You'd need an 8" that is flat to 1 kHz and with a smooth roll off above that. This would put your woofer/mid crossover around 250 Hz, so the 8" really isn't needed unless you had an 8" in mind with high sensitivity to match the 15" and that Beyma horn (102 dB is quite high).
If you have the amps and EQ already to go active, that could be your best bet.
Hello,
the first project of my DIY loudspeakers i have served Ti6k- JBL. My first contact with
them, was in distant 2005.
I started working with them in 2009 and finished in 2012.
The loudspeakers are "SEAS"- Excel / Tw-1”, Mw-5”for center 2х 5.5”,Bass-8,5”/ and cross-over parts- "Intertechnik".
Have are some pictures, if there is interest, i will continue.
Regards!
Wow! That's a beautiful curved cabinet build! Very very nice work. I'm curious, what was the foil tape for? I don't think I've seen it used in a speaker build before. The shape of those cabinets is fantastic.
Related Threads
742.3K posts
170.9K members
Since 2006
