Good midrange driver? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Discuss Good midrange driver? in the DIY Speakers and Subwoofers forum; Good midrange driver? Can anyone reccommend a good midrange driver to use from about 350Hz to about 3.5 KHZ, effeciency around 88 dB. ...
Old 05-13-08, 02:49 AM   #1 (Link)
Alias: Eccentric
Loc: Gold Coast, Qld,Australia
User: #10564
Since: Jul 2007
Jason Schultz is offline
Can anyone reccommend a good midrange driver to use from about 350Hz to about 3.5 KHZ, effeciency around 88 dB. oh and easy to cross over
(does anyone still build 3 ways?)
Jason
Old 05-13-08, 04:28 AM   #2 (Link)
drf
Alias: drf
Loc: Somewhere else.
drf's Avatar
User: #3282
Since: Oct 2006
drf is offline
Re: Good midrange driver?
Have you checked out the Jaycar stuff? How much do you want to spend? are you o.k with online shopping?
"Until mankind is peaceful enough not to have violence on the news, there's no point in taking it out of shows that need it for entertainment value." - Clueless
The imperative is to make a subjective study an objective fact.
Old 05-13-08, 05:42 AM   #3 (Link)
Alias: Eccentric
User: #10564
Since: Jul 2007
Yes and I've checked their stuff and nothing they have looks much good. what i mean by good is a flat response with decent xmax and no nasty resonant peaks in area above 2khz. I suppose i would spend around max $100 au for a good driver. . I have shopped online before and bought drivers imported from US by an oz company. I am quite happy with that
Old 05-13-08, 06:02 AM   #4 (Link)
Alias: Boom
Loc: Fairfax, Va
BoomieMCT's Avatar
User: #4757
Since: Dec 2006
BoomieMCT is offline
How about the Dayton RS-125-8? If the efficiency is too low maybe you can use the 4 ohm version. I've also had good experience with the Tang Band W4-1320.
Old 05-13-08, 06:05 AM   #5 (Link)
Alias: anthony
User: #16309
Since: Feb 2008
mayhem13 is offline
Peerless XT19-Under a hundred dollars U.S. and 87db-close enough?
Old 05-13-08, 07:54 AM   #6 (Link)
New Member
Alias: denizen
User: #11886
Since: Sep 2007
denizen23 is offline
The Vifa PL14-WJ09-04 is a very good 88db driver and easy to cross-over.
Also checkout the even smoother PL11-MH09-08 @ 87db.
Yes some do still build three-ways.
Old 05-13-08, 09:22 AM   #7 (Link)
Alias: Matt
User: #16260
Since: Jan 2008
mdrake is offline
Madisound has some nice mids on their site. The MMGW is a really sounding midrange panel but it could be hard to implement in a three way. There is also the NEO-8 which is a really nice driver but you will have to attenuate it with a resister as the it is 94db. Here is a link
Also the NEO 10 is supposed to be available to DIY in late 2008.
Matt
Old 05-13-08, 01:53 PM   #8 (Link)
Alias: Mike
Loc: Chattanooga, TN
User: #5740
Since: Jan 2007
mgboy is offline
Is the TB W5-704 an okay match?
Old 05-13-08, 02:07 PM   #9 (Link)
Alias: Matt
User: #16260
Since: Jan 2008
mdrake is offline
GR-Research is another mid-woofer you could look at. I have their sub and I am NOT all to excited about it but their mids might be better. The value factor is high.
Matt
Old 05-13-08, 03:10 PM   #10 (Link)
Alias: DasBot
User: #20687
Since: May 2008
DasBot is offline
There are about 50 drivers that will fit the bill. Tell us more about the project as a whole.
Old 05-14-08, 04:49 AM   #11 (Link)
Alias: Eccentric
User: #10564
Since: Jul 2007
thanks everyone for your input i'm slowly working my way through your suggestions. To DS 21 Can you please explain the directivity issue of crossing a mid to tweeter. and how do others deal with this.
My system as it is at present is a 200mm woofer (SEAS BASIC) with a sensitvity of 91dB as published in a 28 litre enclosure tuned to 34 Hz .
the baffle is 23.5 cm wide. I'm not sure what tweeter i will use but I Think it will be a vifa D27 TG 35-8. Not all drivers are readily available in Australia.
