DIY Niles LCR Clone - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
DIY Niles LCR Clone
Discuss DIY Niles LCR Clone in the DIY Speakers and Subwoofers forum; DIY Niles LCR Clone http://www.nilesaudio.com/product.ph...rdcdID=FG01136 Hey guys. I have been mildly obsessed lately about making a set of LCRs. I have been pouring over ...
Old 04-14-08, 11:50 AM   #1 (Link)
Alias: matt
User: #7380
Since: Mar 2007
hddummy is offline
DIY Niles LCR Clone
Hey guys. I have been mildly obsessed lately about making a set of LCRs. I have been pouring over different DIY projects and websites, but I can't find any projects that look like the Niles Audio speakers that I really like. Have you ever seen a DIY with that configuration? I might have to adapt existing projects or just go it alone.
I think a sealed box with two Dayton RS225 woofers and one RS52 mid-dome are a good start. I haven't picked a tweeter.
I'm just getting started here, but I'd appreciate any feedback. Thanks!
Matt
Old 04-14-08, 06:21 PM   #2 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is offline
Re: DIY Niles LCR Clone
I can't say I've sen a DIY with that configuration. If you do have to "go it alone", you'll be entering the dark world of crossover design.
We're all in this together!
Old 04-14-08, 06:50 PM   #3 (Link)
Alias: matt
User: #7380
Since: Mar 2007
hddummy is offline
indeed, that is the path I am most afraid of and the reason i would rather find a DIY already worked out. However, I am willing to try, learn and experiment as long as the cost of buying a bunch of components doesn't get to be too excessive. I guess i'll play around with speaker workshop for a while and see what I can figure out.
Old 04-14-08, 07:45 PM   #4 (Link)
Alias: Boom
Loc: Fairfax, Va
BoomieMCT's Avatar
User: #4757
Since: Dec 2006
BoomieMCT is offline
I hear those are good speakers but I still don't understand why they laid the drivers out the way they did. I can see it being do-able but I don't see any advantage to it.
If you are interested in doing this project I'd spend some quality time with Speakerworkshop, Passive Crossover Designer and Edge.
Old 04-15-08, 05:19 AM   #5 (Link)
Alias: matt
User: #7380
Since: Mar 2007
hddummy is offline
I'll definately be rocking the design software programs for a while. That'll keep me busy and challenged enough to make sure I want to follow through with it.
DS-21 wrote: View Post
Also, definitely go with a cone mid. You don't want to have your woofers in that kind of setup playing very high.
What frequency range do you refer to as "high" in this case?
Old 07-03-08, 01:09 AM   #6 (Link)
New Member
Alias: DYsLeXiC
User: #22671
Since: Jul 2008
dyslexic is offline
Any headway on this project? I'm a tad interested....actually, very interested....
Old 07-03-08, 09:43 AM   #7 (Link)
Alias: anthony
User: #16309
Since: Feb 2008
mayhem13 is offline
Look at the ZDT3.5 design from zaph-the woofer uses the rs180 at 7" instead of 8, but the box can be reconfigured for volume match. The xover is first rate on the design so it's a good place to start adjusting for BSC of course.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Similar Threads
Proficient Audio C1030 (New LCR in-ceiiling) lspence Home Audio Speakers 4 02-21-08 08:37 AM
amp help svs pb12+2 clone matt98svt DIY Subwoofers 9 01-28-08 07:01 PM
Exodus LCR and 61 speaker kits needed rick12667 DIY Speakers 5 12-06-07 10:43 PM
Niles lcaillo Manufacturer and Vendor Reference Information 0 05-12-07 10:38 PM
DIY Chorus XP3 clone Ilkka Subwoofer Tests 3 07-17-06 02:31 PM
Mach 5 Audio
