Status
Not open for further replies.
Black Widow PFG - the Discussion - Black Widow
309K views 1K replies 132 participants last post by  Harpmaker
#1 · (Edited by Moderator)
Announcement​
Createx has changed the formula for AAA which may result in BW™ not mixing out neutral. At this time, we do not recommend using this formula unless you have some of the older AAA.
[img]http://i96.photobucket.com/albums/l190/wbassett/HTS/Logos/BlackWidowPFG3.gif[/img]
Black Widow PFG
What is Black Widow 'PFG'? It is a revolutionary way of making a screen the 'DIY' way.
Black Widow™ Wikipedia Page - contains formula's and other useful information.
***EDIT*** - adding the formula to the top of this post for easy reference - ***EDIT***
Black Widow formula
- One quart of Valspar Ultra Premium Flat Enamel (we call this VUPE frequently) tinted PPG (Pittsburgh Paints) 427-2 Bermuda Beige
- 8oz. of Auto Air Aluminum fine
Lowes, Home Depot, Menards, Sherwin Williams, Ace Hardware, Benjamin Moore and I'm sure many others can easily match PPG 427-2 Bermuda Beige. Just tell the counter person you'd like a quart of VUPE, or the flat enamel of your choice, tinted Pittsburgh Paints Bermuda Beige.
Auto Air Aluminum Fine may be found locally at auto paint stores or an airbrush supply store. If not, it's readily available online at Dick Blick amongst other places. Dick Blick runs out of the 4oz bottles quite frequently - like today for instance. What can I say? We created a lot of demand I guess. ;) You can google it for other online vendors as well.
Add the two in a separate pail and mix until they are blended thoroughly. The Bermuda Beige is just that, beige. When added to the aluminum it becomes a dead on N7.5 neutral.
This mix can be applied either by spraying or by rolling. Rolling should be at least two coats, spraying should be at least 6 coats.
One quart of VUPE gives you 100 square feet of coverage. That plus the AAA should give you at least three coats on a 100" screen.
Some pictures of the items you need:
Vaslpar Ultra Premium Flat Enamel tinted Bermuda Beige.
The Valspar Ultra Premium Flat Enamel paint has been renamed by Lowe's to Valspar Ultra Premium Super Flat Finish. The paint is the same so the existing tint formula will still work.
You can use Behr 1850 as well and the picture of the Auto Air Aluminum is actually a quart - not the two 4oz bottles you would need for a quart of Bermuda Beige.
I also tested PPG Grand Distinction Flat Enamel - of all the paints this one seemed the best for rolling. But I think it's only available at Menards - which is a much smaller chain than Home Depot and Lowes.
When rolling, use a 1/4" nap roller for less texture. Do not use a foam roller as they have been found to create more bubbles while rolling which can create concentrations of the aluminum when they pop. It's strongly advisable to set up a work light off to one side of the screen so that you can see the progress and avoid roller marks. Avoiding roller marks is essential but it's not as difficult to achieve as most make it out to be. Roll the screen like you would a wall and you should be fine. Before the paint has had a chance to dry go back over it down rolling each pass. Apply no pressure other than holding the roller on the wall. This will eliminate any roller marks.
Spraying should only be attempted after you are comfortable with your spraying equipment. If you have to spray and have never done it before, we recommend the Wagner Control Spray HVLP gun sold at several of the big box stores. The kit comes with a viscosity cup which helps you determine the amount of water to add to your mix. A general rule of thumb is that you add water, mixing it in before testing it, until the resulting mix runs out of the viscosity cup in 45 seconds or less.
It really is that simple! No mixing tubes of artist acrylics, popsicle stick paints, etc. using tiny little milliliter measuring implements. Just dump one 8oz AAA bottle or two 4oz AAA bottles and the quart of Bermuda Beige into a pail, mix it up and apply. :T
***End of edit*** - January 16, 2010
A very brief history of DIY painted screens and some of the more popular methods and mindsets:
For years the debate was White vs Gray. White is easy and the most forgiving. Of course the better balanced a white screen is the more accurate it will be, but unlike a gray screen White is more forgiving and can be off more and not be as noticeable as a gray screen that isn't a well balanced color. Still even with a white screen, the closer to D65 it is the more accurate it will be.
The same goes with gray screens, the closer they are to neutral the better and more accurate they are.
But what exactly constitutes a 'neutral'?
Good Question. There are many parameters but the main ones are the color balance (L*ab and xyY values), spectral curve, and color temperature.
For years many have tried to make the 'perfect' DIY screen. One that would perform with ambient lighting but also perform equally as well in a dark and dedicated environment.
