Two way floor standing/shelf speakers - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Discuss Two way floor standing/shelf speakers in the DIY Speakers and Subwoofers forum; Two way floor standing/shelf speakers Hi All here at the shack. I just read an interesting thread with a guy that is about to make ...
Old 03-22-08, 03:56 PM   #1 (Link)
Alias: tued
User: #17717
Since: Mar 2008
tued is offline
I just read an interesting thread with a guy that is about to make some curved cabinets. So I thought I would share my curved cabinet with you.
Here comes the pics:
Comments are welcome, regards.
Old 03-22-08, 05:01 PM   #2 (Link)
New Member
Alias: denizen
User: #11886
Since: Sep 2007
denizen23 is online now
Re: Two way floor standing/shelf speakers
Nicely done!!
Old 03-22-08, 05:19 PM   #3 (Link)
Alias: Wild
Loc: Trinidad and Tobago
Wildcard26's Avatar
User: #9110
Since: May 2007
Wildcard26 is offline
Those are absolutely amazing..
Old 03-22-08, 05:55 PM   #4 (Link)
Alias: Randy
Loc: Minnesota, USA
User: #12896
Since: Oct 2007
yourgrandma is offline
Did you fill the relief cuts with anything? Looks like a simpler method than veneering. Looks nice.
Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3
Old 03-22-08, 06:59 PM   #5 (Link)
Alias: tued
User: #17717
Since: Mar 2008
tued is offline
No, no fills, but you could do that to add extra stability.
As it is only a 5 1/4" driver I saw no need for that. The front baffle if a 1,5" thick sandwich construction, so that is quite stable.
And thanks for the credit
Old 03-23-08, 10:58 AM   #6 (Link)
Alias: Josh
Loc: Louisville, KY
Ricci's Avatar
User: #9132
Since: May 2007
Ricci is offline
Very nice and quite unique looking too. The spikes are a nice touch. How do they sound?
Old 03-23-08, 03:43 PM   #7 (Link)
Alias: tued
User: #17717
Since: Mar 2008
tued is offline
The sound:
First impressions:
The sound is very open and detailed, the bass was not as controlled as I wanted it to be....but there is plenty of it. To be hournest they sounded a bit boring.
Second impresions:
I sealed the port with some acoustic damper foam and that really made them change character.
The overall sound gets much more controlled and detailed, especially the bass is effected (positivly that is). The bass is so clean now. Very nice.
I'm amazed of the impact this did.
Maybe I should have made them closed in the first place (at bit late for that now...), but this way I guess you could say that they functions as a closed box with an acoustic vent.
Anyway I'm really glad for the sound now - not boring at all anymore
Old 03-23-08, 05:12 PM   #8 (Link)
Alias: Randy
Loc: Minnesota, USA
User: #12896
Since: Oct 2007
That's pretty good work, would you mind sharing your process for smoothing the back? Did the MDF smoothly bend or did it square off at each relief? How did you finish them? I would picture using Bondo, as I have done in the past.
Old 03-24-08, 06:28 AM   #9 (Link)
Alias: tued
User: #17717
Since: Mar 2008
tued is offline
yourgrandma wrote: View Post
It is a it bit 'squared-up' but you have to look closely to see this.
I made a mold/form to support the structure, then glued the sides together. In fact the only screws is for the drivers and spikes.
I'll see if can find some additional pictures that visualize the build process.
I finished them with a low-gloss as the first layer and then I rolled on a thick layer of high-gloss paint with I then smoothed out with a very wide brush. The last step for repeated several times after sanding each layer.
Old 03-30-08, 11:04 AM   #10 (Link)
New Member
Alias: michael
Loc: bristol ct
User: #18085
Since: Mar 2008
flavo cadillac is offline
hey there, your cabinets look gorgeous, very nice work and great detail w/ the spikes.
i just wanted to add for anyone thinking of doing a similar relief cut to be careful w/ what ever they might use to fill the cuts. make sure that the product doesnt have too much liquid in it or it will push out the mdf at the relived area leaving you w/ a very bumpy surface. ask me how i know
Old 04-01-08, 11:32 AM   #11 (Link)
Alias: Ken
Loc: CT
ktaillon's Avatar
User: #7968
Since: Apr 2007
ktaillon is offline
Nice job, It's nice to see some box shapes other than a rectangle. What did you use for drivers?
I bet it's very strong because of the round back.
Old 04-02-08, 12:55 AM   #12 (Link)
Alias: tued
User: #17717
Since: Mar 2008
tued is offline
I used the following Visaton drivers:
For the mid/bass I used the AL 130 and the tweeter is the G 20 SC.
The box is very stable and you can barely feel any vibrations, especialy the front baffle is dead. Even when playing very loud.
Old 04-02-08, 07:50 AM   #13 (Link)
Alias: Ken
Loc: CT
ktaillon's Avatar
User: #7968
Since: Apr 2007
ktaillon is offline
I noticed that you used the one piece baffle, I see those at Home Depot. They also have stair treads that is 1" or 1 and 1/8" thick pine with no knots. It makes a nice baffle too.
Old 04-02-08, 10:41 AM   #14 (Link)
Alias: tued
User: #17717
Since: Mar 2008
tued is offline
I got the wood at a locale dealer here in Denmark. It would not make much sense for me to get my wood at the home depot unless they offer free shipping
The stair threads baffle is 18mm (0,70866142 inches) thick which is more than enough because the inner-baffle is of 19mm (0,7480315 inches) MDF. So it is actually quite thick. I think that the front (outer) baffle will look to thick if it was 1"...but good to get some referrence to other places where to get your stuf and inspiration.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Similar Threads
Any off the shelf N8.5 paints identified yet? Harry Muscle Projector Screens | DIY Screens 7 02-09-08 09:51 AM
Neutral Grays and Simple Off the Shelf Solutions wbassett Projector Screens | DIY Screens 125 12-01-07 12:35 PM
In-wall vs Free Standing Speakers tzilinsky Home Audio Speakers 5 10-07-07 01:37 PM
Effectiveness of free standing super chunks? jaegertc Home Audio Acoustics 4 03-24-07 03:09 PM
Revel F52 Floor-Standing Speakers, C52 Center Channel Speaker, S30 Bookshelf Speakers Sonnie Home Theater, Audio and Video News 0 06-02-06 08:33 AM
Mach 5 Audio
