Different impedance/same system? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Discuss Different impedance/same system? in the DIY Speakers and Subwoofers forum; Different impedance/same system? Consider a two way sealed system with a 4ohm tweeter and 8ohm midbass-midbass driver has 2db greater sensitivity. Any inherent ...
Old 05-02-08, 11:02 AM   #1 (Link)
Alias: anthony
User: #16309
Since: Feb 2008
mayhem13 is offline
Consider a two way sealed system with a 4ohm tweeter and 8ohm midbass-midbass driver has 2db greater sensitivity. Any inherent problems that couldn't be reasonably accounted for in the x-over?
Another option would be to add a second midbass in parallel but i'm not sure my receiver will like the 4ohm load.
Old 05-02-08, 11:33 AM   #2 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Re: Different impedance/same system?
You can pad the level of any driver down with a resistor (not an lpad, just a series resistor) and raise the impedance. However, that resistor has to pass through a significant amount of current to the drivers south of it. This is why you normally see this arrangement with a tweeter only: they are more efficienct (usually) and require much less power to drive than a woofer.
2dB is not that much, and many drivers (especially different brands) may end up being perfect matches, despite their SPL spec. It's not uncommon to see a 90dB woofer measure 88 or even 93.
so the simple answer is that you're starting in a hole with the mids being more efficient, especially since you need to raise the impedance of the tweeter a tad (which always comes with an efficiency hit). But it may be doable.
Another thing you can do if you absolutely want these two drivers, is you can use the DCR in any inductors for the woofer low pass filter to eat some of the efficiency. It is not ideal and makes you entire system much less efficient, but it can match the levels.
Last option is active crossover. In my mind, this is the only reason to resort to active crossover (flame on guys ) -- but it is the primary benefit of that route. You can match widely disparate efficiencies between drivers in the crossover to amp stage. Of course that comes at the expense of portability (i.e. plugging into anybody's system) and more gear. But it is an option if you are married to specific drivers that have this problem.
That's all I got now. Hope that helped some.
Old 05-04-08, 05:45 PM   #3 (Link)
Alias: Boom
Loc: Fairfax, Va
BoomieMCT's Avatar
User: #4757
Since: Dec 2006
BoomieMCT is offline
+1 what Anthony said about manufactuer's specs not always being spot on. Also the listed sensitivity is often an averaged value. You may find that once in the enclosure things aren't like what they are on paper. The best thing to do is make a test enclosure and go from there.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Similar Threads
Hi Vi SD1.1 impedance guitarded DIY Speakers 4 02-04-08 03:42 PM
Here is my system enquire Home Theater Equipment 0 10-28-07 10:04 AM
New 5.1 system jpm11 Home Audio Speakers 5 04-20-07 11:48 AM
BFD Impedance Issues? Housteau BFD Forum 6 04-18-07 10:09 AM
My System chasw98 Home Theater Equipment 0 09-19-06 06:20 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
