Neo3PDR faceplate question - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Discuss Neo3PDR faceplate question in the DIY Speakers and Subwoofers forum; Neo3PDR faceplate question Does anyone know if there are any real differences between the flush mount and surface mount faceplaces for the Neo3PDR?...
Old 04-22-08, 04:39 PM   #1 (Link)
Alias: Boom
Loc: Fairfax, Va
BoomieMCT's Avatar
User: #4757
Since: Dec 2006
BoomieMCT is offline
Old 04-23-08, 08:22 AM   #2 (Link)
Alias: Boom
Loc: Fairfax, Va
BoomieMCT's Avatar
User: #4757
Since: Dec 2006
Re: Neo3PDR faceplate question
I haven't done a proper test yet but looking over my very rough data it seems the surface mount extends the low end a bit. The waveguide seems deeper yet narrower on the surface mount one - perhaps this is part of it?
I'll try to do a side by side response test, both on and off axis, later. I'm curious if anyone else has insight though.
Old 04-23-08, 09:19 AM   #3 (Link)
Alias: Chris
Loc: Virginia, USA
User: #16045
Since: Jan 2008
WmAx is offline
Who is is that makes/sells the metal plate flush mount plate for the NEO3? I remember seeing this online a short while back, but I did not bookmark it. Oops.
TIA,
Chris
Old 04-23-08, 09:21 AM   #4 (Link)
Alias: Boom
Loc: Fairfax, Va
BoomieMCT's Avatar
User: #4757
Since: Dec 2006
WmAx wrote: View Post
TIA,
Chris
I got mine from Parts Express. They have the flush mount and surface mount ones. I will admit that my choice was more motivated by looks then performance - I'm making a speaker without flush mounting the drivers to match the quasi-industrial design of my HT. I did get curious if there was any noticeable performance difference though so I borrowed the flush mounted faceplate to do some tests.
Old 04-24-08, 10:34 PM   #5 (Link)
Alias: anthony
User: #16309
Since: Feb 2008
mayhem13 is offline
I've been researching waveguides lately and i would imagine after looking in the PE catalog that their would be a difference in off axis response and a slight difference in sensitivity of 1db or so.
Old 05-06-08, 11:30 AM   #6 (Link)
Alias: eyekode
Loc: Apex, NC
eyekode's Avatar
User: #15723
Since: Jan 2008
eyekode is offline
I used the flush-mount variety to build my copy of Cryolite's : http://www.lonesaguaro.com/speakers/...7/Cryolite.htm
I will admit that I chose the flush mount for aesthetics as well. I think flush-mounted drivers look much more professional.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Mach 5 Audio
