Getting ready - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Getting ready
Discuss Getting ready in the DIY Speakers and Subwoofers forum; Getting ready I'm embarking on a new DIY speaker based on the Quasi.Mo.D.O. http://hjem.get2net.dk/sejrhede/diy21.htm using the Pioneer B20FU20-51FW 8" Full Range Driver ...
Old 06-02-08, 03:42 PM   #1 (Link)
Alias: Jay
Loc: Western Wisconsin
jackfish's Avatar
User: #5100
Since: Dec 2006
jackfish is offline
Getting ready
I'm embarking on a new DIY speaker based on the Quasi.Mo.D.O. http://hjem.get2net.dk/sejrhede/diy21.htm using the Pioneer B20FU20-51FW 8" Full Range Driver http://www.partsexpress.com/pe/showd...number=290-045 instead of the Monacor SP200x, the Motorola KSN-1005 piezo http://piezosource.com/general/datas...1001_1005A.pdf and an 8 Ohm L-Pad. I'll use an 8 Ohm resistor and L-Pad on the piezo with a simple capacitor filter at 15,000 Hz and will build the box and vent for an FS of 33Hz.
My question after all of that is, looking at the plans what assortment of clamps would I need to glue that box together? Thanks.
Old 06-02-08, 04:48 PM   #2 (Link)
Alias: Boom
Loc: Fairfax, Va
BoomieMCT's Avatar
User: #4757
Since: Dec 2006
BoomieMCT is offline
Re: Getting ready
You have the dimensions of the box - buy clamps accordingly.
Now you know that you can't just sub drivers and/or tweeters and expect it to work. I assume the creator of the original design picked a x-over for the tweeter that corresponded with the roll-off of the woofer. By changing both parts your design may not cross properly. Also the tuning of the box will change by using a different woofer.
Old 06-02-08, 05:19 PM   #3 (Link)
Alias: Jay
jackfish's Avatar
User: #5100
Since: Dec 2006
jackfish is offline
Re: Getting ready
Thank You for your response. It is not a standard tweeter-woofer configuration. The 8" driver is full range with a stated frequency response of 36Hz-17,000Hz. The piezo will be "crossed over" at 15,000Hz (1.33 uF) only to enhance high frequencies above that. I can also experiment with different capacitors up and down from there. I have recalculated a similar box and vent based on the replacement 8" driver parameters for an FS of 33Hz. The box is larger, with different port dimensions. What kind of clamps are appropriate or are in your arsenal for making speaker boxes?
http://www.d-s-t.com.au/data/Misc/CTS/QuasiMoDo.htm
Are you aware of the fun of full range drivers enhanced with a piezo? http://fullrangedriver.com/forum/ http://www.zillaspeak.com/
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Similar Threads
Almost ready to start using REW salvasol REW Forum 19 04-21-08 06:00 PM
HD-Ready Question powder21 Video Displays and Processors 10 03-06-08 12:13 AM
Am I HDTV ready? hifidave Home Theater Projectors 1 10-24-07 08:01 AM
Getting ready for REW? Warpdrv REW Forum 4 04-23-07 04:49 PM
Getting ready to put together my first... Joeychgo Home Theater System Recommendations 8 08-15-06 01:06 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191
