| DIY Speakers SR-71 Build CompleteDiscuss SR-71 Build Complete in the DIY Speakers and Subwoofers forum; SR-71 Build Complete Hi all
Just got finished with my SR-71 bit build. Made the cabinets from scratch w/ leftover mdf from my ... |
| | #1 (Link) | |||
| SR-71 Build Complete Hi all Just got finished with my SR-71 bit build. Made the cabinets from scratch w/ leftover mdf from my TC-2000 project. 3/4" mdf with double front baffle, braced with dowels. Cabinets are the same volume as madisound cabinets. I used a really nice etimoe veneer and spent the time to piano finish the baffles (not sure why i did this since they are covered with the grill but the edges look really good) They sound very good - very happy with the sound. I will try to post some better pics in the near future. Just snapped a few with low light and no tripod but I think you can get the idea for now. ![]() ![]() ![]() ![]() | |||
| | #6 (Link) | |||
| Re: SR-71 Build Complete Hi, I really like the look of your cabinets. I just got done with a pair of these myself. I really like the openess of the soundstage. I'm only using them for music myself. Hope you like them as much as I do! James | |||
| | #9 (Link) | |||
| Re: SR-71 Build Complete Wow-wow-we-wow, VERY NICE. I've never done any veneering but I've done a lot of wood work over the years and I know it is difficult to get a finished product that looks that nice. Excellent job. Sharp Aquos 52" - Denon 3808CI - HTPS 7000 - AVS 2000 - Dish Network VIP722 DVR - Helios X5000 - PS3 for Blu-ray and gameing - Custom 7.1 system (upgrade in progress) - Harmony 722 Universal Remote | |||
| | #10 (Link) | |||
| Re: SR-71 Build Complete Hi all Thanks for all the great comments! I want to respond to everyone but work has been nuts! This was a great project and am very happy with wound and results. I should have some this weekend to get a proper reply together | |||
| | #11 (Link) | |||
| Re: SR-71 Build Complete Finally got a few minutes to reply The grills were DIY. I had to borrow a table saw from a friend for the box and was not able to get it again to cut mdf square for the grills so I had to improvise. I ended up using shoe molding from home depot and cutting it to basically make a shoe molding/picture frame/speaker grill. It ended up working out pretty good. As far as cabinet construction, I am a big fan of using the construction process outlined in http://www.subwoofer-builder.com/freesoft.htm This allows to route everything so it is square and true - a fair amount of routing but the results are predictable. As far as the veneer- this was the first time I worked with raw veneer/ Previously everything was paperback. I just coldpressed the veneer with Better Bond extra dark and every possible clamp I could find. There was a fair amount of bleed through of glue through the grain. On the test piece I used a mdf platen and ended up with the platen glued to the veneer So, after reducing the volume of the glue and putting aluminum foil between the platen and veneer things were good. There was still some bleed through that had to be sanded down so the finish was even. As far as trimming the veneer..... there was only one method that finally gave good results. I had to score the top of the veneer (visible side) until the xacto just started to break through and then snap off the veneer. This produced a clean top edge that could then be sanded flush. Every other method I tried produced chipping of the veneer. The finish was my favorite teak oil and Briwax. No staining or anything, the veneer is so naturally beautiful nothing had to be done to it. The stands are DIY also. Just scrap mdf and a piece of poplar from the Depot rounded off at the front. Some good ol satin black and done! Now I just have to convince the wife that I (we) NEED a new center and rears...... ![]() | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Complete noob - Before I start...... | scoobz | REW Forum | 2 | 03-20-08 12:58 PM |
| TC-2000 Build Complete w/pics | jkoll42 | DIY Subwoofers | 19 | 03-07-08 05:57 PM |
| New HT - complete comparison | bswiftly | Home Theater System Recommendations | 8 | 02-27-08 04:43 PM |
| Complete Noob needs Help | RT3 | DIY Speakers | 1 | 12-14-07 07:15 PM |
| What complete system for around $750 | turbochad | Home Theater System Recommendations | 26 | 12-06-07 03:13 PM |