One of the biggest problems and debates has been what exactly is gray? This has literally been debated for years and rather than explain it all over again the best thing is to refer to the neutral gray thread.
As good as a simple neutral gray is, there has always been a desire to improve upon things. The most popular way up until now has been by the use of mica (pearlescent) and poly coatings. The problem is mica by nature causes a color shift.
So how can we improve on a well balanced neutral gray without introducing color shifting that mica's and interference pigments are known to cause? By using non-interference pigments instead...
[MOUSE]PFG stands for 'Pigment Free Gray'. Granted anything added to a white based paint to change the color is technically a pigment, this is a gray that is not created by use of the standard pigments used in paint shops or by other DIY methods. Hence the original name 'PFG', or Pigment Free Gray.[/MOUSE]
It was found that by adding aluminum based paint (which is a water based paint comprised primarily of aluminum and no other colorants) a gray was created. Aluminum is a very bright and universal element. It has been used over the years as a 'silver' substitute, and has even been used for making mirrors. Needless to say it is very bright and reflective.
That and the fact that it is a non-interference substance it was a very interesting element. The results were astounding.
First let's look at one of the most neutral Off The Self neutral grays made the conventional way with various colorant pigments.
This is about as neutral as it gets with pigment based colorants. Look at the values highlighted in green. The color balance, temperature, and spectral curve all are well within our desired specifications.
Now let's look at what happens to that same ideal neutral when an interference material such as mica is added.
Quite a change from the neutral balance seen before, and this was with just one coating.
Next up is one of the most well known and popular DIY advanced screen methods.
Again a major change from our well balanced neutral reference.
Black Widow PFG is up next... First a 4:1 mix ratio using Sherwin Williams Luminous White.
It isn't dead on neutral but is a very close near neutral. Look at the spectral curve though, it's still very flat!
Next is a 5:1 ratio mix using True Value's Winter Mist, the same as the very first data graphic shown...
So what exactly is Black Widow? It is a gray made using Henry Aluminum roof paint added in the proper ratio to a common base paint. You can't just use anything, it has to be a water based aluminum paint so we went with Henry 558. The original material was a plain water based aluminum paint, but unfortunately it was discontinued.
What are the benefits? Well as the Spider says-
  • Better Blacks
  • Bolder Colors
  • Whiter Whites
  • Excellent performance with both ambient light and lights out dedicated setups
  • A brighter and more vibrant image without the color shifting problems caused by iridescence.
  • Sharper image quality and shadow detail
That's some pretty bold claims... seeing is believing though.
The center of the screen are the two original PFG test panels in a 3:1 and 4:1 ratio. To the left is a known performer, Sherwin Williams Gray Screen, and to the right is a generic general run of the mill N8.5 shade of gray.
SW Gray Screen was one of the Kings of Off The Shelf (OTS) grays that provided deep blacks, excellent color reproduction and very white whites. It's no contest between the two.
So PFG wins with blacks but what about color? Another good question...
Color reproduction is just as accurate but has a more vivid look to them. Here we can see that there is no discernible difference in color reproduction between PFG and a known performer. What the camera can't show is the depth and detail is much greater in the PFG screen.
The secret is the aluminum, but the key is not only the lack of color shifting that iridescence cause, but how uniform the aluminum is.
To the left is a PFG sample, to the right is a mica based application. The aluminum has a much denser and more uniform coverage as compared to the larger mica flakes. It's also very easy to see reds, blues, yellows, orange and other colors throughout the mica. That is a perfect example of uniformity and lack of color shifting.
What is really amazing is this is a darker screen but doesn't look dull or muddy like most dark grays look. The aluminum is the performance difference.
Lights out...
Lights on...
It was these tests that led to the current application that we are now ready to present... Black Widow PFG!
The next logical question is how do you make it and how do you apply it.
Making it is very simple. For a 4:1 ratio take 8 ounces of Auto Air Aluminum Fine and add it to a quart of Valspar flat enamal tinted to PPG Bermuda Beige, stir and apply. That will make 40 ounces of Black Widow
How is Black Widow applied? It's just like painting a wall. No special rollers or rolling techniques are needed. Just a good quality low nap roller. Prime the surface with a good primer, my primer of choice is Kilz2, but any good quality white primer will work. Mix up your Black Widow, and roll it on... it really is that easy. Stay away from foam rollers though. They sometimes cause bubbles to form and when the bubbles pop a bright spot is formed. If you see a bubble, don't panic, just roll it out and move on.
Coming up next are some actual Black Widow shots and even a first hand account of making a full size screen and how it performs.
