DIY SpeakersDiscuss Adding protection to mini monitors for sub use? in the DIY Speakers | DIY Subwoofers forum; Adding protection to mini monitors for sub use? I built a pair of mini monitors for a friend and now he wants to incorporate a subwoofer into the ... |
Views: 402 - Replies: 15
| Adding protection to mini monitors for sub use? I built a pair of mini monitors for a friend and now he wants to incorporate a subwoofer into the system. How do I cut the low frequency to the monitors to about 80 Hz? Thanks for looking! | ||||
| | #2 | |||||
| Re: Adding protection to mini monitors for sub use? Quote:
1. You can get a sub with speaker level crossover. 2. You can get a sub with line level crossover. 3. You can buy a crossover, line or speaker level, to add. 4. You can put a capacitor in the line before the amp or speaker cable. More info needed. Kal Kal Rubinson __________________________________ "Music in the Round" Contributing Editor, Stereophile | |||||
| | #3 | ||||
| Re: Adding protection to mini monitors for sub use? I'm using this amp: http://www.apexjr.com/MnKAmp.htm And and old Sony stereo integrated amp with out pre-outs | ||||
| | #4 | ||||
| Re: Adding protection to mini monitors for sub use? The left and right speaker outputs from the Sony connect to the L+R speaker inputs on the sub amp, the L+R speaker outputs on the sub amp connect to the mini monitors. Set the Low Pass on the sub amp to 80 hz. We're all in this together! Members DIY Subwoofer Database Enclosure Volume Calculators Driver Wiring Diagrams | ||||
| | #6 | ||||
| Re: Adding protection to mini monitors for sub use? Yes. Let us know how it turns out. We're all in this together! Members DIY Subwoofer Database Enclosure Volume Calculators Driver Wiring Diagrams | ||||
| | #8 | ||||
| Re: Adding protection to mini monitors for sub use? Nope. No where do I see anything about a HP filter for the pass through. Is there something in the specs I missed? Kal Kal Rubinson __________________________________ "Music in the Round" Contributing Editor, Stereophile | ||||
| | #10 | ||||
| Re: Adding protection to mini monitors for sub use? It's either adjustable from the law pass on the sub or built in and fixed at 80 hz like most other plate amps that have speaker level inputs. Either way the lows go to the sub and 80 hz and above go to the monitors. We're all in this together! Members DIY Subwoofer Database Enclosure Volume Calculators Driver Wiring Diagrams | ||||
