speaker testing software. - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Discuss speaker testing software. in the DIY Speakers and Subwoofers forum; speaker testing software. Im looking to buy some testing software, and i'm curious what everyone uses and recomends. Right now im looking at ...
Old 03-13-08, 04:40 PM   #1 (Link)
Alias: jer
Loc: ct
jeremy7's Avatar
User: #16574
Since: Feb 2008
jeremy7 is offline
Soundeasy ($250)
bass box with x-over pro ($170) both from parts express
or possibly true audio
I cant decide, bass box looks good but i dont think it tests impedance.
I realy want something complete and accurate, any advice would be appreciated
Old 03-13-08, 06:49 PM   #2 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Re: speaker testing software.
Well, I'm using speaker workshop, which is free. However, you have to be very patient and allow for a steep learning curve. I"m just now (1 year later) getting comfortable with my measurements and that I'm using the crossover tools properly.
Also plan on getting a good test mic. Apparently there are alternatives to the Behringer ECM8000. Naiant and Beyer make good ones on both ends of the spectrum (the Naiants are cheaper and the Beyer is expensive). I have the ECM8k and an M-Audio Mobile Pre USB soundcard. There are other alternatives you can use, but you have to supply phantom power to most good mics.
If you want to go pre-packaged, I have heard many good things about Sound Easy. Zaph (www.zaphaudio.com) uses it and likes the combination of testing and design tools.
Good luck.
Old 03-13-08, 06:51 PM   #3 (Link)
JCD
Golden Bear Mod
Alias: Jacen
Loc: Bay Area, California
JCD's Avatar
User: #53
JCD is offline
The recommendation I've seen most often is TrueRTA. It's not best of breed, but it's inexpensive ($100 for level 5 version -- which you want) and easier to use than most. REW is free, but I don't think it does all of the testing stuff you'd want in a testing software. The other thing I'm seriously considering is getting the Woofer Tester from Parts Express. I think between that and TrueRTA, you'd be doing pretty well.
JCD
Old 03-18-08, 11:43 AM   #4 (Link)
Alias: Ken
Loc: CT
ktaillon's Avatar
User: #7968
Since: Apr 2007
ktaillon is offline
Take a look at ARTA, it works with most sound cards and mics. I also own TruRTA, it's a great tool but it's a real time analyser, not a MLS (time based) frequency response tool.
It's nice to have both so you can get the response from the speaker and also the room response.
Both companies have free trial versions.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Similar Threads
Designing a sub... software, etc. Boris Yeltsin DIY Subwoofers 4 03-01-08 02:19 PM
Software EQ? mgboy REW Forum 7 08-07-07 08:11 PM
Software EQ dsiroky REW Forum 1 04-09-07 04:55 PM
REW w/software EQ? andreh REW Forum 16 02-19-07 11:50 PM
Mach 5 Audio
