Mod/Build Center - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Mod/Build Center
Discuss Mod/Build Center in the DIY Speakers and Subwoofers forum; Mod/Build Center I have bee trying to figure out what to do with my screen and center for quite some time now, ...
Old 04-26-08, 10:34 PM   #1 (Link)
Alias: Randy
Loc: Minnesota, USA
User: #12896
Since: Oct 2007
yourgrandma is offline
Mod/Build Center
I have bee trying to figure out what to do with my screen and center for quite some time now, but with little luck. First, I figured I'd leave it the way it was and stick an AT screen in front of it, then I put the center out in front of the screen and liked it, but the front stage has a convex shape to it and I still have a horizontal center. I have contmplated finding a better center (ie clr 2300), but it's still horizontal. After trying my current center in a vertical position, I think I want to build a mini version of my mains for the center using parts from DefTech.
So, I wonder what your thoughts are. my current line up is in my sig for referance. I was thinking of getting two 6 1/2" mid bass drivers and building a short, wide cabinet for them and a DefTech tweeter I have, along with either a custom crossover or a production model from DefTech.
Just help me brainstorm, what are your ideas on the subject? Obviously the info is a bit sparse, but I'd be hard pressed to give all the info in one post, feel free to ask anything.
Thanks!
Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3
Old 04-27-08, 12:09 AM   #2 (Link)
Alias: Boom
Loc: Fairfax, Va
BoomieMCT's Avatar
User: #4757
Since: Dec 2006
BoomieMCT is offline
Re: Mod/Build Center
I had a similar problem. My solution (in progress) is to build a mini-tower version of the mains. I felt this was the only way to get the dispersion I wanted without having the mains overpower the center (don't have the cash or space for an AT screen). I actually should be done with my rough final enclosure Sunday or Monday, then it's time for testing testing testing.
Old 04-27-08, 09:35 AM   #3 (Link)
Alias: Randy
Loc: Minnesota, USA
User: #12896
Since: Oct 2007
Thanks Boom, that looks like a swell center you've got there.
I usually can't, but last night I watched a couple movies at reference level (as calibrated by Audyssey on my Onkyo 805, 0.00dB), and noticed that my center is both honky and shrill, but vertical placement helped, but the tweeter was then about a foot from the screen and way out of line with the mains'. It looks like I'm back to looking at AT screens.
My screen is not a constant part of the room, so I was thinking of building a cabinet that would hold the screen and serve as a speaker. The problem is the I sit so close to the front stage that the center being out of alignment is really noticeable.
Like I said, I'm just brainstorming, feel free to think outloud with me.
Thanks guys.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Similar Threads
ART Cleanbox mod thread ccdoggy DIY Subwoofers 93 10-06-08 08:11 PM
ADHT: OB Center (theater) build Anthony DIY Speakers 15 03-17-08 09:27 PM
Update on my OB Center build Anthony DIY Speakers 6 02-26-08 10:31 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
