| DIY Speakers Diy Centre speakerDiscuss Diy Centre speaker in the DIY Speakers and Subwoofers forum; Diy Centre speaker Hi i have read that you can build the centre speaker box first then design the crossovers second is this ... |
Views: 943 - Replies: 10
| Diy Centre speaker Hi i have read that you can build the centre speaker box first then design the crossovers second is this true? . i can get the crossover professionally built I want to use the following listed.1x 1" HDS Peerless tweeter T-S Parameters Resonance Frequency fs 700 Hz Mechanical Q factor Qms -- Electrical Q factor Qes -- Total Q factor Qts -- Force factor Bl -- Tm Mechanical resistance Rms -- Kg/s Moving mass Mms -- g Suspension compliance Cms -- mm/N Effective cone diameter D -- cm Effective piston area Sd -- cm2 Equivalent volume Vas -- ltrs Sensitivity (2.83V/1m) 93 dB 2x 6.5" HDS Peerless Phase plug mid woofers. T-S Parameters Resonance Frequency fs 41.9 Hz Mechanical Q factor Qms 2.41 Electrical Q factor Qes 0.42 Total Q factor Qts 0.36 Force factor Bl 8.2 Tm Mechanical resistance Rms 1.83 Kg/s Moving mass Mms 16.8 g Suspension compliance Cms 0.86 mm/N Effective cone diameter D 13.1 cm Effective piston area Sd 135 cm2 Equivalent volume Vas 21.7 ltrs Sensitivity (2.83V/1m) 87.8 dB Ratio BL/√(Re) 3.4 Ratio fs/Qts F 122 2x 2.5" full range Peerless T-S Parameters Resonance Frequency fs 101.2 Hz Mechanical Q factor Qms 3.46 Electrical Q factor Qes 0.64 Total Q factor Qts 0.54 Force factor Bl 2.7 Tm Mechanical resistance Rms 0.36 Kg/s Moving mass Mms 1.9 g Suspension compliance Cms 1.27 mm/N Effective cone diameter D 5.3 cm Effective piston area Sd 22 cm2 Equivalent volume Vas 0.8 ltrs Sensitivity (2.83V/1m) 86.5 dB Ratio BL/√(Re) 1.4 Ratio fs/Qts F 186 Or not use these and use 4x 6.5" HDS Peerless Phase plug mid woofers instead of 2 as my original plan. Can someone please model a box for me? Cheers Troy (I am a HT green horn but a quick learner) Last edited by SAY IT LOUD; 06-16-09 at 09:30 PM.. Reason: update info | ||||
| | #2 | ||||
| Re: Diy Centre speaker Posting the T/S parameters of the mid woofers would help. | ||||
| | #3 | ||||
| Re: Diy Centre speaker Why have u chosen these drivers Mr.T ..& are u working with Clayton ![]() Pre: TAS Processor Eq: DCX 2496 Power: Behringer A500, Ebony 290w x4 Source: Sony DVD Front: Tag 2.6 Center: n/a Rear: Yamaha NS-225 Subs: Whise 624 | ||||
| | #4 | ||||
| Re: Diy Centre speaker I am using these as an audio shop i know uses 1x 1" HDS Peerless tweeter 2x 6.5" HDS Peerless Phase plug mid woofers in his centre speaker and sell them for AU$2865 each and gets rave reveiws. I dont know any clayton so no. | ||||
| | #5 | ||||
| Re: Diy Centre speaker www.thespeakerspecialist.com.au This is the Clayton i was referring to, worth a visit... he's in Southport ![]() Pre: TAS Processor Eq: DCX 2496 Power: Behringer A500, Ebony 290w x4 Source: Sony DVD Front: Tag 2.6 Center: n/a Rear: Yamaha NS-225 Subs: Whise 624 | ||||
| | #7 | ||||
| Re: Diy Centre speaker I have been interested in building some peerless speakers for some time now. Please let us know how it goes. If you can share the crossover design as well that would be pretty sweet as well. Thanks, Kyle | ||||
| | #8 | ||||
| Re: Diy Centre speaker Hi Keelay, I brought the drivers today 1X Peerless 1" HDS 810921 and 2x 6.5" Peerless HDS Phase Plug the crossover XON 455-V2 has been desingned for these drivers and are sold for AU $2700. The cost for my build AU$600. I will be time aligning and recessing the drivers. I have all the specs i need for the build. Frequency Response 36Hz to 22KHz Size H1100 x W205 x D375mm Power Req' 10W to 150Wrms Impedance 4 ohm Nominal Sensitivity 92dB Cheers Troy | ||||
| | #10 | ||||
| Re: Diy Centre speaker Looks good am i correct you are time aligning? I will post pics when i can work out how to resize them soon i will give up. | ||||
