Resurecting Realistic Mach One's - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Discuss Resurecting Realistic Mach One's in the DIY Speakers and Subwoofers forum; Resurecting Realistic Mach One's I was given a pair of Mach One's today. One is minus the woofer the other has some cone damage ...
Old 11-19-07, 12:50 PM   #1 (Link)
Alias: Brad
User: #12504
Since: Oct 2007
Tiny is offline
I was given a pair of Mach One's today. One is minus the woofer the other has some cone damage and needs foaming. When I was a kid I drooled over the pair a family member had. The midrange and and tweeter are both horns. (If I recall right, these were rather pricey for the day about $750 for a pair in 1980) I want a quality 15" that isn't going to cost me a fortune. Any suggestions.
Old 11-19-07, 12:58 PM   #2 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Re: Resurecting Realistic Mach One's
We would need to know rough cabinet dimensions and where it would be crossed over to be of any help.
Hopefully someone here has actually dealt with these speakers before and can give some advice, but if you can get volume and crossover, more people can chime in with advice.
Old 11-19-07, 01:11 PM   #3 (Link)
Alias: Brad
User: #12504
Since: Oct 2007
Tiny is offline
Anthony wrote: View Post
I have no idea what the cross over frequency is though the original was a 4 ohm 15", my cabinet volume in the main compartment is about 1.9cf the upper portion of the cabinet is sealed with a 7 ohm midrange horn.
I am tempted to leave the woofer off and use both sets of horns as a center channel project. Any thoughts on that?
Old 11-19-07, 01:54 PM   #4 (Link)
Alias: Brian Bunge
Loc: Palm Bay, FL
User: #63
Brian Bunge is offline
Is the cabinet sealed or ported? You might possibly be able to get away with the 4 ohm version of the Dayton Classic woofer from Parts Express:
http://www.partsexpress.com/pe/pshow...number=295-470
Brian Bunge
Old 11-19-07, 02:50 PM   #5 (Link)
Alias: Brad
User: #12504
Since: Oct 2007
Tiny is offline
it is a sealed box. This is the specs from an audio karma post
Mach One Liquid Cooled Speaker System specs: Frequency Response...........25~20,000 Hz Power Handling Capacity..160 watts peak program Impedance.............. .8 ohms System resonance........ 65 Hz Crossover Points: 1.2 kHz and 4.5 kHz Speaker Complement: " (38 cm) Acoustic suspension, 34.8 oz, 986 g) magnet, woofer with double brass voice coils, 1 extended range high compliance ferrofluid-, cooled horn tweeter, Multicellular ferrofluid-cooled horn midrange Enclosure: Oiled walnut with removable grille Controls: Midrange control, Tweeter control Dimensions: 28-5/8" H x 17-3/8"W x 12" D (72.7cm H x 44cm W x 30 cm D) Weight: 65 lbs
Old 11-20-07, 12:05 PM   #6 (Link)
JCD
Golden Bear Mod
Alias: Jacen
Loc: Bay Area, California
JCD's Avatar
User: #53
JCD is offline
So, does that mean the crossover point is 1.2khz?
In any case, I'd take a look at the Dayton drivers at Parts Express. Dayton seems to be a value leader these days. This one may work out..
However, this would mean a complete redesign of the crossover.. a difficult thing made even more so because it's a horn system (heard horns are even more problematic than regular drivers when designing crossovers).
JCd
Old 11-20-07, 12:07 PM   #7 (Link)
Alias: Brian Bunge
Loc: Palm Bay, FL
User: #63
Well, he said it was a 4 ohm woofer, so the 4 ohm version would be a better match. I modeled it last night and it looked pretty good in 1.9^ft3. The Q was around .8 but I don't know that that would be a deal breaker for these.
Brian Bunge
Old 11-20-07, 03:34 PM   #8 (Link)
Alias: Brad
User: #12504
Since: Oct 2007
Tiny is offline
I put a pair or pyle 15" subs in the cabinet just to give it a listen this morning. It wasn't the best low end I could have put in them, but at free they work better than nothing and since it was the highs and mids that really make this speaker it will be a great addition to my garage/workshop sound system. Besides when the lathe is running it ends up drowning out the details.
Old 06-08-08, 03:31 PM   #9 (Link)
New Member
Alias: Travis
Loc: Courtenay B.C.
User: #21711
Since: Jun 2008
WELROCK is offline
HI, I just picked up a pair of these mach one's, 4024A. I hooked up the speaker wires and only have sound out of the top tweeter. What is the port for between the speaker wire conectors? Do these need power to work? Help.
pontiacnut@telus.net
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195
