| DIY Speakers Designing some speakers, need a little help.Discuss Designing some speakers, need a little help. in the DIY Speakers and Subwoofers forum; Designing some speakers, need a little help. Hello, I'm a product designer at Sheffield Hallam in the UK and have decided to design some speaker for one ... |
| | #1 (Link) | |||
| Designing some speakers, need a little help. Hello, I'm a product designer at Sheffield Hallam in the UK and have decided to design some speaker for one of my projects, to be honest I started this project thinking it would be pretty straight forward but i was badly mistaken. Up to now the I've decided I'm going to design some floor standing speakers with the general 3 speaker system, high, mid and low speaker separation and will be using a nice looking solid wood and the Biwire system, but im struggling to make decisions on what type of material to use for the components. So here are some of the questions I'm after to progress with this project, hopefully some light can be shed on these questions. First of all tweeters. Amongst other materials I've seen aluminum and titanium tweeter, what is generally the best material for a set of main speakers for the home when it comes to sound quality? or is there some kind of future material coming on the scene which is not really known about yet? Also there are all kinds of tweeter like AMT or ribbon tweeter and many more, generally what type is used for a loudspeaker and sufficient for general home use? Domes, paper, plastic or kevlar? I have to admit I am going for the Kevler up to now as I just think it looks cool, but does this material have any benefit over paper or plastic or vice versa when it comes to sound quality? or again, is there any kind of wildcard material which is not really known about? Speaker spikes, do these really have any kind of benefit on sound quality? I have researched and researched and found out quite alot but to be honest I have been overwhelmed, there is just so much different stuff out there and so many pros and cons to anything I find relavent, thats why I've turned to forums now where the real audio heads are, to get real feedback and not a sales pitch. Any reply to these questions will be greatly appreciated. I will upload the designs I come up with as I progress. Thank you. | |||
| | #2 (Link) | |||
| Re: Designing some speakers, need a little help. Welcome Nathbonn. Glad you have you here. Your tweeter question is a great one. I think you should spend some time listening to different tweeters installed in commercial speakers at your local audio shops as much as possible. Hopefully, you will get a sense of how each type will present its sonic signature. Of course, you will never find the perfect tweeter, or woofer for that matter. Others will give better advise. Have fun, Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) Denon AVR-2807 Receiver w/AudysseyXT LG DVD Recorder w/HDMI Direct TV DVR HD Optoma H31 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | |||
| | #3 (Link) | ||||||
| Re: Designing some speakers, need a little help. Quote:
Basically, what I am saying is don't look at driver composition, but the actual data on how it reacts at certain frequencies and SPLs. Actually, speaker spikes couple a speaker to the floor which is not a good thing. Rather I would recommend using a decoupling system such as a high grade dense foam that would decouple the speaker from the floor thus reducing/eliminating resonance. If you have any more questions or want clarification feel free to ask. Also, more information on what you want to do with these speakers as well as budget and expectations would be useful. BTW, I am moving this to the DIY speaker section as it will likely get more traffic there. -Andrew | ||||||
| | #4 (Link) | ||||
I know from where I speak, I added spikes to an old system, and they did just that. | ||||
| | #5 (Link) | ||||
It is simple physics that spikes actually couple a speaker to the ground by creating a point of contact and thus energy transfer between both the ground and the cabinet. This will most certainly create a problem with resonance. On the other hand using the method I suggested there would be complete separation between the ground and the loudspeaker allowing for no/minimal transfer of energy. This increased resonance would do anything but tighten up bass in an unbiased situation. Also, it is highly unlikely that the spikes had any effect on the treble of your system due to the nature of the wavelength at these frequencies. My statements are not based on personal opinion, but the science and credible research relevant to the field of loudspeaker design, perception and their relation to enjoyment as shown in the AES and other credible publications. -Andrew | ||||
| | #7 (Link) | |||
| Re: Designing some speakers, need a little help. Applying simple laws of physics would make one realize why spikes would be detrimental to sound quality. Thusly, what a speaker company sells, and what is popular does not necessarily correlate with high quality, Bose is a perfect example of this. It should also be pointed out that just because it is commonly accepted does not mean it is the proper methodology to implement. It should be noted I am referring to highest possible fidelity. Another note would refer to self proclaimed audiophiles who claim various snake oils create higher sound quality. This is all based solely on bias and has no basis in reality - spikes happen to fall into this category. I no longer wish to derail this thread. If you wish to debate the 'merits' of spikes feel free to create a thread on the subject. -Andrew | |||
| | #8 (Link) | |||
| Re: Designing some speakers, need a little help. I believe both of you are right on the subject. While the spikes will create additional resonance due to coupling, many people find the bass extension gained pleasing especially in a smaller system lacking in low end extension. In the Pro audio industy we would typically suspend our full range systems to avoid system resonance around 800hz that would create excessive feedback at high Spl. the same effect could happen in home listening environments at various frequencies excited by room modes lending to 'pollution' of absolute fidelity.While not as significant as feedback, the resonances will color the output which may be desirable given the frequency response of the given system.Going with an active crossover system will easily make such issues moot at normal listening levels. | |||
| | #9 (Link) | |||
