2 way or 3 way - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
2 way or 3 way
Discuss 2 way or 3 way in the DIY Speakers and Subwoofers forum; 2 way or 3 way Hi all I currently have for my mains a 3 way speaker made up of Woofer: 200mm seas Basic P21 ...
Old 04-14-08, 07:30 PM   #1 (Link)
Alias: Eccentric
Loc: Gold Coast, Qld,Australia
User: #10564
Since: Jul 2007
Jason Schultz is offline
2 way or 3 way
Hi all
I currently have for my mains a 3 way speaker made up of Woofer: 200mm seas Basic P21 Rex DD, crossed to mid around 900 Hz. Mid is Vifa D75MX dome crossed to tweeter at 3khz. Tweeter is Vifa old D 19AD with flerro fluid.
I'm wanting to upgrade the sound of the system by possibly switching to a new tweeter. but would I be better off getting rid of the mids and making the speakers into two way speakers. This would be better from a DIY crossover standpoint. My concerns are:
1/ It looks as though the woofer 's FR becomes a little lumpy around 1000 HZ. so crossover would be difficult and final sound not so great.
2/ When driven hard I don't want to hear intermodulation distortion in vocals(which i have heard in two way speakers previously)
So I am also pondering updating to a better mid /tweeter combination.
has anybody used the P21REX in a two way before or does anyone have any suggestions.
Old 04-14-08, 07:40 PM   #2 (Link)
Alias: Boom
Loc: Fairfax, Va
BoomieMCT's Avatar
User: #4757
Since: Dec 2006
BoomieMCT is offline
Re: 2 way or 3 way
As you seem to have already pointed out - I'm not sure how remaking a 3-way as a 2-way would be an improvement.
Anyhoo - what is it about these speakers that you feel needs improving? That's the first question you need to answer. Also there is a good chance that you'd get more improvement starting from scratch. Usually simply swapping drivers won't do cut it.
Old 04-14-08, 08:36 PM   #3 (Link)
Alias: Eccentric
User: #10564
Since: Jul 2007
Re: 2 way or 3 way
boomie wrote
Anyhow - what is it about these speakers that you feel needs improving?. thats a very good question. I would have to say that I have heard speakers with a better sounding treble than mine. I was wanting that clean airy top end that mine don't have so i thought i would replace the tweeter (redesign crossover ofcorse)
I was also trying to not have to spend money and time on a complete new design
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