#2 ·
Re: Black Widow PFG
Very interesting and very informative Bill...
This certainly appeals to me more than a straight grey screen..
But before I get too excited, none of the products you mentioned are available down here..
I will be most interested to see what you are able to find as alternative paints..
Would it not be possible to just add aluminium powder to a brilliant white base paint, to match what you have with your "Black Widow"?
#3 ·
Re: Black Widow PFG
Prof that is actually being worked on too. One of the problems with powders is they aren't typically a local item either, and then there is working out exactly how much equates to the same 8 ounces of HE558 or the previous PFG component. Needless to say 8 ounces of powder isn't the same as 8 ounces of a premade compound.
Plus I think it is very important to state that with the wrong type of aluminum powder, when added to water it can cause a very nasty reaction. So no, at this point in time we don't have any powders ready to be recommended. We're still testing in that area.
Performance and balance wise when we're done with that testing it will be the same and if we can make this even easier that's the goal.
A lot of people wanted to hear something substantial and we finally have some tested ways that we are recommending. Another reason for not just waiting for a powder based version is people started buying aluminum paint and I know some were getting solvent based and not water based. That's not going to mix or apply well with a water based latex so rather than people having a bad experience and walking away disgusted it was time to give the details along with our recommendations of what we found to work the best.
#6 ·
Re: Black Widow PFG
From what I've been told, there are heavy restrictions on importing any type of liquid into Australia..and requires a certificate to do so..and usually is only available to bulk importers..
I think I might have to make some direct enquiries myself...just to make sure..
#7 ·
Re: Black Widow PFG
Prof.,
I am working on situations such as yours and hope to have something soon! ;) I'm close but I don't want to say 'next week' or something like that cause I can never seem to meet deadlines I set for myself.
mech
#9 ·
Re: Black Widow PFG
Don't panic Prof, I have been experimenting with Resene products which is avaliable in Aus aswell.
I have been working on the resene range experimenting with filtering and was about to return to some developement work.(Home redecorating the house has held up hobbies).
They have an aluminium paint in their range, but I haven't been overly happy with the spectrums of the straight whites. Think I even have an old testpot of ali in the garage.
I can do a spectrum reading with my gear. I'll keep ya posted.
regards
#10 ·
Re: Black Widow PFG
Thanks Smokey Joe, but unfortunately Resene products are not available in SA..
I've already had the occasion to look for them when I was after their clear matt acrylic for the top coat on my Melamine screen..And they won't ship one can..
I may have to do my own experimenting on the aluminium side if nothing else comes up..
Edit..I take it that you were happy with the alum you have..just not the white paint..
#11 ·
Re: Black Widow PFG
Well......
I have this screen in action, have been for that last few days.
I think it's fabulous myself.
I could NOT find the Henry 558 locally, even though I went to their website and found local distributors, maybe you guys will have better luck, but I ordered it online after MANY hours of frustration....
It was pathetic.....
I have personally taken more pics than I care to mention, getting a really good screen shot(REAL, LIKE WHAT YOU REALLY SEE), is a nightmare in itself, ESPECIALLY on LIGHT backgrounds.....
Reason?
White Balance
White balance can take up a whole LARGE thread in itself, and be MANY pages in itself..
Alot of views will be LESS affected by this than others, but some shots are SEVERELY affected,I'm trying, and I have 2 cameras here......
Facts are this,
LARGE white areas look a bit bluish, I MUST get a Whibal, and even then it'll change per shot.
Like I said, WB is a big deal in regards to NON DOCTORED SHOTS.
ALL of the shots you see, are NOT doctored AT ALL, not touch-ups, etc.... is what it is (hopefuly!!).
There IS software available to correct WB on shots.... I think thats a VERY debateable subject,, but I know that it's WIDELY accepted for corporate,and sometimes HT shots..
I have NOT retouched any of my pics, although I could for the WB issue....
I just feel it's a bit weak, and REFUSE to do that. hence the problems I have stated..
Whatever.....
My Projector is a Panasonic AX100U, with over 1900 hours on it, so I USUALLY use he "NORMAL" setting, I think it's the 3rd from brightest, the pics shown are using that setting.
I don't lie, what you see is a FAIR, but NOT perfect rendition of what I see here, any questions LMK.
Pics to come...
#13 ·
Re: Black Widow PFG
I'd like to start out this post by saying that I've looked at and reviewed a lot of panels and paint mixes since coming on board here at the Shack, and this one is the best diy screen paint for ambient light viewing that I know of! There is another that I know of but benven hasn't released his formula yet for comparisons.
