Vifa tweeter help - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Vifa tweeter help
Discuss Vifa tweeter help in the DIY Speakers and Subwoofers forum; Vifa tweeter help I have an older pair of Snell KIIV speakers that have a Vifa D26TG-05 tweeter. One of them is blown. ...
Old 03-26-08, 10:31 PM   #1 (Link)
New Member
Alias: maxdog03
Loc: Northwest
User: #18797
Since: Mar 2008
maxdog03 is offline
Vifa tweeter help
I have an older pair of Snell KIIV speakers that have a Vifa D26TG-05 tweeter. One of them is blown. I have found on ebay and the seller just happens to live in my town that has a pair of Vifa D27TG-05 for sale and both the 26's and 27's are 6 ohm. My question is from you more experienced speaker builders would these tweeters work in my Snells and would they be an improvement or a down grade? Thanks for any advice.
Old 03-27-08, 08:54 AM   #2 (Link)
Alias: josh
User: #15511
Since: Jan 2008
ringbearer3791 is offline
Re: Vifa tweeter help
I can't tell you off-hand whether these new drivers are going to be an improvement or not but i would recommend giving Snell a call. My HT is all Snells right now and i've spoken to those guys a few times with questions. They've always been extremely helpful and friendly. they may even have OEM replacements for your tweets if you want to go that route.
Snell Acoustics
300 Jubilee Drive, PO Box 3717
Peabody, MA 01961-3717
Phone: (978) 538-6262
Fax: (978) 538-6266
Email: support@snellacoustics.com
good luck, hope this helps.
__________________________
46" Sony 720p LCD
Denon AVR-4306
Snell K5 fronts
Snell KIII rears
Snell XA55 center
Snell PS 10 Sub (TC LMS4000 coming soon!)
Oppo 981hd
APC H15 power conditioner
Old 03-27-08, 11:50 AM   #3 (Link)
New Member
Alias: maxdog03
Loc: Northwest
User: #18797
Since: Mar 2008
maxdog03 is offline
ringbearer3791 wrote: View Post
Snell Acoustics
Fax: (978) 538-6266
Thanks,
I'll probably give that a try. I did find that Madisound does have the 26 tweeters in stock but it will cost the same for one than it will be for these two that are available. If the 27's would sound good, then I was thinking I could sell off the one good 26 and recover most of my money.
Old 03-28-08, 08:00 AM   #4 (Link)
Alias: Michael
Loc: Chesapeake Virginia
User: #3685
Since: Nov 2006
buggers is offline
Most of the time you can not replace drivers with another model. To do so would require a completely new crossover.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Similar Threads
Tweeter advice BoomieMCT DIY Speakers 0 02-28-08 01:10 PM
Vifa repair question steve Manufacturers Service and Support 2 02-08-08 02:28 PM
How to tone down the tweeter ccdoggy DIY Speakers 4 05-11-07 10:14 AM
Vifa lcaillo Manufacturer and Vendor Reference Information 0 04-30-07 10:36 PM
Tweeter preferences Exocer Home Audio Speakers 27 01-22-07 05:13 PM
Mach 5 Audio
