2nd Order Crossover - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
2nd Order Crossover
Discuss 2nd Order Crossover in the DIY Speakers and Subwoofers forum; 2nd Order Crossover I need to construct a 2nd order crossover for my dipole woofer and Magnepan MC1's and I have a couple ...
Old 05-08-08, 05:17 PM   #1 (Link)
Alias: Matt
User: #16260
Since: Jan 2008
mdrake is online now
2nd Order Crossover
I need to construct a 2nd order crossover for my dipole woofer and Magnepan MC1's and I have a couple of questions. I used to use an old DOS based program for designing crossovers but it has since vanished. What software would you guys recommend? Also what is a good crossover point for the MC1's. I was thinking 160 but that seems to high and might interfere with male vocals. Any thoughts?
Matt
Old 05-10-08, 11:20 AM   #2 (Link)
Alias: Boom
Loc: Fairfax, Va
BoomieMCT's Avatar
User: #4757
Since: Dec 2006
BoomieMCT is offline
Re: 2nd Order Crossover
The best thing would be to set up a maggie away from the corner and run RoomEQ. Take that data and use Passive Crossover Designs (google it) to work on the circuit design. And, of course, nothing beats actually testing and measuring what you make.
Old 05-10-08, 11:44 AM   #3 (Link)
Alias: Matt
User: #16260
Since: Jan 2008
Thanks for the reply and the name of the software!! So, basically see where the MC1 rolls off naturally and then build the sub crossover to match it. GREAT IDEA!!!!!!!!
Do Maggies have a 2nd order roll off naturally?
Matt
Old 05-10-08, 02:44 PM   #4 (Link)
Alias: Boom
Loc: Fairfax, Va
BoomieMCT's Avatar
User: #4757
Since: Dec 2006
mdrake wrote: View Post
Matt
Not *exactly* what I said! What I meant was to verify the performance of the Maggie and dipole bass module with Room EQ so you'd know where to set your x-over. You'd want to set it above where the Maggie rolls off but below where the bass module starts to distort. Also this would help you get an idea of how to deal with the two different baffles as dipole speakers tend to have some decent roll-off from the cancellation of the rear and front waves (which is based on baffle width).
Old 05-10-08, 03:47 PM   #5 (Link)
Alias: Matt
User: #16260
Since: Jan 2008
COOL thanks for the clarification!! I thought you meant to just use a low pass on the sub and let the Maggies roll of naturally. I know where the MMGW's roll of which is 180hz but I am hoping the MC1's go lower. Thanks for the help!!
Matt
Old 05-10-08, 06:15 PM   #6 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
The MC1's do go lower. I have measured them in my room and they are good to 80 Hz. That's on wall with the room gain. Since my crossover is at 80 Hz as well, I kind of take a double whammy with the crossover down and rolloff combining.
So if you want really good integration you can probably count on them around 100 Hz, or try different slopes (steeper with the low pass and shallower with the high pass, since it will combine with the natural rolloff of the speakers).
Old 05-13-08, 03:14 PM   #7 (Link)
Alias: DasBot
User: #20687
Since: May 2008
DasBot is offline
Why not go active and avoid all that sillyness? I use a Rockford Fosgate EPX crossover to give me the whereabouts of what sounds good. That narrows the field and if the application calls for passives, I know where to start.
Old 05-13-08, 03:50 PM   #8 (Link)
Alias: Matt
User: #16260
Since: Jan 2008
I was thinking of going with an active crossover but I would either have to bi amp the MC1 and dipole sub or let the MC1 roll off naturally and use another amp and an active on the dipole sub. Mmmmmmm now you got me thinking....
Matt
Old 05-13-08, 04:35 PM   #9 (Link)
Alias: DasBot
User: #20687
Since: May 2008
DasBot is offline
You can pick up a ButtKicker amp for bass for around $250 and that's 1kwrms and 2ohm stable. A simple cap on the high end would be acceptable for a hp filter. BK amp has a built in filter.
Heck you can pick up a car audio active crossover and an old receiver for $60 to do the job on the cheap.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Similar Threads
Should I add a 2nd sub? lexx2004 Home Audio Subwoofers 37 06-02-08 02:38 PM
I'm about to order a BFD, but look at this... TJHUB BFD Forum 45 05-24-08 08:43 AM
New Sub...2nd try at REW rafaelsmith REW Forum 25 04-01-08 11:25 AM
Order of Calibration? John_Williams REW Forum 2 10-21-06 07:56 AM
Norpus' 2nd IB sub norpus DIY Subwoofers - Infinite Baffle 8 10-18-06 09:55 PM
Mach 5 Audio