Shopping
What you're looking for is this:
And this is what it looks like when opened:
Application Notes
Some application notes that I'd like to add are that spraying is currently under review. Harpmaker agreed to beta test spraying for us and is still working on it. ;)
As for the nap of the roller I'd keep it 1/4" or less. I used foam rollers on my original test panels and had bubbles form to which Bill has alluded to the problems this can create. So stick with the 1/4" or less nap roller. I haven't had any trouble with panels created with these. Nor has our other beta tester, muzz, who has already replaced his screen with Black Widow!
Another item I'd like to caution folks about is handling the screen after it has dried. Care should be taken as we have seen some smudging. At this time it appears to be worse on screens that are sprayed. I had to create quite a bit of friction with my finger to create a smudge on my rolled screens. We're currently investigating a good topcoat that won't yellow over time and won't decrease the performance of the screen. I'm hoping to continue work on it this week. As of right now the Behr 780 matte polyurethane seems to work fine. However it has been known to yellow over time. I'm currently investigating proportions of Valspar Clear Coat Protectors in the flat and satin finishes to figure out which will work best. They introduce virtually no color shifting.
Musings
So I'm sure folks will wonder why 4:1 and 5:1? Why not 3:1? Well the 3:1's produced a very grainy picture and what appeared to be roller marks on the panel. While I'm not a painter by trade, I can assure you there aren't any roller marks. I believe it's just from higher concentration of aluminum. I've done some work on these and have gotten them straightened out. When it's finalized I'll add it to the top post and to the thread.
mech
#16 ·
Re: Black Widow PFG
Thing is, it works well in a dedicated setup too.
As I mentioned, aluminum has been used for many things, even mirrors, so it adds a highly reflective property without the color shifting we see with pearls and iridescence. We can make a darker gray that makes blacks look better but the highly reflective and uniform properties of aluminum let it remain a bright screen and able to produce whites and vivid colors that are typically reserved for much lighter shade screens. Blacks and brightness aside, it gives better detail and image sharpness as well as more depth.
I know I showed this screen shot before, but take a look at it again and look at the reds and orange's closer... they really come to life and have a vibrance and depth I haven't seen on any other DIY screen including the laminates I have tested.
I've used/tested a variety of painted and laminate screens and I will be replacing my own personal screen with one of these.
As part of that I will be documenting a screen build from the ground up. This screen will be just as unique and revolutionary as the Black Widow PFG paint that will be going on it. Right now the prototype is light enough that I can literally lift it (53"x93") with my pinkie. I am adding cross bracing to stiffen the frame up more and that will add some weight, so after adding the supports I'd say I probably will have to use my index finger instead of my pinkie ;)
In other words we're moving from the days of big heavy 60lb DIY screens and frames down to less than 20lbs, something Grzboken himself would be proud of ;)
So look for that to be coming in the next few weeks... the prototype worked, so now it's time to build the real McCoy.
#14 ·
Re: Black Widow PFG
I also want to reiterate that I can't smudge my panels without applying an abnormal amount of pressure and friction, so much that it would damage any screen except for a laminate screen. Rolling doesn't seem to be a problem and I just wanted to add that so people didn't think this was a problem even with a rolled screen.
Keep in mind any painted screen can be damaged with excessive scrubbing or abrasive cleaners. The only virtually indestructible screen that I know of and have personally tested (and I really mean I abused it! From freezing to soaking in water for days...) is laminate.
I will be spraying a screen very soon on the new light weight screen I am working on so we will get this working as a sprayed option.
#15 ·
Re: Black Widow PFG
A couple more spectral reflectance curves:
This one is of all three plotted in one chart
And then the original HE558 spectral curve
Also a big hearty :thankyou: to Smokey Joe for helping me with all this!
mech
#17 ·
Re: Black Widow PFG
Where to purchase
The place where muzz and I purchased our gallons was here.
Ace Hardware is supposed to be able to order it as well. Although Harpmaker's Ace said he would have to buy 4 gallons.
If you live in a warmer climate, it may actually be stocked on the shelves of Home Depot, Lowe's etc.
We'll add to this list as we hear of more places.
mech
#18 ·
Re: Black Widow PFG
I'll probably add to this a gazillion times over time! :bigsmile:
But another thing I want to add is that I never tried Winter Mist 4:1 or 6:1 ratios as all I had was less than a quart of Winter Mist and my True Value is a pain to get to. So I guess what I'm saying is that it would more than likely work. If you're willing to test it out let us know as I'd like samples to spectro! ;)
Another thing to note, and reason why I haven't tried it, is that the Lowe's in my neck of the woods are unable to match True Value Winter Mist. It's not in their system. It's in other Lowe's systems across the hemisphere. Just not mine. :foottap: I do have the formula for it and intend to pick some up once I find out the base to use for the formula given to me. :bigsmile:
mech
#19 ·
Re: Black Widow PFG
I think this screen does a good job with ambient lighting, here are a couple of shots..