| | Re: Designing some speakers, need a little help. I think avaserfi made some great points and agree pretty much with everything he stated. I'd suggest that if you're really serious about building a set of speakers, I HIGHLY recommend going with a proven DIY design. Designing a set of speakers from scratch and getting a good result is time/cost intensive -- especially as a complete beginner. Also, lets move any further spike pro/con arguements to another thread as avaserfi suggested -- the OP shouldn't have to wade through these arguements here. Thanks. Oh and welcome to the Shack Natbonn! JCD | |||
| | #10 (Link) | ||||
-Chris | ||||
| | #11 (Link) | |||
| Re: Designing some speakers, need a little help. Here are some good foolproof designs. http://www.htguide.com/forum/forumdisplay.php4?f=39 I dont like reinventing the wheel ![]() | |||
| | #12 (Link) | |||
| Re: Designing some speakers, need a little help. Hi all, thank you all for your responses, its been very helpful. When I started this project I thought I would be able to full understand all the working of a speaker and be able to design one that theoretically worked with beautiful sound quality in just two months lol, man was I being foolish there, I never understood how complex this area really is, I thought that there would be a universal standard of getting sound quality by basically using the the most expensive material ect. After some time researching in to the technologies and science behind the workings of speakers I've now come to the conclusion that it will be best for me to take a more conceptual approach to this project and lightly touching on the componets, technology and materials used to simply justify my concept design as I simply do not have enough time to fully understand fine technological issues surrounding this area. So up to now I'm going to make some floor standing speakers, the cabinets will be made of some kind of ply wood or MDF with a nice finish. I wont be using the biwire set up as I have had quite a few responces to this saying that there is not really any need for it in my circumstance (a set of speakers for the general home) I will be avoiding right angles for my cabinet (I don't fully understand why this is seen as better) but supposedly it it so as a designer I will take this on board. I will be using bass ports. Even though I know they have to be a the right size in conjunction with the cabinet and the drivers but thats not something I will be going into in too much depth with. The fact that they give better bass if used right is good enough for me. The mid and high ranged speakers still have to be air tight as bass ports only apply to base. I will be using 3 speakers in each cabinet each doing their specific job, low=woofer mid speaker and a tweeter=high. For the tweeter I will be using a hard material such as aluminum or titanium as there are known more for there high frq and from the research I have done this seems in general what what a tweeter is all about. I will be using Kevlar for the low and mid ranged speakers because I think it looks cool and companies such as Bowser and Wilkins say that it has positive attributes for breaking sound up or something so thats good enough for me because I again...I think it looks cool also![]() erm yeah, I know that this is all very very vague for people who know all about the technology behind the speakers but this is going to be a conceptual design. As for the forum community I would like you to point out anything here that is totally wrong in some of the choices and information I feel I briefly understand and maybe suggest something else if it really does not make any sense. I have processed the information I have gained over the last week or so to the best of my ability but this has got to end, I could go on like this and be in this state of confusion for the rest of my life ![]() But please remember that this design is not going to be a fully resolved design but rather a design that follows some basic rules to justify a pair of loudspeakers for the general home. Thank you. Last edited by Nathbonn; 03-28-08 at 09:40 AM. | |||
| | #13 (Link) | |||
| | Re: Designing some speakers, need a little help. Just a few comments..
JCD | |||
| | #14 (Link) | |||
| Re: Designing some speakers, need a little help. Hello Nathbonn, new guy here but I though it worth while to reply to your post. I've played with systems since I was ten, and now I'm fifty. So lets just say I've been able to gather some biased opinions for 40 years. First and foremost, you'll find eveyone agrees and disagrees on what sounds the best. And through my many years of building, I've come to a few conclusions and have been able to do some off the cuff comparisions. I get my hearing checked each year, part of my job working in industrial atmosphere. And so do the people I work with. From the graph of the hearing tests they perform everyone hears a tad different, and some dramatically different. So our hearing curves are not flat like the ones the speaker companies sell us. So what I may be able to hear is different than what you may be able to hear. It comes from genetics and what abuse your ears have taken over the years. Then there is what you think you should be able to hear vs what you really do hear. This come from exposure and memory. So while we are both sitting at a live performance of say some acoustical guitars, I may hear certain sounds at different levels than what you may hear. When we play these sounds back over a sound system, the sound I heard at the concert will need to sound the way I perceived it vs the way you perceived it. What are we hearing? harmonics and reflections at different sound levels. And then there is personal preference. We could have 20 females vocalist sing the same song at the same tempo et al and you'll like one more than I may like another. Which goes along with the looks of the speaker. If I think a speaker is ugly, no matter how great the sound really is, I may never like the sound it makes. While the same components in a more pleasing design will automatically sound better to me than the ugly speakers. Psychoacoustics? So with all that said, will a measured response of a system be able to tell me what going to sound good? Maybe, but only my ears will tell me. So my advise to you is to go out and listen to several different manufacturers and see what types of speaker formats you enjoy the best and go from there. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Designing a sub... software, etc. | Boris Yeltsin | DIY Subwoofers | 4 | 03-01-08 02:19 PM |
| Designing a home theater from scratch | Neal_3 | Home Theater Design and Construction | 8 | 11-20-07 03:51 PM |
| Need Help Designing Home Theatre | max1565 | Home Theater Design and Construction | 5 | 04-26-07 12:10 PM |
| More speakers anyone | Steve Williamson | Home Audio Speakers | 5 | 07-17-06 11:08 AM |
| Revel F52 Floor-Standing Speakers, C52 Center Channel Speaker, S30 Bookshelf Speakers | Sonnie | Home Theater, Audio and Video News | 0 | 06-02-06 08:33 AM |
