Infinity Crossover question - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Discuss Infinity Crossover question in the DIY Speakers and Subwoofers forum; Infinity Crossover question I have a pair of crossovers from some Infinity RS4000 speakers. I am thinking about using these in some DIY ...
Old 04-09-08, 10:05 PM   #1 (Link)
Alias: Binger
Loc: Omaha
User: #18424
Since: Mar 2008
SQCherokee is offline
I am thinking about using these in some DIY speakers.
Do any of you know what the impedence of the individaul drivers in these speakers were? They were not labled on the drivers them selves...and the guy I talked to at Infinity had no idea.
Also what were the crossover points of these units?
Old 04-09-08, 10:15 PM   #2 (Link)
Alias: Boom
Loc: Fairfax, Va
BoomieMCT's Avatar
User: #4757
Since: Dec 2006
BoomieMCT is offline
Re: Infinity Crossover question
Not to sound like a purist but unless you are going for a real budget option you will be better off making your own x-overs.
Old 04-10-08, 01:37 PM   #3 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is online now
Your best bet would be to identify the values of the inductors, resistors, and capacitors, and put them in a modeling program like speaker workshop or Passive Crossover Designer from FRD Consortium.
Even without an accurate speaker impedance, you could probably estimate where the crossover points were. Then you could "fake" a driver impedance from a similarly sized driver (get data from Parts Express or Madisound) to confirm.
I would guess for a commercial speaker the woofer would be 8Ohms nominal, but that would probably put it somewhere between 5 Ohms in a dip, with a peak over 30 Ohms. They really do go all over the place, which is why the best way is to measure the impedance directly.
For that you can use one of several tools: Speaker Workshop, Sound Easy, Woofer Tester from Parts Express.
As a last resort, you may be able to identify the woofer from markings and some place may still sell the raw driver. Unlikely, as Infinity probably has their own manufacturing for that.
Good luck.
Anthony
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Similar Threads
FS Four Infinity SM65 loudspeakers jackfish Classifieds - Speakers and Subwoofers 0 02-11-08 03:49 PM
Infinity lcaillo Manufacturer and Vendor Reference Information 0 05-14-07 07:37 PM
Crossover question(s) BoomieMCT DIY Speakers 11 02-10-07 07:38 AM
DIY Infinity Kappa Perfect 12 Ilkka Subwoofer Tests 5 10-11-06 05:50 PM
DIY Infinity Kappa Perfect 12 w/ EQ and XO Ilkka Subwoofer Tests 3 07-17-06 02:29 PM
Mach 5 Audio