Old 05-15-08, 05:34 AM   #12 (Link)
Alias: Eccentric
User: #10564
Since: Jul 2007
For those who are interested I have decided (when i get round to it) to use/buy a pair of Peerless SDS 5 1/4 " midwoofers.cat No. 830887.
they have an amazingly flat FR from 150 Hz to 4K.are 88.5dB 1w/1M,
have 3.5mm one way Xmax,and pwr handling around 85W.and aren't overly expensive.I'll probably use a seaeld box with Q-.7.
Old 05-15-08, 03:40 PM   #13 (Link)
Alias: Looney
Loc: Topeka, KS
User: #2678
Since: Sep 2006
looneybomber is offline
Jason Schultz wrote: View Post
I second that. I don't think I understand what you're saying DS-21. The directivity of the tweeter or do you mean midrange?
Old 05-15-08, 04:28 PM   #14 (Link)
Alias: Boom
Loc: Fairfax, Va
BoomieMCT's Avatar
User: #4757
Since: Dec 2006
I'll take a shot at this. Drivers will "beam" when the width of the cone approaches the wavelength of the frequency being reproduced. Becuase of this if you have a midbass and a tweeter that make a nice flat FR across the crossover region on-axis it might not be flat off axis because the midbass will start beaming before the tweeter. The two ways to deal with it is to control the directivity of the tweeter to match that of the midbass OR cross over low enough that the crossover point is below where the midbass will beam.
Is this basically it?
Old 05-15-08, 04:31 PM   #15 (Link)
Alias: Looney
Loc: Topeka, KS
User: #2678
Since: Sep 2006
Yeah, I understand all of that, which is why I was confused about his remark about the tweeter. The tweeter should be fine, but the mid could be problematic and thus why I asked if he meant mid instead.
Old 05-16-08, 12:47 AM   #16 (Link)
Alias: Eccentric
User: #10564
Since: Jul 2007
Yeah thanks boomie and looney.
I havn't done the math yet but I would have thought 3.5Khz would have produced an ok off-axis response using a 5.5 inch mid. Actually I'm just looking at the 30Deg off axis response for this driver now and its remakably good. only 2db down at 3000 Hz. I might try to cross it at 3 instead of 3.5 KHZ. I could have gone for a 4 inch mid which could be crossed higher without beaming but I would prefer to have a little more radiating surface area (5.5 inch) so the driver doesn't use up too much xmax while playing loud operating in the 300 hz area.
I will most likely use a 2nd order Bessell or LR for this Woofer to Mid XO so the mid will still be producing some sound a little lower than 300 Hz
Old 05-16-08, 02:14 PM   #17 (Link)
Alias: Looney
Loc: Topeka, KS
User: #2678
Since: Sep 2006
Jason: A little beaming may not be all that bad depending on how the mid is used and how you primarily listen to your music/movies. In some applications, it could even be a necessity, but that's typically in a pro-audio application at large venue's.
Old 05-27-08, 06:04 AM   #18 (Link)
A9X
New Member
Alias: x
Loc: Australia
User: #15182
Since: Jan 2008
A9X is offline
True, but there is the internet and mail.
I have some NIB/NOS Vifa P13-8 that I was going to use in a set of Lynn Olson's ME2's a while back before I discovered high eff drivers.
Old 05-29-08, 11:35 AM   #19 (Link)
Alias: tc
Loc: Edmonton
User: #1410
Tristanc1 is offline
CSS(creative sound solutions in Canada) has some new mid's that look interesting, with an intro pricing of $140/pair. Might also want to look at their other 4" full ranges, supposed to be pretty good http://www.creativesound.ca
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Similar Threads
which appropriate driver v1rtu0s1ty DIY Subwoofers - Sealed and Ported 23 02-28-08 12:43 PM
Good low-cost 12" driver? whines DIY Subwoofers 17 11-14-07 10:48 AM
Driver Noise derekbannatyne DIY Subwoofers 18 05-31-07 05:20 AM
Reverse Driver? mgboy DIY Speakers 6 02-02-07 10:38 AM
Sub Driver Distance Josuah DIY Subwoofers 2 10-10-06 09:22 PM
Mach 5 Audio
