What lightweight wood? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Discuss What lightweight wood? in the DIY Speakers and Subwoofers forum; What lightweight wood? I want to mount a few B3S speakers on the wall. I have 3/4" mdf around but I imagine that ...
Old 05-15-08, 10:13 PM   #1 (Link)
Alias: Brian
Loc: Oklahoma City
User: #5872
Since: Jan 2007
bonehead848 is offline
I want to mount a few B3S speakers on the wall. I have 3/4" mdf around but I imagine that is going to be fairly heavy and overbuilt. These are only 3" speakers. So what lightweight wood would you guys recommend? They will be painted black so the wood does not have to be pretty.
Old 05-15-08, 11:40 PM   #2 (Link)
Alias: sollars
Loc: Kansas City, Missouri
User: #19719
Since: Apr 2008
mrsollars is offline
Re: What lightweight wood?
basswood is fairly cheap and light. holds paint well.
i use it for woodcarving.
matt
Old 05-16-08, 07:36 AM   #3 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is online now
You could go with 1/2" MDF. It will keep the low-resonance and stability of MDF, but be a lot lighter.
While wood movement is less of an issue as the scale of the box gets smaller, it is still something to worry about. Ply/MDF do not have this problem.
Another trick people do is to build the case out of MDF or ply and make the front baffle out of oak or maple and have it "float". Basically, secured, but weatherstripped to get a good seal. It is free to expand and won't split the cabinet. however if you are going to paint the whole thing, this may be overkill.
Old 05-16-08, 07:44 AM   #4 (Link)
Alias: Dom
Loc: United Kingdom
User: #19056
Since: Apr 2008
Tripp is offline
Ply wood is a very good aterial imo, its lighter and very very rigid, although i dont know how good the sound dampening qualities are compared to MDF.
Old 05-16-08, 08:38 AM   #5 (Link)
Alias: Ben
Loc: Manitoba
User: #739
Bent is online now
Are trying an established design, or using your own?
Why I ask, is I have a pair of B3S's and associated filter components on order to build Zaph's B3S full range system, I can't hit his 0.12 ft^3 enclosure recomendation, but I have a pair of 12" long tubes cut out of 4" PVC with a slice out of them for a faceplate that should allow 0.08 ft^3.
Zaph said I may notice a bit of a response hump, but I'm sure they will work pretty good none-the-less.
Old 05-16-08, 11:08 AM   #6 (Link)
Alias: Brian
Loc: Oklahoma City
User: #5872
Since: Jan 2007
Yeah they are zaphs design but I don't think the tubes would pass for WAF. I had thought about .5" mdf but my local lowes does not carry it. I guess I could try calling around. I also really like the idea of ply. I believe that would be the lightest right? Some stuffing should take care of any dampening issues.
Old 05-16-08, 03:25 PM   #7 (Link)
Alias: Ben
Loc: Manitoba
User: #739
Bent is online now
stiffness woun't be much of an issue with these 'lil fellas, I think they run out of steam at about 90 hz, and don't go too much lower.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Similar Threads
What type of wood jwhite8086 DIY Speakers 13 01-17-08 04:55 PM
Wood Choice jokers10 DIY Subwoofers 20 12-02-07 01:27 PM
Wood Technology lcaillo Manufacturer and Vendor Reference Information 0 04-30-07 09:52 PM
Wood Clamp sale! Darren DIY Subwoofers 1 03-29-07 08:14 PM
Acoustical wood ceiling Dain Bramaged Home Audio Acoustics 14 02-03-07 09:50 PM
Mach 5 Audio