Without light:
http://s168.photobucket.com/albums/u173/muzz1/PFG screen grabs/?action=view&current=IMG_1516.jpg
With 75 watt table lamp to the left of the camera- easy reading light:
http://s168.photobucket.com/albums/u173/muzz1/PFG screen grabs/?action=view&current=IMG_1517.jpg
This pic isn't too bad for a 1900 hr bulb:
This screen smokes my old Pebble Beach/2 x PTC
http://s168.photobucket.com/albums/u173/muzz1/PFG screen grabs/?action=view&current=IMG_1331.jpg :T
#22 ·
Re: Black Widow PFG
I went slightly different, my mix is Benjamin Moore Chantilly Lace, @ 4.5:1
This was an EZ job.
I mixed the 558 paint by hand (as specified by the label),and combined the 2 products the same way..
I used a 1/4" Nap roller
Piece of cake, awesome results.
#23 ·
Re: Black Widow PFG
muzz that biplane shot looks really good. You can see the individual rivits and that's some good detail to pick up from a projector and a screen shot. :)
#25 ·
Re: Black Widow PFG
Yeah, I like that pic, it is the EXACT frame shown elsewhere, produced by a MUCH more expensive setup.
My pic is by a AX100U Pannny LCD @ 720P, with >1900 hrs.
The one shown isn't overexposed, or blooming badly like the one it copied.
All folks need to do to compare the 2, is look at the blue sky above the pilots head to see what I am talking about.... the other pic is pretty much bright white, there is no blue sky.....
There IS a blue sky patch there!!
So obviously I had to be mindful of the contrast on that pic to show it like it really is... the other pic?
Well.. overexposed or blooming badly... I wasn't there to see.
#28 ·
Re: Black Widow PFG
Prof I will say seriously that there is some viewing cone so that means there is gain, but how much, we can't say right now until it's tested.
#36 ·
Re: Black Widow PFG
Great jobs guys and thank you. I assume an Designer White substrate will work for this or are you using something else that is better recommended? Thanks.
When I sprayed my Black Widow mixes the first time, I used some TWH (melamine coated hardboard); the second round I used regular hardboard that had been primed with Kilz 2. The Kilz 2 primed HB gives slightly brighter colors in my limited testing, but this could also be due to a change of spraying technique for that panel as well. The paint sticks to Kilz 2 MUCH better than to the TWH, and I would suspect the same would hold true for the laminate.
The bottom line is you can spray your DW if you want to. I don't know about rolling.
H.
G
#31 ·
Re: Black Widow PFG
wow, I checked all the places listed on Henry's site and no one around me here even know's about this manufacturer. If anyone plans on buying these in bulk and willing to ship, let me know. Thanks.
Seems the minimum is 1 gallon
#40 ·
Re: Black Widow PFG
Yep. We're not happy about that, but what can we do? We had originally thought that we could buy a bunch of this stuff and sell it at cost to members. But that opens us up to tax issues and a whole slew of other issues. However if someone were to buy a gallon, I'm sure they could find some folks willing to buy the excess from them at cost. You could always label it as BBQ sauce when you ship it! ;)
mech
#32 ·
Re: Black Widow PFG
It would be interesting to make up some PFG with the Auto Air Aluminum (AAA:bigsmile:) product. I still have some left over. Although, I would have to use the Behr 4850 white paint as the base. This paint is awesome guys. I think it would be as good if not better than the other white paints you have tried. The good thing about using the AAA is it does help with spraying as it was designed to be sprayed. Just a thought, Or is that 2 thoughts?
#41 ·
Re: Black Widow PFG
Believe it or not Ben, I'm still putzing on this stuff! That's the one down side to owning the spectro! LOL! Rather than make Bill or Jim mix it up and send it out it's easier just for me to be the tinkerer. Bill and Jim are the idea guys. I'm their soldier! :bigsmile:
But I am tinkering with some other things that have been tried before and some that haven't. Where they'll lead us...:dontknow: But I do know this. I have a heckuva lot of respect for you guys who've done this without a spectro! You guys are amazing and my hat is off to you! ;)
mech
Status
You have insufficient privileges to reply here.
