3 way with differing impedence drivers - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Discuss 3 way with differing impedence drivers in the DIY Speakers and Subwoofers forum; 3 way with differing impedence drivers I'm thinking of designing a new 3 way speaker. A WMT, where the efficiency of the Woofer is 91 dB ...
Old 05-11-08, 04:59 AM   #1 (Link)
Alias: Eccentric
Loc: Gold Coast, Qld,Australia
User: #10564
Since: Jul 2007
Jason Schultz is offline
I'm thinking of designing a new 3 way speaker. A WMT, where the efficiency of the Woofer is 91 dB ,
the mid is 88 dB
Tweeter is 91dB
To get the Mid up to 91 dB I thought i could use 2 mid-range drivers. However this would mean that the mid section is 4 ohms and not 8.
Can sombody explain to me why this is not a good idea ?
What are the effects of doing this?
Thanks in advance guys
Old 05-11-08, 08:57 AM   #2 (Link)
Alias: Boom
Loc: Fairfax, Va
BoomieMCT's Avatar
User: #4757
Since: Dec 2006
BoomieMCT is offline
Re: 3 way with differing impedence drivers
This is only a bad idea if your amp can't drive a 4 ohm load or if you are using tubes (which like a flat impedence).
One thought - putting two 88dB drivers in parallel will make the mid's efficiency 94dB. If 91dB is the goal, you can then add a 2 ohm resistor in series so you have 91dB and a 6 ohm load. Most 8 ohm recievers can drive 6 ohms.
One thing to be aware of is that published efficiencies are averaged over the the driver's bandwidth. They are often not perfectly flat or exactly where you might think they are. Make sure to test the drivers in baffle before building the x-over.
Old 05-12-08, 12:04 AM   #3 (Link)
New Member
Alias: Jay
Loc: Indiana
User: #18254
Since: Mar 2008
Jay_WJ is offline
Using drivers with different impedance levels does not cause any problem.
BTW, I don't think you'll need two midrange drivers. If the woofer sensitivity is 91 dB, you'll get only 86 to 87 dB due to baffle step loss. You'll possibly even need to pad the midrange.
-jAy
Old 05-12-08, 03:58 AM   #4 (Link)
Alias: Eccentric
User: #10564
Since: Jul 2007
I am finding this hard to beleive. I have not read anything in depth about baffle step gain/loss. Please correct me but are you saying that the woofers response will be reduced by 4-5 dB because of this effect. Is this only relevant to anechoic measurements or should i be compensating for this in my crosover design?
Old 05-12-08, 04:10 AM   #5 (Link)
Alias: Eccentric
User: #10564
Since: Jul 2007
Thanks for your reply this helps alot. I read a similar thread recently about published driver efficiencies and how they can be misleading.
Regarding the 2ohm resistor to reduce efficiency and raise impedence: should this be added before the cross over or after it. Or do i add a 2 ohm resistor to each positive cable after it forks to go to each mid driver. please pardon my ignorance
Old 05-12-08, 07:09 PM   #6 (Link)
New Member
Alias: denizen
User: #11886
Since: Sep 2007
denizen23 is online now
I purposely used 'mismatched' drivers, to obtain optimal tonal balance. The crossover simply needs to be designed accordingly.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Similar Threads
easiest way to test driver impedence? jeremy7 DIY Speakers 1 02-18-08 01:54 PM
new drivers for older sub dieselpower1966 DIY Subwoofers - Sealed and Ported 8 02-17-08 07:58 AM
AE drivers tpizzle DIY Subwoofers 5 12-14-07 09:59 PM
ID Drivers? Josuah DIY Subwoofers 5 10-30-07 04:50 PM
Venom Drivers a1161979 DIY Subwoofers 2 08-29-07 03:57 AM
Mach 5 Audio
