #64
tradewinds
Inactive
Alias:
User: #
Posts: n/a
Re: Black Widow PFG
bidzer wrote: View Post
Yes, Home Depot also said they carry other brands as well as Ace. The problem will be the base white to use if one goes with another brand.
Old 01-22-08, 03:55 PM   #65
Alias: Brian
Loc: Tewksbury, MA
User: #15852
Since: Jan 2008
  bidzer is offline
Re: Black Widow PFG
I'm trying to see what's the recommended application to try this on? Plywood? Polywall? Wilsonart?
Old 01-22-08, 04:04 PM   #66
Shack Moderator
Alias: Bill
wbassett's Avatar
Loc: Upper State NY
User: #6427
Re: Black Widow PFG
Bidzer see post#52
Old 01-22-08, 04:45 PM   #67
Alias: Ben
Loc: The Hammer
User: #9890
Since: Jun 2007
  benven is offline
Re: Black Widow PFG
All good points. But, you need to be careful rolling this product. It does create bubbles when used in higher AAAaint ratio. Using it 3:1 may not be issue. I'm just passing along my experience. Good luck!
Old 01-22-08, 04:52 PM   #68
Shack Moderator
Alias: Bill
wbassett's Avatar
Loc: Upper State NY
User: #6427
Re: Black Widow PFG
I've rolled from 3:1 all the way to 6:1, even using the dreaded foam rollers and it's not that bad. Just go slow and take a little care and it's a breeze.
Old 01-22-08, 05:19 PM   #69
Chris Nitro
Inactive
Alias:
User: #
Posts: n/a
Re: Black Widow PFG
Hey guys, awesome job on everything that you guys come up with to make the best screen possible. I'm in the same vote as some others here in that the Henry 558 is unavailable in my area. I'm not sure how it works for buying the stuff online and shipping up here to Canada. I'm still a few weeks away from deciding what I want to do for the screen. I will keep up to date on this thread to get updates and if anything easier to get becomes available. Thanks again for the hard work guys.
Once I get the walls up and mudded I plan on putting on some coats of Kilz2 primer and setting up the projector. I will watch a week or two with just the primer on to get idea on final screen size that I want, then final option for screen paint.
Old 01-22-08, 05:57 PM   #70
Shack Moderator
Alias: Don
Harpmaker's Avatar
Loc: Central PA
User: #12848
Since: Oct 2007
  Harpmaker is online now
Re: Black Widow PFG
I notice that this is a fibered roof paint. I don't know if the fibers can be filtered out or not.
For whatever reason, none of the Lowe's stores in my area sell this.
« Home Theater Shack > Home Theater | Audio | Video > Projection Screens > Screens > DIY Screens »
Bookmark and Share
Dish Network
