beaming ? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
beaming ?
Discuss beaming ? in the DIY Speakers and Subwoofers forum; beaming ? Hello, I have finished my baffle for my new WMTMW speaker. I have the Scan-Speak 95000 one inch tweeter and ...
Old 07-07-08, 01:20 PM   #1 (Link)
Alias: vince dallaire
Loc: Phoenix, AZ
User: #12578
Since: Oct 2007
vince is offline
beaming ?
Hello, I have finished my baffle for my new WMTMW speaker. I have the Scan-Speak 95000 one inch tweeter and two Peerless three and a quarter inch mids, this is the middle of surr. to mid of surr. I am electronicly cross at 24db per octave using Marchand gear. My question is this, I have heard in the forum at times about "beaming", can someone explain a little? I need to determine the cross point so I can make the purchase from Marchand for the plug in module's. I will get a few on either side of the cross point I come up with. Just want to limit beaming problems if possible.
Thanks
Vince
Old 07-07-08, 02:06 PM   #2 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Re: beaming ?
Put simply, beaming is where you ask a driver to play too high. There are other issues with playing too high, such as breakup distortion, but that's another discussion.
I forget where the actual cuts are, but as the wavelength of the sound approaches the width of the driver the sound tends to beam more. when this happens, you get full output on-axis, but then very rapid lowering of volume as you move off axis. If you toe in your speakers and sit exactly in the sweet spot, you may never notice beaming at all.
But in the real world, you have people sitting off axis, or the speakers fire straight ahead, so this is a problem. With the beaming, a nice natural sounding speaker might sound hollow or dull at certain frequencies because those are being beamed and you aren't on the axis. This balance will change based on driver size and position (both speaker and seating position). Also, if it's bad enough, you may have one ear hearing the full signal and the other attenuated, which needless to say, sounds weird.
So beaming is to be avoided. Thankfully, it's easy to avoid if you just don't push the drivers to play too high. I don't have my reference books handy, so hopefully someone else will chime in with some actual figures.
I've crossed 3" speakers at 3 Khz with no beaming problems and crossed 8" speakers at 500 Hz with no beaming. When I crossed those same 8" speakers at 1kHz you could hear the beaming effect.
Good luck.
Old 07-07-08, 03:57 PM   #3 (Link)
Alias: Bill
Loc: New Hampshire
User: #21930
Since: Jun 2008
Bill Fitzmaurice is offline
Re: beaming ?
vince wrote: View Post
Thanks
Vince
What's more important is the excessively lobed response you'll get from the woofers and mids if they are crossed too high. Ideally they should be crossed no higher than where one wavelength equals their center to center distance. Where beaming is concerned ideally the actual cone diameter should be no more than 1 wavelength where it crosses over. But there's a fair amount of wiggle room between what's ideal and what's sufficient.
Bill Fitzmaurice
Bill Fitzmaurice Loudspeaker Design
Old 07-07-08, 09:30 PM   #4 (Link)
Loc: Phoenix, AZ
User: #12578
Since: Oct 2007
vince is offline
Re: beaming ?
Thanks guys, I wish I would have thought of this sooner, but I think I can make it work. The distance from center of Scan Speak donme to center of Peerless mid is exactly five inches. I will do now some calculations and see what I can come up with concerning diameter of mid and center to ceter situation. Again thanks for the input!
Vince
Old 08-04-08, 04:54 PM   #5 (Link)
JMB
New Member
Alias: Jay
Loc: Texas
User: #3849
Since: Nov 2006
JMB is offline
Re: beaming ?
Okay, it won't allow me to post a link. There is a website called the FRD Consortium, where you can find the Asymmetrical Response Pattern Estimator (ARPE). This will graphically provide you with what you want (you need excel or perhaps open office to run this).
Jay
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
